VCO 12V build
Page 1 of 1 [10 Posts]
Warung
PostPosted: Wed Jun 28, 2017 12:31 am    Post subject: VCO 12V build Reply with quote  Mark this post and the followings unread
Hello Im just a very beginner trying to build my first VCO. Can someone explain me what are these connections shown in the picture of pcb components? As i guess the upper one is just connector for supply line (socket type?) and what is the bottom one?
 Filename:  12V.bmp
 Filesize:  2.73 MB
 Downloaded:  521 Time(s)
translucent
PostPosted: Wed Jun 28, 2017 3:25 am    Post subject: Reply with quote  Mark this post and the followings unread
When building it for 12 Volt, you can fit a connector in order to connect the board to a Eurorack standard power bus (see also https://www.sdiy.info/w/Eurorack)
gdavis
PostPosted: Wed Jun 28, 2017 6:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
There are three different types of power connectors commonly used in modular synths (MOTM, DOTCOM and Eurorack IIRC?). The PCB includes pads for all three so you have the option of choosing which ever one you want. Your top box actually surrounds the pads for two different connectors. The lower box is a Eurorack style power connector which is normally +/-12V as Translucent mentioned. I think the other two are usually +/-15V, but there's nothing stopping you from using them for +/-12V other than you'd be defying convention which may lead to some confusion down the line.
Warung
PostPosted: Thu Jun 29, 2017 12:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Found the connection. Can someone tell me what wattage resistors i should use?
translucent
PostPosted: Thu Jun 29, 2017 3:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Looking at the schematics I would say it doesn't matter, except for R1 and R2 that will have somewhat higher current flowing through them, so you may choose .5 or .6 watt resistors there to be on the safe side.
Warung
PostPosted: Mon Jul 10, 2017 10:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Does polyester and mylar film capacitors are the same?
wackelpeter
Audio files: 10
PostPosted: Tue Jul 11, 2017 12:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes.
An interesting summary from Harry Bissel for most of the different cap types and their use can be found here.
http://analogrules.com/capacitors.html
Warung
PostPosted: Tue Jul 11, 2017 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
wackelpeter wrote:
Yes.
So Polyester/Mylar film/Metallized Polyester (looks red but the same shape) is the same capacitor just called differently?
Im searching for a capacitor's kit and don't want to go wrong and wait another month for parts. Also learning new stuff is always fun.
wackelpeter
Audio files: 10
PostPosted: Tue Jul 11, 2017 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
For most applications Wima MKP2 or FKP2 caps are good Options, apart from decoupling at the IC's which can be done with simple ceramic caps.
Those MKP and FKP are polypropylene and as per the list and the manufacturers advice best suited for timing caps, S&H, oscillators, etc.
Also have to admit that i had and still have some circuits with non proper caps inside... maybe soon i'll change some of them to see if i can observe any improvement.
translucent
PostPosted: Wed Jul 12, 2017 2:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Looking at the YuSynth VCO and BOM, then C8 is the component that really needs to be taken care of (it is also specified on the BOM and the comments as being high grade/low temperature drift styroflex or silver mica), but C3...C6 are only used for decoupling so may as well be replaced by ceramics?
