yusynth
Posted: Fri Aug 08, 2014 3:18 am Post subject:
superb ! _________________ Yves |
sebsongs
Joined: Feb 09, 2013 Posts: 49 Location: Malmö, Sweden
Posted: Sun Aug 10, 2014 5:36 am Post subject:
Thank you very much mr Usson! |
dave the butcher
Posted: Mon Aug 11, 2014 9:05 am Post subject:
gorgeous !!!
drakfluga
Joined: May 09, 2012 Posts: 49 Location: Gothenburg SE
Posted: Thu Oct 23, 2014 5:19 am Post subject:
Hey there! Great looking build! I read through the thread and noticed you're in Sweden so I thought I'd say hello. I'm in Gothenburg myself, started building a Yusynth-based modular a few years ago. I shelved the project for a while due to lack of time (and funds) but now I'm up and running again, been sourcing components like crazy for the past month or so. I'm currently sitting with a finished Steiner VCF (old version), ADSR and a half-finished VCO, LFO1 and LFO2. Got about 10 more modules in the pipe I'm going to be working on during the winter, as well as the cabinet and power supply.
I've also started experimenting with an Arduino and DAC-based MIDI-CV-solution of my own design.
Anyway, great looking build, and inspiring to see a fellow Swede hooked on Yves' designs!  |
drakfluga
Posted: Thu Oct 23, 2014 5:30 am Post subject:
By the way, I have to ask, your panel design... What type of adhesive paper are you using? Can you elaborate on your process a bit?
I'm thinking of going the same route, it seems to be the easiest way as it will be pretty cheap and easy to replace and update panels if you want to add mods to modules or change the width etc.
I had originally planned on ordering professional panels but the cost skyrocketed fairly quickly and honestly it'd be pretty neat to have my own panel design anyway.  |
sebsongs
Posted: Wed Nov 05, 2014 2:16 am Post subject:
drakfluga wrote: | Hey there! Great looking build! I read through the thread and noticed you're in Sweden so I thought I'd say hello. I'm in Gothenburg myself, started building a Yusynth-based modular a few years ago. I shelved the project for a while due to lack of time (and funds) but now I'm up and running again, been sourcing components like crazy for the past month or so. I'm currently sitting with a finished Steiner VCF (old version), ADSR and a half-finished VCO, LFO1 and LFO2. Got about 10 more modules in the pipe I'm going to be working on during the winter, as well as the cabinet and power supply.
I had originally planned on ordering professional panels but the cost skyrocketed fairly quickly and honestly it'd be pretty neat to have my own panel design anyway. Wink |
A fellow synth building swede! Nice to hear from you!
Sounds like you got quite a project going, very much like me.
My modular has not had any new modules built in a while because I haven't been able to decide wether I'm going to keep my panel designs or go for new and better ones. I took on the challenge to learning how to silk screen, and the results so far has been quite pleasing. It is a slow process but very pleasing when it comes out good.
To answer your question: to make my current panels I have printed my panel design onto adhesive A4 paper, I use HERMA Premium No. 5065.
I got it at akademibokhandeln in my town.
I print two versions of my panel design: one that is the way I want it (in my case white graphics on black background) and one that is inverted. The inverted one I stick to my aluminum panel to use as a drill template. If you put small crosses in the center of every drill point in your design it then gets very easy to align the drilled holes with the front panel sticker.
I then cover the printed sticker (not the drill template, the one you're using for the actual panel) with an adhesive transparent plastic, the one you cover books with also. I managed to find a matte plastic, so the panels doesn't act as a mirror all the time. The print then becomes sealed, the blacks get darker and it can withstand more fluids and scratching.
Before I stick it to the panel I use hole punches to cut out all the holes for the jack sockets and pots.
You cannot drill trough the paper and plastic and get away with clean edges around the holes. The only way to get it nice and clean is to punch out the holes.
Then I drill the holes in my aluminum panel using the inverted drill template I printed out before. And lastly I stick the adhesive sticker to the aluminum panel and cut along the edges of the panel with a sharpie or razor blade to get a nice straight edge.
The trickiest part is to align the aluminum panel with the sticker. My trick is to tape the sticker to a window (in daylight) with the adhesive side away from the window. Then it is easy to align the holes in the sticker with the holes in the aluminum panel.
Another way to make the adhesive paper durable is to coat it with a couple of thin coats of clearcoat, preferably a matte one. I have done this and it comes out very good, but the adhesive plastic is as a faster method and it does not stink.
So you are making arduino-projects also? I am deep in the process of developing a arduino sequencer with some nice features. I will be posting a thread on that one when I have some results.
I have some ideas for more arduino modules also. The most important thing when using a 5V processor in a +-15V environment is to protect it! One will make a mistake sooner or later and the processor is smoked.
Look out for my new website on www.sebsongs.com. I'm in the process of making a whole new site that is more biased towards synths and electronics. Hopefully I will launch the site very soon. |
01012k7
Posted: Mon Mar 21, 2016 4:38 pm Post subject:
I decided to make my Yusynth smaller but decided to make a smaller as a desktop synth I also adding a mixer and a 8 step sequencer boards are almost made but lots to wire up should be a few months
Description: |
Filesize: |
3.7 MB |
Viewed: |
314 Time(s) |
Description: |
Filesize: |
3.42 MB |
Viewed: |
327 Time(s) |
