ARP Odyssey MKII/III VCO - Eurorack Format
Page 3 of 5 [122 Posts]
Broadwave
Audio files: 6
PostPosted: Wed Apr 10, 2013 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I had a bunch of them made by Futurlec - Very good quality, reasonably priced, but delivery takes forever Rolling Eyes
If I need to build anything that needs a quality PCB, I have to plan months in advance Wink
I'm currently working on upgrading my Odyssey (extra VCO & LFO, Aftertouch and 40235 Dual Filter) so I'll be busy for a while, but I'll keep popping in to see how things are cooking.
Synth DIY Projects
Musical Doodlings
furio
PostPosted: Wed Apr 10, 2013 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi guys! Smile
I offer the acrylic engraved panels for 6 EUR each and an aluminum engraved panel for 23 EUR.
 Filesize:  532.89 KB
 Viewed:  680 Time(s)
steffensen
PostPosted: Wed Apr 10, 2013 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, Futurlec, thats awesome man. Any chance you could share the file needed for a order from them? Or if we could arrange something? I really want more of these VCO's. Very Happy
steffensen
PostPosted: Wed Apr 10, 2013 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
furio wrote:
Hi guys! Smile
How does the aluminium engraved ones look? Is it the black ones on Page 2 of this thread? Wasnt sure if they were alu or acrylic.
furio
PostPosted: Wed Apr 10, 2013 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
steffensen wrote:
furio wrote:
Hi guys! Smile
It was just to show that you can use 9 and 16 mm pots ...We do those black in Acrylic. The aluminium black ones has not yet arrived! Wink
steffensen
PostPosted: Wed Apr 10, 2013 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
furio wrote:
steffensen wrote:
furio wrote:
Hi guys! Smile
Cool, looking forward seeing them.
Any sketch to share until then? Curious on the design. Smile
furio
PostPosted: Wed Apr 10, 2013 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
it should come out similar to those in acrylic that I posted previously... I just widened the title for security and optimized traces
 Filesize:  51.25 KB
 Viewed:  34556 Time(s)
steffensen
PostPosted: Wed Apr 10, 2013 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice one. Smile
Not sure about the font for the main label, its pretty hard to see. Looks like its a tight build there, but it is doable. I really need a couple more of these puppies..
noiselector
PostPosted: Wed Apr 10, 2013 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Furio, I want 5 black acrylic panels.
furio
PostPosted: Mon Apr 15, 2013 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
the aluminum panels are here !! Very Happy
 Filesize:  532.58 KB
 Viewed:  658 Time(s)
paulstone
PostPosted: Mon Apr 15, 2013 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello guys this is my first post here Smile
interested for 4 pcb and alum. panels if are disponible thx
Audio files: 308
PostPosted: Mon Apr 15, 2013 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome paulstone & thanks!
steffensen
PostPosted: Tue Apr 16, 2013 2:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Looking good man. Smile
How much for these?
Is it a tight squeeze to fit it all in 8HP? Build pic?
noiselector
PostPosted: Tue Apr 16, 2013 2:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, PCBs are available.Nice looking Furio!!
paulstone
PostPosted: Tue Apr 16, 2013 3:13 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome paulstone - could you please freeze your avatar?
hi blue thx for the welcome , yep i will change Smile
ciao
P.
steffensen
PostPosted: Mon Apr 22, 2013 7:03 am    Post subject: Reply with quote  Mark this post and the followings unread
How much for these?
furio
PostPosted: Mon Apr 22, 2013 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I am so sorry everyone for my delay in answering questions... I have been working for a whole week on testing and checking my PCB... discovering that the CD4011 by NXP did not function with this PCB. The problem has been solved after I bought a ST.
The panel has enough space to mount the alpha 9 or 16 mm pots.
 Filesize:  383.31 KB
 Viewed:  673 Time(s)
 Filesize:  354.36 KB
 Viewed:  701 Time(s)
steffensen
PostPosted: Mon Apr 29, 2013 2:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for the delay in reply here too. Smile
Nice looking builds! I thought you had the Ringmod in there as well, hence why i figured it was a tight build. Plenty of room here, great.
Just figured acrylic panels perhaps wouldnt be a bad idea. To avoid the locking between the VCO's especially.
Or - have you guys solved this in any other way?
It gets a bit disturbing at times when you DONT want sync to happen. Smile
noiselector
PostPosted: Mon Apr 29, 2013 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info about the CD4011 issue.
I am testing a separate board for waveshaper, ringmod and subosc.
I will share the layout when the testing will be finished.
I have built only one VCO and the only issue I noticed is when I put it in my grounded rack the VCO is detuned.
furio
PostPosted: Thu May 02, 2013 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello to all,
The BC847BPN improve the sound.
...32bit/96kHz (fm@saw & pwm@pw) test:
http://modular-synth.org/OLDfiles/OddyOSCprova.wav
Please note: in the PDF file I have marked the BC847BPN upside down.
steffensen
PostPosted: Thu May 02, 2013 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
furio wrote:
Hello to all,
I breadboarded the VCO some months ago, and tried a bunch of transistors. I fond that the 2N alternatives delivered the american raw ARP sound, while the BC ones made it more in to the realms of round Roland.
So, i wouldnt say it improves the sound, rather gives it a different tone.
furio
PostPosted: Thu May 02, 2013 11:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
steffensen wrote:
furio wrote:
Hello to all,
Hi steffensen,
I've noticed a marked improvement of the operation, rather than a difference in tone = the instrument results is more convincing to me.
In theory, the transistors 2N3904 and 2N3906 should be tended to more audiophile sound... I guess it's just a matter of thermal coupling and perhaps a work of this kind one might approach a similar result (photo).
I tried to make two adapter's with the recommended transistors & better tempcos = after comparing, the VCO with 2N3904/2N3906 expo converter seems to malfunction.
For years I used the dual version PCB by Andy and it was my favorite module... perhaps I would install two BC847BPN's also on them.
The tone changes a lot more by replacing the 2N5910 with a 2N3906... however, for a while I try the VCO with the 2N3906 instead the 2N5910, but I have no intention to replace the 2N5459's.
It disturbs me a lot more to run a celluar phone in standby mode in the studio for the damages arising in tone and operation, than the BC847BPN.
In any case, I like the Andy's idea to separate the dual VCO in individual modules. The single VCO improves drastically in sound and operation.
P.S. unfortunately I just destroyed my natural ADC and I have to fix it... I recorded with an ADC with integrated Pre-amplifier on which they are installed an array of AD8620's, these inject too much violence and obscure the detail.
steffensen
PostPosted: Fri May 03, 2013 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
furio wrote:
Hi steffensen,
Interesting.
I didnt do anything particular to my 2N3904/2N3906 expo converter, it just works great. I use a 1.87 tempco, which might have something to do with that tho.
What do you mean by operation? Is FM behaving better? Or something else?
I havent found a 2N5910 yet, but i think i have some on the way now (just hope they arent fakes).
I did however (for the 2N5910) try comparing the 2N3906 with the later used by ARP: 2N4125.
Made no difference in sound at all, but perhaps the latter one dont get heated as much. I didnt measure.
Using BF245 instead of the 2N5459 however made a difference for sure. (more in to the Roland realm i described above)
As said, mine is working great BUT the locking/syncing of the VCO's is disturbing. Its one thing if i have chose to use Sync, but if i havent i dont want it to happen. And there is no way to stop the Ground joining up thru the panel obviously.
This should be a problem with the original Odyssey as well imo, wonder how they solved that.. if this is the answer to stop the locking.
I cant be the only one experiencing this and wanting to find a solution?
furio
PostPosted: Fri May 03, 2013 2:06 am    Post subject: Reply with quote  Mark this post and the followings unread
I too believed for three years that my dual VCO was great... Though now it just works better... by giving a close ear I would say that the auto-sync could still be improved (I do not know how I should proceed to investigate technically and/or whether I have the suitable lab equipment... I only have a pocket oscilloscope with which I can almost see nothing).
noiselector
PostPosted: Fri May 03, 2013 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I think you could use Nomex paper for insulating the panel from the ground board trace as an easy solution ( or you can use Furio's acrylic panels).
Thanks a lot for sharing all your experiments with this VCO board, this threat is getting hot.
Wink
