Moog EP-3 Expression Pedal - Does it fit with the G2X?
Page 1 of 1 [7 Posts]
BigShort
PostPosted: Thu Mar 12, 2015 8:49 am    Post subject: Moog EP-3 Expression Pedal - Does it fit with the G2X? Reply with quote  Mark this post and the followings unread
I would really like to buy this unexpensive Controller/Expression Pedal. All what i read about was very impressing:
http://www.moogmusic.com/products/accessories/ep-3-expression-pedal
High quality universal expression pedal for keyboards, synthesizers, and instrument pedals with external polarity switch, output level knob, and included 6.5’ cable.High quality universal expression pedal for keyboards, synthesizers, and instrument pedals with external polarity switch, output level knob, and included 6.5’ cable.
http://www.musicstore.de/de_DE/EUR/Ratings/Comments/ratings-SYN0004509-000
Das Moog Expression Pedal EP-3 wird härtesten Anforderungen gerecht. Durch die neu konzipierte Hebemechanik lässt dich das Pedal sehr ausdruckstark spielen. Der Polaritätsschalter macht das Pedal kompatibel zu fast jedem Hersteller von Keyboards mit Expression oder CV Eingang und macht es zu einem idealen Begleiter der Mooger- und MiniFooger. Ein abnehmbares Kabel unterstreicht mal wieder durchdachtes Design und Funktionalität aus dem Hause Moog.
Features:
Extrem robust, 6,3 Klinkenausgang an der Frontseite, Potentiometer zur Regelung des Outputs, TRS - TRS Kabel im Lieferung enthalten, Gewicht ca. 1,2 kg
I hope anybody use it allready and can write about his experience or anybody else could give some hints for another goodone.
I would like to controll all what i can do with the modwheel and the volume if its possible.
Thx in advance
BobTheDog
Audio files: 32
PostPosted: Tue Mar 24, 2015 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have a couple of these, they have worked with everything I have tried them with. I will connect one up to the G2 tomorow and get back to you....
BigShort
PostPosted: Wed Mar 25, 2015 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ohh thank you Bob, that would be really nice from you, many thx for your effort
BobTheDog
Audio files: 32
PostPosted: Thu Mar 26, 2015 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whoops, sorry I forgot. Will give it a go tomorow. In my reminder list now!
BigShort
PostPosted: Thu Mar 26, 2015 9:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
no problem Bob, take your time! I'm happy getting replays of just one of this fantastic community, hehe
BobTheDog
Audio files: 32
PostPosted: Fri Mar 27, 2015 3:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I have two of these pedals.
I tried one and it was all over the place, very wonky.
Then I tried the second one I have and it worked fine, I attached a ctrlsend module and the range was good from 0 - 127 and control of params was smooth.
So I guess they work fine and one of my pedals is bust, it's been stuck in a box with loads of other crap for a while so maybe something has happened to it.
They are not the most robust pedal and are very light so they move around a bit, and they have a bit of a ratchet type noise when you use them but they are cheap!
BigShort
PostPosted: Fri Mar 27, 2015 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Bob,
many thanx for your fast test & answer. Sorry for your very wonky piece, that is not nice.
Your comment "Then I tried the second one I have and it worked fine, I attached a ctrlsend module and the range was good from 0 - 127 and control of params was smooth." sounds very promising and helpful.
I don't understand that your EP 3 is very light, it should be 2.6 lbs or 1.15 kg, it's heavier than others. Look at this comparisation chart:
http://www.thomann.de/gb/search_compare.html?art[]=102890&art[]=102920&art[]=129443&art[]=195660&art[]=114986&gk=TAKYVP&kf=on&oa=ala&pc=show
The ratchet type noise is maybe repairable with a bit oil or nonfluid oil. Did you try it?
But anyway, i should give it a try..
Many thanx Smile
