Saw waves with adjustable width?
Page 1 of 1 [6 Posts]
tranzash
PostPosted: Fri Apr 01, 2005 6:10 pm    Post subject: Saw waves with adjustable width? Reply with quote  Mark this post and the followings unread
Hey guys, is it possible to make a building block for adusting saw waves's width. I think alphajuno have this osc algorithm (maybe the M5 too).
Please help Smile
Chet
G2 patch files: 35
PostPosted: Fri Apr 01, 2005 7:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Shape Oscillator can do that. Or do you mean a different kind of shaping?
tranzash
PostPosted: Fri Apr 01, 2005 7:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey Chet, I'm talking about those alphajuno's type saw waves, like you could change the saw's width just like you change a pulse waves width. To create those Hoover bass drones Laughing Probably a building block using G2's osc B and changing those double saw's width.
The reason why I'm asking is that I saw an alpha juno1 at samash for $175.00 Smile
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri Apr 01, 2005 10:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
The modulatable saw from the Alpha Juno is not like the sophisticated ShapeB saw options, it is a regular saw, AM modulated by a PWM square of twice the frequency. It is SAW03 wave BTW, and can be selected in combination with the PWM rectangle. Unlike the rectangle which goes from 50-100%, the double frequency PWM used to chop SAW03 are modulated from 0-100%
This patch has a Alpha Juno SAW03 building block along with a PULSE03 and SUB00 mixed into a VCF VCA CHORUS ETC.
SAW03 0/50/75% modulation
 Filesize:  4.06 KB
 Viewed:  7491 Time(s)
JunoSaw.pch2
ROLAND AJ/MKS SAW03
 Filename:  JunoSaw.pch2
 Filesize:  1.95 KB
 Downloaded:  1932 Time(s)
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Sat Apr 02, 2005 12:17 am    Post subject: Reply with quote  Mark this post and the followings unread
And if you're looking for a G2 patch that emulates the Alpha Juno hoover patch, have a look at this:
http://www.electro-music.com/forum/topic-2809.html
tranzash
PostPosted: Sat Apr 02, 2005 6:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Afrokid, I already have your 'what the' patch.
G2ian Thanks for that alphajuno's building block Very Happy
