samp
Posted: Sat Oct 15, 2016 7:48 am Post subject:
How to Wire Keyboard to 555 Timer? Subject description: Triggering an Oscillator With a Keyboard |
I have recently ripped the keyboard out of an old Kawai organ and would like to use it as a part of this circuit (see attached).
I understand how this circuit is played with a stylus from the 555's pin 3 out, but am having trouble replacing this with the organ keyboard (see photos). I've tried connecting the bus (green wire?) to pin 3 and a single key's wire to pin 2, but with no results.
Is this something to do with CV?
Any suggested schematics/links would be appreciated.
Thanks,
Sam
| Description: |
| Filesize: |
675.47 KB |
| Viewed: |
837 Time(s) |
| Description: |
| Filesize: |
149.5 KB |
| Viewed: |
685 Time(s) |
| Description: |
| Filesize: |
163.23 KB |
| Viewed: |
651 Time(s) |
Joined: Aug 08, 2009 Posts: 1082 Location: Out scouting . . .
Posted: Sat Oct 15, 2016 2:50 pm Post subject:
[removed for personal reasons] Last edited by MusicMan11712 on Tue Nov 15, 2016 10:18 pm; edited 2 times in total |
gdavis
Posted: Sat Oct 15, 2016 5:59 pm Post subject:
Did you meter the keyboard to see if it actually works the way you think?
Assuming it actually connects one wire for each key to a bus wire, you'd need to connect the key wire to is corresponding pad in your circuit instead of pin two. Each pad creates a different resistance between pins 2 and 3 which controls the pitch. Connecting it directly to pin 2 eliminates all the resistance so the pitch is probably above the audible range. _________________ My synth build blog: http://gndsynth.blogspot.com/ |
samp
Posted: Sat Oct 15, 2016 8:42 pm Post subject:
| Thanks for your help! I'll have a look. |
Cfish
samp
Posted: Mon Oct 17, 2016 7:47 am Post subject:
Woo! Got it working! Thanks Cfish -nice synth by the way.
Turns out the first two keys I was testing are broken.
Definitely going to try the bass pedals next. |
