Arduino wavetable synthesis: Implementing an envelope.
Page 1 of 1 [3 Posts]
mubase
PostPosted: Sat Apr 25, 2015 5:19 am    Post subject: Arduino wavetable synthesis: Implementing an envelope. Reply with quote  Mark this post and the followings unread
Hi everyone. Smile
I am going a bit nuts trying to implement a simple decay to a wavetable synth I am working on using an ATXmega board and the Arduino IDE.
I can output a sine wavetable through the DAC quite easily. I use a calculated wavetable in an array of 256 values with a maximum value of 4095 as the DAC is 12 bits.
I can then use an accumulator and phase incrementer to get a wide frequency scale.
The output from the dac is done inside a timer overflow IRQ with a sample rate of around 31250Hz.
I would like to know how to implement an envelope. A simple decaying envelope to start with. So, say, I press a button and on button press detect, start the sound and decay. I want to do it using another wavetable containing a simple ramp wave to start with. Can some one explain to me how I would go about this?
The basic snippet of code that is playing the wave looks like this:
Code:
 accumulator += accumulatorSteps; /* advance accumulator */
      waveStep =( accumulator>>8);
output=(sine[waveStep]);
dac.write(output);//*decay[d]));
accumulator steps is the value of the frequency.
Thanks,
Steve>S
There's a crack in everything...Thats how glue manufacturers make a living.
PostPosted: Sat Apr 25, 2015 10:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Multiplication Smile
Seriously; you'll need to scale the result appropriately, but that's really what is going on.
PS: Make sure you use integer math as much as possible; probably would want to pre-scale your wavetables.
mubase
PostPosted: Fri May 01, 2015 4:51 am    Post subject: Arduino wavetable synthesis: Imple.. :SOLVED Reply with quote  Mark this post and the followings unread
Hi Elmegil. Very Happy
Yep. Thanks. My problem was scaling.
All working well now.
Also, I've migrated from xmega to stm32f4 on Arduino IDE. So much faster and nicer.
I'm now doing experiments with rudimentary (and i say RUDIMENTARY) synchronous granular synthesis. Smile
