diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Tue Jan 28, 2014 5:23 pm Post subject:
Hi Matthias been awhile since any news on this one
definitely interested in euro version pcb's main and panel control if you have any coming up. _________________ In an infinite universe one might very well
ask where the hell am I
as good an answer as any |
Posted: Tue Jan 28, 2014 11:09 pm Post subject:
i am working on it. the new layout gives me some headaches, though. it might be necessary to connect the circuit PCB and the controller PCB with ribbon cables... _________________
Tech Buddy at Random*Source |
mcop
Posted: Wed Jan 29, 2014 12:04 am Post subject:
I've been wondering this too. Good to hear it's still going.
I've been playing with a homebrew 4024 divider connected to either the Barton VCA/Mixer or a matrix mixer and having loads of fun with the sequencing and chopping up possibilities so definitely up for this when it's ready. |
diablojoy
Posted: Wed Jan 29, 2014 2:30 pm Post subject:
| Quote: | | it might be necessary to connect the circuit PCB and the controller PCB with ribbon cables... |
yes good to hear its still going
ribbon cables hmm not quite as nice as the usual headers but if things just wont line up right then so be it ,
had to do something similar with one of hexinverters postman EG's
last weekend (16HP euro panel) I etched a single layer panel board for it so no way could i line it all up for headers , so lots of cabling all running through 3 x 10mm holes in the panel board , couldnt go round the outside too close to the panel size. It didnt save me any cabling but it did suit the 9mm pots i had on hand and made board mounting a whole lot easier. _________________ In an infinite universe one might very well
Joined: Jan 07, 2009 Posts: 1223 Location: Scottish Borders
Posted: Thu Jan 30, 2014 3:03 am Post subject:
I'm still very keen for 2 of these as well (pcb only for my blue system )
Dave. |
Posted: Thu Jun 12, 2014 10:00 am Post subject:
Hello Matthias.
Are you still thinking of doing a small run of these binary boards ?
I'm still very interested in 2 pcb's only , if you decide to do some.
Thanks
Dave. |
Posted: Thu Jun 12, 2014 11:04 am Post subject:
i hear you, dave.
the project is postponed due to lack of time/priorities. but it is not dead, i still plan to do it. i just don't have the time right now. _________________
Posted: Mon Jun 16, 2014 4:34 pm Post subject:
cool , I will save a space for it  |
diablojoy
Posted: Fri Jun 20, 2014 3:16 am Post subject:
hmm cant save any space in my small euro case now but I will make some space when it comes out, just means another case  _________________ In an infinite universe one might very well
bubzy
Joined: Oct 27, 2010 Posts: 594 Location: United Kingdom
Audio files: 64
Posted: Mon Dec 22, 2014 8:21 am Post subject:
hey Matthias,
did you find the time/motivation to continue with this yet?
 _________________ _Richard_  |
Posted: Mon Dec 22, 2014 8:49 am Post subject:
| bubzy wrote: | hey Matthias,
no, but i could upload the new schematics? _________________
Posted: Mon Dec 22, 2014 9:27 am Post subject:
YES PLEASE
I saved a panel just for this
Thanks in advance, Matthias.
Dave. |
bubzy
Audio files: 64
Posted: Mon Dec 22, 2014 5:19 pm Post subject:
yes please that would be awesome, thanks matthias _________________ _Richard_  |
Posted: Tue Dec 23, 2014 3:48 am Post subject:
Thanks Matthias.
need to source an encoder & max313cpe then the breadboard comes out.
Was there a particular number of notches / pulses rotary encoder you had thought about using ?, I have never wired one up before but im sure it will be easy .
(starts to read "rotary encoders for dummies")  |
Posted: Tue Dec 23, 2014 4:06 am Post subject:
| Skrog Productions wrote: | Thanks Matthias.
since this is an 8 bit system we have 254 possible stages. and if you wanted to 'move' to a paticular stage (i.e. for mixing purposes) you don want to use a momentary switch. it would be boring to push that button 250 times, no?
so i just wanted to wire the encoder as a 'rotary momentary' switch (or on/off). the rising edge of each encoders gate will then converted to a short pulse, triggering the divider IC.
so no special requirements on that encoder, it just has to be an incremental one IIRC. _________________
Posted: Tue Dec 23, 2014 4:23 am Post subject:
absolutley. _________________
Posted: Tue Dec 23, 2014 4:32 am Post subject:
Magic , thanks  |
Posted: Tue Dec 23, 2014 7:42 am Post subject:
DG411 is 'NC' (normally closed), whereas the MAX313 or DG412 is 'NO' (normally open).
so you could use a DG412. the MAX313 is just newer, faster, with less on resistance. _________________
mcop
Posted: Tue Dec 23, 2014 7:50 am Post subject:
| Excellent, been waiting to see where this went. Thanks for sharing the schematic. |
Posted: Tue Dec 23, 2014 8:02 am Post subject:
i still hope to do a set of PCBs for this  _________________
Posted: Tue Dec 23, 2014 8:03 am Post subject:
hope dies last. _________________
Posted: Tue Dec 23, 2014 8:11 am Post subject:
Thanks for your help Matthias, i'll get a couple of DG412dj chips for the test layout and decide from there .
Have a great Xmas.
Cheers.
Dave. |
