today> Twyndyllyngs Chez Mosc
EFM VCF 4622 Moog Taurus type Transistor Ladder
Page 1 of 2 [29 Posts]
jbeuckm
Audio files: 9
PostPosted: Tue Dec 08, 2015 10:32 pm    Post subject: EFM VCF 4622 Moog Taurus type Transistor Ladder Reply with quote  Mark this post and the followings unread
This layout is verified. The cutoff pot should be connected to -12v instead of ground to completely close the filter.
Files: https://github.com/jbeuckm/EFM_VCF_4622
(image updated with the fix now)
isak
PostPosted: Mon Dec 14, 2015 11:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you vey much Smile
Sebo
PostPosted: Sun Dec 27, 2015 10:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for sharing!!!
Sebo
My Music:
isak
PostPosted: Mon Jan 04, 2016 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi jbeuckm.
Did you built this board?
I found an intetesting post about the 4622:
http://electro-music.com/forum/topic-26994-0.html&postdays=0&postorder=asc&highlight=
Maybe it will be worth checking Wink
jbeuckm
Audio files: 9
PostPosted: Mon Jan 04, 2016 9:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I built one to test the general layout, but the one on Github is modified a lot since then. It worked, but the early layout needed a kludge to get -12v to the freq pot. I need to verify the newer version soon.
isak
PostPosted: Mon Jan 04, 2016 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Let me know how it went Smile
Cheers Smile
jbeuckm
Audio files: 9
PostPosted: Sat Jan 16, 2016 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Latest version v0.2 works. I fixed the -12V frequency pot thing, moved things around some and moved the CV+Q+F pots slightly further apart so they aren't jammed in.
 Filesize:  160.14 KB
 Viewed:  660 Time(s)
LFLab
PostPosted: Sat Jan 23, 2016 2:09 am    Post subject: Reply with quote  Mark this post and the followings unread
While at lunch break the other day, I added the Taurus VCA to this (you still have another ota in the lm13700).
I have a github account, just can't figure out how to create repositories for my stuff. Will share when i can get github going.
bamboombaps
PostPosted: Mon Jan 25, 2016 3:42 am    Post subject: Reply with quote  Mark this post and the followings unread
let me know when you do id like to have a look
jbeuckm
Audio files: 9
PostPosted: Mon Jan 25, 2016 8:34 am    Post subject: Reply with quote  Mark this post and the followings unread
LFLab - that would be excellent. Git has a learning curve but it's the perfect way to work on this stuff. Here is a good way to proceed with your addon:
-- Log in to Github.
-- Go to my repository and "fork" it. This makes a copy into your Github account. There is a "fork" button in the upper right of the Github page.
-- "Clone" the new repository onto your computer. This requires some kind of Git client software - you might use Github's client or install the command line version of Git (I show some example command lines below).
[git clone git@github.com:lflab/EFM_VCF_4622.git]
-- Overwrite the downloaded schematic and board files with your new ones.
-- "Commit" the new files with Git, adding a message to describe the changes.
[git commit -a -m "added Taurus VCA"]
-- "Push" back up to Github to publish your results.
[git push origin master]
At that point your Github account will hold the updated version. If you wanted to, you could submit a "pull request" to tell me (publisher of the original repo that you forked) that your update is ready to incorporate into the original repo.
Here is a helpful Git tutorial: https://try.github.io/levels/1/challenges/1
LFLab
PostPosted: Wed Jan 27, 2016 1:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, I'd already created my own Github repo's.
I installed Github Desktop, and if I open a repo, I can see the contents, but I can't seem to be able to publish them, I get a "failed to sync" error, saying that the repo needs to be debugged. To be honest, it could be the firewall I am behind at work, I'll take my pc home and retry.
But I am staying away from commandlines and such, if there's something handy as dropbox, which works great (I do appreciate revision control, it's a major part of my work, but for small projects like this, well, maybe it's more trouble than it's worth).
This is what I have now:
Double sided, the red dotted outline is a ground plane (it shows fully red after pressing the rats nest button, but I find that's not helpful when checking the routing)
jbeuckm
Audio files: 9
PostPosted: Thu Jan 28, 2016 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool LFLab!
Warning: I drew the Erthenvar jacks and they are not tested for manufacturing. I would like to have used slots, but I use overlapping holes because that's what the "pcbgcode" ULP can handle and it works on my CNC router.
LFLab
PostPosted: Fri Jan 29, 2016 1:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, those slots did have me wondering, and I don't think iTEAD allows milling contours, figured I can always take a needle file and open up the two holes.
jbeuckm
Audio files: 9
PostPosted: Fri Jan 29, 2016 7:18 am    Post subject: Reply with quote  Mark this post and the followings unread
If they do allow overlapping holes, these three work perfectly well with no manual adjustment.
I tried to overlap .04" holes but kept breaking the bit, so these are .052
n.d
PostPosted: Fri Feb 12, 2016 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I`m somewhat lost. Is the VCF+VCA version available?
If so, is it tested?
LFLab
PostPosted: Sat Feb 13, 2016 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Build one and find out! Do you have experience? Shouldn't be too hard.
n.d
PostPosted: Wed Feb 17, 2016 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
LFLAB: yes, I have experience.
What I meant to ask is if the layout is available.
If i get to be the first builder, I`ll gladly share my experience with everybody.
LFLab
PostPosted: Thu Feb 18, 2016 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Eagle files EFM4622
Here are my Eagle files, keep us updated on your progress.
LFLab
PostPosted: Thu Mar 03, 2016 2:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey n.d., are you managing to build this thing?
masterofstuff124
PostPosted: Sun Apr 24, 2016 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
planning on building one of these Up. LF labs looks like its missing several connections and ground. some of the components are not connected to anything. So ill most likely build the original. Ill also just etch it instead of getting many boards made.
LFLab
PostPosted: Sun Apr 24, 2016 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's because it has a groundplane, which is not shown in the picture for clarity). Very Happy
Let me know if you'd like the eagle files.
masterofstuff124
PostPosted: Sun Apr 24, 2016 4:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
is it just the same file that you posted earlier? i was looking at that one in eagle.
LFLab
PostPosted: Sun Apr 24, 2016 10:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, yes, I posted it earlier. I have changed some things, added trimmers for self resonance (based on frequency centrals raging bull).
I'll upload the latest version tonight.
Regarding the ground plane, push the rats nest button in eagle and it should be filled in.
Edit: Updated files in my dropbox!
Eagle files EFM4622
LFLab
PostPosted: Sat Jul 29, 2017 5:51 am    Post subject: Reply with quote  Mark this post and the followings unread
And so, more than a year later, I shuffled some components, added a two pole connection and some holes so a daughterboard can be added to also have the two pole output available. And, I finally ordered some boards!
Did anyone else?
I can put the Eagle files in my dropbox once more, I've given up on Github.
n.d
PostPosted: Sun Aug 13, 2017 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi LFLab. Notification on your reply never came. I'll build it as soon as I can. Sorry.
Edit: if you can, upload the new design please.
