today> Twyndyllyngs Chez Mosc
All the patches are panned approximately 75% to the right.
Page 1 of 1 [6 Posts]
youshoudbdansin
PostPosted: Tue Dec 13, 2016 12:48 am    Post subject: All the patches are panned approximately 75% to the right. Reply with quote  Mark this post and the followings unread
Good mornig to all. New Andromeda user here, so this may be something simple, I hope Smile I have to turn the pan pot 75% to the left to hear the patch centered. Same thing happens both from the phone and L/R output
sunny pedaal
Audio files: 12
PostPosted: Fri Dec 16, 2016 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
start with an default patch with all effects off.
if still so , the outputboard might be broken.
youshoudbdansin
PostPosted: Sun Dec 18, 2016 5:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info:-) I tried that, the problem remains. I'm afraid it's a hardware problem
sunny pedaal
Audio files: 12
PostPosted: Sat Jan 07, 2017 6:51 am    Post subject: Reply with quote  Mark this post and the followings unread
a good technician can repair it ( with the help of the servicemanual
also probably the individuel voices out will work without problem ?
youshoudbdansin
PostPosted: Tue Jan 10, 2017 8:52 am    Post subject: Reply with quote  Mark this post and the followings unread
The individual outputs and the AUX work fine. All 16 voices tested OK. I have already sent it to a technician. Waiting for the verdict Smile
sunny pedaal
Audio files: 12
PostPosted: Tue Jan 10, 2017 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Let us know the outcome, good luck
