linked event sequencers not reseting when restarting MPC
Page 1 of 1 [4 Posts]
asciibaron
PostPosted: Sat Oct 24, 2015 3:23 pm    Post subject: linked event sequencers not reseting when restarting MPC Reply with quote  Mark this post and the followings unread
i'm using an MPC 2000XL as my main sequencer/master MIDI clock. i am trying to create a patch that has two linked event sequencers to get a 32 step sequence. i can start the sequncers and everything is fine. i stop the MPC and the sequencers stop, but when i start the MPC from the top beginning of the sequence, the event sequencers do not start on step 1, they continue from their current position.
if i connect the rst to sync both sequencers run at the same time, but i do get the behaviour i am looking for with regard to the restarting at step 1.
notice that both sequencers have step 4 lit.
i must be doing something wrong, but i have no idea. anyone know what the solution is?
 Filesize:  53.61 KB
 Viewed:  4223 Time(s)
event_seq_link.pch
 Filename:  event_seq_link.pch
 Filesize:  1.67 KB
 Downloaded:  300 Time(s)
Null Wave
PostPosted: Sat Oct 24, 2015 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey,
Make sure both sequencers have 32 steps,
but most important of all,
Instead of linking CLK of your first sequencer to SYNC, link it to ACTIVE.
The problem should be solved then.
Cool
asciibaron
PostPosted: Sat Oct 24, 2015 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Null Wave wrote:
Hey,
Cool
thank you. works perfectly now.
PostPosted: Sat Oct 24, 2015 5:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Glad that got solved (again, those bloody sequencers .. Shocked ) Cool
And welcome and wolkom asciibaron and Null Wave.
