today> Twyndyllyngs Chez Mosc
Racking my G1
Page 1 of 1 [10 Posts]
BobTheDog
PostPosted: Thu Mar 10, 2011 11:55 pm    Post subject: Racking my G1
Subject description: What size screws?
Hi Guys,
I have the rack ears for my G1 but no screws to connect the ears to the G1.
Can anyone help me out with what size/type screws to use.
Andy
cappy2112
PostPosted: Fri Mar 18, 2011 12:10 pm    Post subject: Re: Racking my G1
BobTheDog wrote:
Hi Guys,
Andy
I bought a pack of "rack screws" at a music store, if I can find the pack I'll post the information. These are a standard thread size though. Try asking at a music store that sells lots of rack gear. Chances are they may sell the screws.
BobTheDog
PostPosted: Fri Mar 18, 2011 4:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I ended up just trying out a variety of screws from the 'leftover' screw box and managed to find 4 screws that did the business.
rowett
PostPosted: Wed May 25, 2011 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
where did you get your rack ears? could i maybe use ones made for the Nord Lead Rack, or perhaps some generic rack hardware?
Redline
PostPosted: Thu Mar 20, 2014 5:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I had the same trouble - 6/32 UNC bolts seem to work OK.
I'm not totally sure if this is 100% correct to whatever would have been supplied originally but they seem to work OK on mine. You need to make sure the bolt heads are wide enough not to slip through the ear mounting holes, or use washers of course.
crawling wind
PostPosted: Wed May 28, 2014 6:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I need rack ears also! There must be a solution.
BobTheDog
PostPosted: Fri May 30, 2014 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I got my G1 off ebay and it came with them.
crawling wind
PostPosted: Tue Jun 03, 2014 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I took Dave Peck's advise from another thread and used a rack shelf that I had in the garage. It's slightly too wide but will serve my purpose. Good one, Dave!
Jack_Hertz
Audio files: 101
G2 patch files: 7
PostPosted: Wed Jan 21, 2015 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey hey! Good news. I found a cheap and somewhat easy replacement for only $4. Home Depot sells these building construction ties that worked nicely: http://www.homedepot.com/p/Simpson-Strong-Tie-GA2-18-Gauge-3-1-4-in-Gusset-Angle-GA2/100375243
After a bit of drilling and fidgeting, I got them work quite well. See my image below of two Racks in the case.
Hope this helps you!
Jack's Rack Hack
 Filesize:  1.78 MB
 Viewed:  605 Time(s)
Jack Hertz.com | Aural Films
crawling wind
PostPosted: Tue Feb 10, 2015 11:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sweet! Thanks for the link.
