Nord micro modular
Page 1 of 1 [6 Posts]
JeEA
PostPosted: Sun Sep 27, 2015 6:33 am    Post subject:  Nord micro modular
Subject description: Nord micro modular not respondent to midi in notes...Well it does
Hi All
I am new to this forum
I just bought a micro modular which does not respond to midi in.
It does respond to programming so the problem is not the pc-midi in.
However it does not respond to keyboard notes.
What Can i do?
Hope anyone herre has an idea.
Jens
Audio files: 297
PostPosted: Sun Sep 27, 2015 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Welcome Jens,
just to make sure:
The midi channel is set correctly and midi reception is enabled as well?
Also MIDI must be routed to the modules, by either using the keyboard tracking etc. or explicit routing from a note in module can be used as well.
JeEA
PostPosted: Sun Sep 27, 2015 11:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks
Well I assume that, but I have to check. I bought it A's defect
I guess the seller know how to use it, but I'll get back to You
Asap
I should receive it tuesday. Then I Can test it and get back to You.
I shure hope it can be fixed. If not I could probably trigger
the sequencer via audio input and still be able to use it.
Audio files: 297
PostPosted: Sun Sep 27, 2015 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah ok ... never had one broken so cant really tell .. was jut making sure about the setup as its easy to forget something there.
JeEA
PostPosted: Tue Sep 29, 2015 10:17 am    Post subject:   Reply with quote  Mark this post and the followings unread
Well
Here are some news. Just Got the beast today by mail and hooked it up to my yamaha EX7
and it responds to midi in! I was told it had a defect midi in and did not respond to midi in. Therefore i Got it cheap.
It responded Nicely to my keyboard.
So i have a full functioning MM
Jens
Audio files: 297
PostPosted: Tue Sep 29, 2015 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Great!
