JonTerp
Posted: Sun May 08, 2005 12:44 pm Post subject:
G1 and Windows XP? |
I am considering picking up a micro modular to play around with, and I noticed that on the Clavia site, it says the minimum requirements are Windows 95/98/NT4.0. I'm just wondering would I be able to run it on XP, and if I did, would I have any conflicts or complications. Some feedback right away would be nice, cause the auction is almost up. Thanks in advance.
Jon |
diskonext
Posted: Sun May 08, 2005 12:49 pm Post subject:
Got a fully working XP and MM setup here. No problems.
-diskonext _________________ :wq |
diskonext
Posted: Sun May 08, 2005 12:53 pm Post subject:
And good luck on the auction, the MM is sweet little box!
JonTerp
Posted: Sun May 08, 2005 1:02 pm Post subject:
| thanks diskonext |
diskonext
Posted: Sun May 08, 2005 2:47 pm Post subject:
No problem,
let us know whether you succeeded!
andy c
Posted: Mon May 09, 2005 1:03 am Post subject:
just remember to run the editor in 'compatibility mode' i pulled out a lot of hair finding that one out.
Andy C _________________ ::Now We Are six::
the new album by the glimmer room
out and available now |
egw
Joined: Feb 01, 2003 Posts: 1569 Location: Asheville NC
G2 patch files: 8
Posted: Mon May 09, 2005 4:47 am Post subject:
I've had no trouble using my micro with XP.
But I don't recall anything about "compatibility" mode. What's that? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Mon May 09, 2005 5:51 am Post subject:
Clicking on the Icon and choosing 'Windows 98 compatibility mode' makes it run more stable or run at all...
Wout |
Posted: Mon May 09, 2005 7:01 am Post subject:
Indeed, in my case the editor would only remember what ports to use when in compatibility mode. Just set it, it can´t harm that I know of. _________________ Kassen |
cappy2112
Joined: Dec 24, 2004 Posts: 2500 Location: San Jose, California
Posted: Mon May 09, 2005 1:24 pm Post subject:
Re: G1 and Windows XP? |
| JonTerp wrote: | I am considering picking up a micro modular to play around with, and I noticed that on the Clavia site, it says the minimum requirements are Windows 95/98/NT4.0. I'm just wondering would I be able to run it on XP, and if I did, would I have any conflicts or complications. Some feedback right away would be nice, cause the auction is almost up. Thanks in advance.
Jon |
Same here. I use XP too. I think I had a quirk a while ago, now I'm using Compatibility mode, and it works well.
Many posts come from XP users. |
Axiom
G2 patch files: 28
Posted: Mon May 09, 2005 1:29 pm Post subject:
I use my micromodular with XP without problems.
see ya _________________
Joined: Apr 03, 2004 Posts: 24542 Location: The Netherlands, Enschede
Audio files: 299
Posted: Mon May 09, 2005 4:59 pm Post subject:
| cappy2112 wrote: |
Same here. I use XP too. I think I had a quirk a while ago, now I'm using Compatibility mode, and it works well. |
For compatibility mode right click on the editor's executable file, select properties from the popup menu, select the compatibility tab then check "run this program in compatibility mode" and select "windows 98 / windows me"
The editor's executable normally is : "C:\Program Files\Clavia\Modular Editor 3.03\ModularEditor3_03.exe"
Jan. |
JonTerp
Posted: Tue May 10, 2005 2:30 pm Post subject:
| well, now the price has been pushed up to $305, which I'm thinking might be a bit much, especially since there is a G1 rack for the same on ebay right now. Maybe I'll just wait and get my G2 engine. |
egw
G2 patch files: 8
Posted: Tue May 10, 2005 6:54 pm Post subject:
| The G1 rack is a steal if you can get it for $300, unless there is something wrong with it. |
JonTerp
Posted: Tue May 10, 2005 9:03 pm Post subject:
| nope, but it still has a couple days left on it, so my guess is it will still go up alot. What should I expect to pay for a G1 rack? I can never make up my mind, I'm considering a G1 rack over a G2 engine just because I can get it for cheaper, and it has built in controlls. |
egw
G2 patch files: 8
Posted: Wed May 11, 2005 6:40 am Post subject:
| The G1 rack takes a lot of rack space, if that's an issue. The G2 engine will give you the reverbs, delays and sequencer midi out, plus a few other goodies. However with the engine you'll still need an external box to control it. So, it depends on how you want to use it and what other gear you have. |
