Joined: Apr 03, 2004 Posts: 24515 Location: The Netherlands, Enschede
Posted: Wed Aug 08, 2012 8:29 am Post subject:
Yup, thanks for the copy, looked fine, and thanks for sending that to them! _________________ Jan
BobTheDog
Audio files: 32
Posted: Wed Aug 08, 2012 8:32 am Post subject:
Ok good, Just checking it went out ok.
Lets see what they say.....
My guess is its some resource leak in their audio/firewire code on the pacarana. |
Posted: Wed Aug 08, 2012 8:45 am Post subject:
There are multiple issues I think, with a USB interface I run in trouble too, just seems to last a bit longer overall ... but there is some random component too, and my gut feeling is that OSC is not handled correctly either. _________________ Jan
BobTheDog
Audio files: 32
Posted: Wed Aug 08, 2012 9:20 am Post subject:
An interesting test may be to disable all audio channels apart from two and see if it lasts longer on the Konnekt.
Was the USB interface a two channel one? |
Posted: Wed Aug 08, 2012 9:25 am Post subject:
Yes it was 2 ch, still is
Interesting way to look at it ... I'll reconnect the t.c. again this evening ... how would i disable channels on it? In kyma, or would i need re-install its driver?
I don't really want to use the USB one - it's my zoom h2 thingie and want to take that one with me for when I run into interesting sounds to sample. _________________ Jan
BobTheDog
Audio files: 32
Posted: Wed Aug 08, 2012 9:37 am Post subject:
I just tried it in Kyma DSP Status->Configure
I turned all input channels off and all outputs apart from 1&2 off, The I/O % on the front panel just seems the same evern after a restart.
Might be worth a punt though. |
Posted: Wed Aug 08, 2012 11:35 am Post subject:
Ok restarted with tc connected and nothing else changed. Turned all inputs off, and kept two outputs enabled.
4 minutes .. counting. _________________ Jan
Posted: Wed Aug 08, 2012 11:39 am Post subject:
Previous setup had run for about 140 hours ... not a week ... what I did see however that one DSP was running at 43% and I/O was running at about 20%.
I/O is now 94% .. 99% and DSP 4 is at 37%, the others at 1%. _________________ Jan
BobTheDog
Audio files: 32
Posted: Wed Aug 08, 2012 11:56 am Post subject:
Wow that I/O is high!
Mine with all channels going varied wildly between 20-77%.
My DSP 4 was always at 44%.
What I/O delay have you got it going at, mine is at 14ms.
Just changed I/O dalay to 4.5ms and I get a lower I/O %, seems to stick pretty solidly at 26% with the odd leap up to 75%.
I wonder what that figure signifies! |
Posted: Wed Aug 08, 2012 12:31 pm Post subject:
10 ms _________________ Jan
Posted: Wed Aug 08, 2012 12:33 pm Post subject:
But erm .. no idea what it means, I;ve reported that number to symbolic sound one time .. got no comments on that.
edit (the I/O percentage). _________________ Jan
Posted: Wed Aug 08, 2012 3:53 pm Post subject:
<bang>
2 hours 48 minutes and 57 seconds
Pacarana is not responding, Unhandled Firewire bus reset or Firewire error (22)
lemme reload ... cursor turns into watch ... please turn on or connect connect your Kyma signal processor ... ok ... pacarana still shows 37% for DSP 4 I/O 36% now ... ok .. pull firewire cables ... put them back ... hit ok again ... watch ok .. its back it seems ... saving debug logs ... I/O back to 46 ... 88% DSPs all at 1% .. staring patch again ... and it runs ...
ok, sent out the deb ug log. _________________ Jan
BobTheDog
Audio files: 32
Posted: Wed Aug 08, 2012 11:26 pm Post subject:
Well my idea about the audio channels was a no go then.
Its interesting that it restarts the same as mine if you pull the cables.
I wonder if your log will have the "logical unit reset" like mine did.... |
Posted: Thu Aug 09, 2012 2:39 am Post subject:
It apparently did.
When I left home this morning for work the thing was still running BTW. _________________ Jan
Posted: Thu Aug 09, 2012 2:42 am Post subject:
After checking home stream - it still runs. _________________ Jan
Posted: Wed Aug 22, 2012 4:39 am Post subject:
The symbolic sound folks found an issue and made a fix for that ... the current patch has been running now for 65 hours with the t.c. electronic ... this is looking good!
Going to let it run a bit more and then will plug in some OSC stuff again. _________________ Jan
BobTheDog
Audio files: 32
Posted: Wed Aug 22, 2012 4:57 am Post subject:
| Great stuff, if yours fails again I can do some more testing...... |
Joined: Apr 24, 2009 Posts: 2508 Location: Bristol UK
Audio files: 500
BobTheDog
Audio files: 32
Posted: Wed Aug 22, 2012 5:03 am Post subject:
We expect great things from you now Jan
I want to start using mine more, seems to have been gathering too much dust lately. |
Posted: Thu Aug 23, 2012 5:24 am Post subject:
I just survived a power dip that made me have to restart adsl modem, ethernet switch, local server and a laptop's ethernet connection
almost 90 hours now  _________________ Jan
BobTheDog
Audio files: 32
Posted: Thu Aug 23, 2012 5:25 am Post subject:
| It will outlast us all now! |
cebec
G2 patch files: 31
Posted: Thu Aug 23, 2012 5:44 am Post subject:
Where I wrote "I" I meant "It" BTW. _________________ Jan
Posted: Fri Aug 24, 2012 8:31 pm Post subject:
To have some OSC again I've plugged the ethernet cable in after 116 hours or so without crashing ... been stable for 12 hours now in that new situation, and counting.
Thank you very much Andy for stepping in, it was your crash report that pointed to the bug fix
Looks like solved to me
(knocking wood, we need a knock on wood emotismile thingie) _________________ Jan
BobTheDog
Audio files: 32
Posted: Sat Aug 25, 2012 1:16 am Post subject:
Really glad to hear that  |
