NM1 editor problem - out of memory
Page 1 of 1 [2 Posts]
VON
PostPosted: Sun Apr 05, 2015 2:05 pm    Post subject: NM1 editor problem - out of memory
Subject description: out of memory
Hi everybody...I'm running the NM editor 3.03 on Windows XP. It has always worked well..but lately it does not connect via midi about the problem called: out of memory (see the attachment). Laptop works exclusively with the editor - there are no other programs installed - so is impossible that it is without memory. I have two NM (normal and rack version) and in both cases the problem happens!
any suggestions?
 Filesize:  138.93 KB
 Viewed:  4177 Time(s)
PostPosted: Mon Apr 06, 2015 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I've seen that message too on occasions .. but not using XP anymore ... you could try to fiddle with compatibility modes for the editor executable.
