adnauseam
Joined: Mar 27, 2013 Posts: 147 Location: Manitoba, Canada
Posted: Fri Jan 10, 2014 9:00 am Post subject:
USB MIDI to Legacy MIDI via Arduino |
So check this out:
Interfacing MIDI devices with Arduino using USB Host Shield
With a bit of fiddling you could potentially look at MIDI data coming from any USB only MIDI device and adapt it to sent standard midi out to any other device. This means you could use your korg nano products, usb only midi controller, perhaps even the OP-1 as a device for legacy midi devices.
This approach seems promising to anyone who has the time to tinker. Currently the only decent available USB-> MIDI device (by iConnectMIDI I think?) is approaching $200.
What I read in the comments section is that one problem you may encounter is the voltage levels of the shield may not be large enough for some bus powered usb devices. This coould be explored.[/url] |
Joined: Aug 08, 2009 Posts: 1082 Location: Out scouting . . .
Posted: Fri Jan 10, 2014 4:07 pm Post subject:
[removed for personal reasons] Last edited by MusicMan11712 on Tue Nov 15, 2016 10:25 pm; edited 1 time in total |
adnauseam
Posted: Fri Jan 10, 2014 4:32 pm Post subject:
I got a little bit excited and ordered an Arduino with some USB and midi din jacks. well see how it goes in a few weeks  |
Posted: Sat Jan 11, 2014 9:57 am Post subject:
adnauseam
Posted: Sat Jan 11, 2014 10:58 am Post subject:
Quite pricey! I purchased some USB to serial adapters for about 2 bucks each. they convert USB date into serial data with no setup our drivers for the arduino |
cappy2112
Joined: Dec 24, 2004 Posts: 2494 Location: San Jose, California
Posted: Fri Feb 21, 2014 12:52 am Post subject:
adnauseam wrote: | Quite pricey! I purchased some USB to serial adapters for about 2 bucks each. they convert USB date into serial data with no setup our drivers for the arduino |
Would you post the link for those adapters? _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
adnauseam
Posted: Fri Feb 21, 2014 1:20 am Post subject:
Arduino USB |
So I got mine in the mail a few days ago..
They're Mini A usb connectors. Bummer
Most devices will have Standard USB B (or sometimes USB A)at the instrument end (that's the more square, robust connector) and Standard USB A at the other end (the more rectangular, annoying connector)
So It was my fault for buying an item with a poor description and a bad photo (and also not enquiring).
They're still available on ebay for cheap, though.
*** Disclaimer: I haven't tried either of these as the ones I ordered weren't what I wanted. ***
USB A
USB B (the larger one)
I have ordered a few of the first ones. I have the most of these cables available. I plan to first try it out with my Korg NanoKontrol and later my Behringer BCR2000 |
gdavis
Posted: Fri Feb 21, 2014 11:51 am Post subject:
The difference between the "expensive" shield and the "cheap" usb to serial converter is that the shield acts as a host which can enumerate connected devices while the converter can only act as a device which must be connected to a host.
Most midi controllers are usb devices, not hosts, and will need to be connected to a host to operate.
I don't mean to be a downer, but I don't think the simple usb to serial converter is going to allow you to connect to midi controllers, you need the host shield. _________________ My synth build blog: http://gndsynth.blogspot.com/ |
adnauseam
Posted: Fri Feb 21, 2014 12:06 pm Post subject:
USB Host |
I was thinking this...
That was always the downside of USB, iirc.
I guess we'll find out soon enough  |
cappy2112
Posted: Fri Feb 21, 2014 12:10 pm Post subject:
Re: Arduino USB |
adnauseam wrote: | So I got mine in the mail a few days ago..
USB A
BTW- the Arduino 2560 ADK has both host & target USB implemented.
It costs more, but you get a lot more program & data memory, IO pins, serial ports, HW interrupt pins. _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
elektromeister
Posted: Wed Jan 11, 2017 12:29 pm Post subject:
Anynody managed to get more then one USB devices like AKAI onto his Arduino?
What is required to do that?
I need a solution to obtain data from any MIDI Controllers, like also flute and saxophone into an electronic device. Next to Controllers like lauch pads.
I wonder how it is possible to analyze them? I expect them to have all their different MIDI Protocol, or? _________________ music is the key |
Joined: Nov 23, 2015 Posts: 1317 Location: Netherlands
Posted: Wed Jan 11, 2017 1:57 pm Post subject:
Google for Hiduino, this is where your arduino (UNO) turns in a native !!! MIDI device, so your computer will see the arduino as a MIDI device.
And HERE you can even rename your Hiduino (give it a name that makes sense) |
gdavis
Posted: Wed Jan 11, 2017 2:27 pm Post subject:
To connect to a MIDI controller the Arduino needs to act as a USB host, not a USB device (the MIDI controller is the USB device). Uno doesn't have the hardware to act as a host, I think some others might.
I was just reminded that there is an Arduino USB host shield available. That might work. It refers to a USB host library. Hmmm, I must look into this.... _________________ My synth build blog: http://gndsynth.blogspot.com/ |
Spikes
Posted: Sat Jan 28, 2017 5:22 pm Post subject:
I've built a USB MIDI to standard MIDI converter using that host shield and an Uno.
Works fine.
There is a library and examples so used that as a base.
There is a bidirectional example which no-one seems to have got working.
In my case I got a USB keyboard for playing a diy synth, that was fine but then the synth could only be used with a USB keyboard so added standard MIDI, easy to do and now can use either.
After that feature creep set in..... |
