Connectors on XR2206 PCB
Page 1 of 1 [9 Posts]
infraxpert
PostPosted: Sun Jul 06, 2014 4:22 am    Post subject: Connectors on XR2206 PCB
Subject description: What hides behind the connectorcode on the XR2206 PCB from MagicSmoke
Does anybody know how to translate the different CN-codes into pots and plugs on the Magic Smoke PCB for the TH-102/XR2206 VCO?
If anybody have a connection manual it would be a great help.
Thanks
Danno Gee Ray
PostPosted: Sun Jul 06, 2014 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would recommend picking up a copy of the book an-analog-synthesizer-for-the-21st-century.
at this link http://www.lulu.com/shop/thomas-henry/an-analog-synthesizer-for-the-21st-century/paperback/product-20192513.html;jsessionid=8C896E5BB75FCE5A1BAF4A5C1BD0010B. The schematics are found there.
infraxpert
PostPosted: Sun Jul 06, 2014 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I already have the book but it does not show anything about the PCB from magic smoke. I also have the book about Thomas Henry VCOs and that one is even more confusing since it does not have one final layout for the VCO.
I just wonder course magic smoke refer to this forum for further documentation.
Rivelen
G2 patch files: 12
PostPosted: Sun Jul 06, 2014 10:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
so you did not received the wiring guide from Magic Smoke ?
-> ok, sent to you by pm.
rjd2
PostPosted: Sun Jul 27, 2014 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Good friend! Would you mind DMing me the connection notes please? I too cannot translate the cn codes on the pcb... Thanks!
AlasdairMoons
PostPosted: Sun Jul 27, 2014 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
okido, then I post my question here too ... in my wiring doc the TRI-SI DPDT switch AND the Hi-Lo siwtch is wired to CN 103 ..
is it possible that there is a fault and the DPDT TRI-SI Switch is wired to CN13 and CN14 ???
 Filesize:  26.77 KB
 Viewed:  9750 Time(s)
my Music-Channel:
my Facebook:
PostPosted: Sun Jul 27, 2014 8:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is correct. Here are some notes I have, not sure their exact provenance, but I believe they are from Tim, and they apply here:
If you're looking for a little more info on the board image I posted, here are the connector functions:
Left Edge:
CN7 Linear CV In jack
CN8 Linear CV attenuator
CN1 Coarse Tune
CN2 Fine Tune
CN101 FM 2 In jack
CN102 FM 2 attenuator
Top Edge:
CN105 Square Suboctave out
CN110 Pulse Suboctave out
CN108 PWM In attenuator
CN107 PWM In jack
CN106 PWM Initial
CN109 Pulse Out
CN104 Rampoid Out
CN15 Tri - Ramp / Sine Out
CN16 Square Out
Bottom Edge:
CN4 1V/Octave CV in (switching jack)
CN3 Keyboard CV in (from internal bus)
CN6 FM 1 In attenuator
CN5 FM 1 In jack
CN9 Skew Initial
CN10 Skew CN In jack
CN11 Skew attenuator
CN103 Hi / Low cap switch
CN12 Sync In
Middle:
CN13 S1a (Tri - Ramp / Sine Select switch)
CN14 S1b (Tri - Ramp / Sine Select switch)
Right Edge:
CN17 DC Power In (4 pin .156" Blacet style)
CN18 & CN19 DC Power In (6 pin .100")
Whew! Lotsa connectors. But we do have
* Tri -Ramp / Sine Out
* Pulse Out (derived from Tri - Ramp)
* Suboctave (derived from Pulse)
* Square Out
* Suboctave (derived from Square)
* Rampoid Out
* Two Expo FM Inputs with attenuators
* Linear CV Input with attenuator
* 1V/Octave CV Input
* Tri - Ramp Skew CV Input with attenuator
* PWM Input with attenuator
* Sync Input
AlasdairMoons
PostPosted: Mon Jul 28, 2014 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I reread the doc I got and did my wiring today .. something is wrong .. I just hear noise .. but anyway ..
my doc says
CN01 is fine and CN02 is coarse .. but from listening to the noise that must be wrong in my doc ..
and I do not understand the CN4 and CN3 connection ....
CN4 is a switched jack .. o.k. .. I did that
but how or where do I connect CN3?? Or do I not need it if I have no internal keyboard connected??
my Music-Channel:
my Facebook:
PostPosted: Mon Jul 28, 2014 7:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is exactly right. I am traveling and away from my el Cerrito, so I can't say specifically, but I do recall there was more than one connector that I opted not to use, and the internal keyboard one was definitely one of those.
As to the cause of noise, unfortunately I'm not sure what to suggest there. When I am back home this weekend, if you're still having issues I can measure voltages on mine and give you some ideas.
