How to replace Analog Pots with CV control?
Page 1 of 1 [15 Posts]
thefunk
PostPosted: Mon Apr 30, 2012 1:23 pm    Post subject: How to replace Analog Pots with CV control? Reply with quote  Mark this post and the followings unread
I'm looking to use a MicroController to control a number of analog drum circuits. But, I am currently struggling to find a suitable / hassle free method to replace volume (voltage divider) pots with a voltage controlled circuit.
The methods I know of and their issues to me are:
Digital Pots: Only linear. Only allow voltages within the power supply rails: 0-5V for the most part.
OTA: Just seems like overkill. According to the 13700 datasheet I would need a whole a chip for 1 pot.
LED / Photo-resistor / Cell: Would need 2 pairs for each pot and would need to find a way to increase 1 resistance while accordingly reducing the other... non-linearly.
FET: same as photo-resistor.
VC Pot chips: NTE still makes one for $10 each.
Are their any other methods I am missing? How is this normally achieved? Digital pots look like the best method out of the lot, but I'm hoping there is an easier way.
thanks.
Clack
PostPosted: Tue May 01, 2012 12:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes pretty much
An experimental idea I have been playing with is to switch an analogue gate on and off at more that audio rate put a simple filter on it and then adjust PWM
Also a Note that you only need half a lm13700 if it is grounded or single resistance.
Clacktronics.co.uk
slacker
PostPosted: Tue May 01, 2012 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
You can probably get away with using one LDR for each pot. You make the top of the divider a fixed resistor and use the LDR for the bottom or the other way round.
This will work like a volume control, the only thing is the impedance changes with the changes to the LDR's resistance. Depending on what is driving the "pot" this may or may not matter.
You can do the same thing with FETs.
JingleJoe
PostPosted: Tue May 01, 2012 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
What about a D to A converter?
Simply put the output of that into the input of the voltage controlled circuit.
thefunk
PostPosted: Tue May 01, 2012 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks all.
@Clack
Yes 1/2 an lm13700 will work. I missed that. That means I'll only need 14 of them to be able to control the TH Quad Bass++. That, with pwm, a filter and a s&h circuit should work nicely. This is sounding more enticing.
@Slacker
I'm sure I could get away with 1/2 the resistance and a 6dB drop in these circuits, but I would like to find a method I could use reliably without much thinking. Smile Though, these methods are definitely worth experimenting with in single ended pots. (The decay knob in the Bass++)
@JingleJoe
I'm not sure I follow... creating an analog signal from a digital one should not be a problem. Though, a serial digital decoder might be worth looking for... a digital pot without the resistors... hmmm... they must exist.
PostPosted: Tue May 01, 2012 6:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
So which microcontroller?
If you take Arduino as an example, the analog outputs produce PWM signals, which can be filtered with appropriate caps & resistors to provide a steady voltage level for a given value. There are some example circuits "out there" though I haven't looked at them recently because I didn't take that approach.
I think we're assuming that the pots are hooked up with one side on a positive voltage source, the other on ground or a negative source, and the control coming out of the wiper. If that's the case, I'd assume that you could hook the voltage through appropriate resistance to ground and then just connect to where the wiper was connected.
If the pot is being used to control gain on an op amp or transistor circuit, then you'll need something else, I'm not sure what Smile.
thefunk
PostPosted: Tue May 01, 2012 7:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Netduino. So pretty much an Arduino.
Sorry for the confusion, to clarify... the full volume audio wave at one end, ground at the other end (for the most part), and the adjusted volume at the wiper. What I would like is an added control voltage to set the position of the wiper.
I'm starting to see why OTAs are so 'beloved'. Smile The LM13700s look like the best way to go. Though, digital pots might be worth messing around with.
This is the circuit I'm beginning with...
http://www.birthofasynth.com/Thomas_Henry/pdf/Bass_Plus/basspp_schematic.pdf I'd like to be able to control the pots programmatically.
stewpye
PostPosted: Tue May 01, 2012 8:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
You really need to rethink the circuit design rather than just replace pots with something else.
For things like the decay control you could just use a PWM output to switch a transistor that discharges the decay cap.
Wherever there is a simple volume control just use a VCA (LM13700).
Regards,
Stewart.
JingleJoe
PostPosted: Wed May 02, 2012 4:09 am    Post subject: Reply with quote  Mark this post and the followings unread
thefunk wrote:
@JingleJoe
I ment something like an R2R ladder, input your digital binary number and get out a voltage level which you can just feed into the CV input of the circuit, be it a filter or VCO or whatever.
Now if you're talking about level control of say, an LFO signal, thats another kettle of fish.
richardc64
Audio files: 26
PostPosted: Wed May 02, 2012 4:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Regards,
Stewart.
The only places a real DC-coupled VCA are needed in the Bass++ are for Sweep and Range, if it's included. For Shell Volume and Impact Volume I suggest the technique used in the TR-909. The signal at the transistors' collectors (Keep the capacitors,) has to be limited to 1V or less, then boosted back up by the op amp, which would be IC2b in the Bass++.
Impact Tone has me stumped, though. Maybe use 1/3 cd4053 to select full Hi or full Lo?
 Filesize:  6.08 KB
 Viewed:  7065 Time(s)
stewpye
PostPosted: Wed May 02, 2012 7:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
For the impact tone you could use two LM13700 VCA's. The input to one of them comes from the high pass section of the tone circuit and the input to the other one comes from the low pass section of the tone control circuit. You may want to make the input impedance of them similar to what the tone pot is. The control input for one of the VCA's would have to be inverted (and level shifted) in regards to the other.
The shell volume could probably be done by just having an attenuator (similar to the sweep control) between the emitter of Q1 and R18.
Regards,
Stewart.
thefunk
PostPosted: Wed May 02, 2012 11:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah. So the 909 uses transistors not tied to ground. I hadn't thought much about the Impact tone, but using a switch or mixing the outputs seem like good ideas to me.
I guess I should just start tinkering and try them all. It's more fun that way anyway Smile Thanks for the ideas all!
richardc64
Audio files: 26
PostPosted: Thu May 03, 2012 12:59 am    Post subject: Reply with quote  Mark this post and the followings unread
doh
The PWM duty cycle could select anything in between, which expands on...
oldmanfury
PostPosted: Wed May 16, 2012 7:58 pm    Post subject: Re: How to replace Analog Pots with CV control? Reply with quote  Mark this post and the followings unread
thefunk wrote:
Digital Pots: Only linear. Only allow voltages within the power supply rails: 0-5V for the most part. Digital pots look like the best method out of the lot, but I'm hoping there is an easier way.
thanks.
Actually digital pots with an arduino controlling over I2C was fairly easy to implement. Some spotty details here:
http://buzzville.typepad.com/oldmanfury/2010/03/my-first-arduino-project-the-voltage-controlled-grunge-pedal.html
The link to the digital pot tutorial is valuable info.
-gerald
thefunk
PostPosted: Sun May 20, 2012 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. That's cool! I've got one of those pedals... somewhere, from my 'grunge' days Smile .NET Micro is about as simple at SPI control.
