Multi-Funtion Module Dotcom panel
Page 1 of 1 [3 Posts]
marvkaye
PostPosted: Mon May 14, 2012 6:54 am    Post subject: Multi-Funtion Module Dotcom panel Reply with quote  Mark this post and the followings unread
I recently purchased PCBs for Ray's Multi-Function Module and decided to go ahead with a panel design for it. My modular started out with Dotcom and that is the format I'm using for all my DIY panels, this one is no different. I thought I'd share it here in case anyone is interested. I'm also working on a plastic mount for the voltmeter LEDs that ties into the PCB bracket, will post that effort as well when it's done & tested.
<marv>
ps (edit)... the drawing as shown is slightly smaller than full size. It should measure 8.5" wide by 8.75" tall. Unfortunately, in order to show the whole thing on a single letter-size page (and still have some margins for printing) the image is scaled down slightly. I scaled it up by 110% and printed to get a 8.75" tall panel, but I was missing about 9/16" of the right hand edge. I tried printing in tiles, but it left out the middle for some reason and changed the size on me slightly... perhaps you'll have better luck with it. I do have a DXF file available, if anyone is interested... PM me for it. Sorry for the inconvenience.
MFOS_MFM_Dotcom-panel.pdf
 Filename:  MFOS_MFM_Dotcom-panel.pdf
 Filesize:  70.53 KB
 Downloaded:  165 Time(s)
iopop3
PostPosted: Mon May 14, 2012 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Really nice! Ive ordered a few dotcom panels from resynthesis.co.uk for my Yusynth modules. So, having this module in MU format is really tempting.
marvkaye
PostPosted: Mon May 14, 2012 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
The dxf file would work well for resynthesis.co.uk if you decide to go that way. I've set it up for CNC engraving and machining, with everything on proper layers for different size holes, different line thicknesses (ie, small tic marks and the lines up the voltmeter are thin, major tic marks and function dividing lines are thick), text is already vector curves, etc. Just so you know.
<marv>
