3D Printed Case and Panel for Noise Toaster
Page 1 of 1 [5 Posts]
elkayem
PostPosted: Tue Jul 04, 2017 4:47 pm    Post subject: 3D Printed Case and Panel for Noise Toaster Reply with quote  Mark this post and the followings unread
Hi All!
I just joined this forum to let folks know that I've put together a 3D printed case and front panel for the terrific MFOS Noise Toaster. Might be handy for anyone with access to a 3D printer.
Check it out here: https://www.thingiverse.com/thing:2418993
The front panel includes raised lettering, which will show up clearly provided you pause the print at the right height and change the filament. The case includes a 9V battery compartment and slot for a 1" diameter speaker. Everything you need!
I suspect I'll be back to this forum a lot now that my appetite for DIY synth has been whet. I'm currently weighing the Mark II vs Ultimate. Should be fun with my midi keyboard!
Meanwhile, here are a few photos:
Audio files: 303
PostPosted: Wed Jul 05, 2017 3:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, that looks very nice!
And welcome
PostPosted: Wed Jul 05, 2017 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome party!
That looks great! Razz
is it done with a standard filament printer ? because it looks pretty clean.
elkayem
PostPosted: Wed Jul 05, 2017 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for the kind welcome! The printer is nothing special, just an open source DIY kit on a shoe string budget. The filament is pretty standard, too. I used garden variety 1.75 mm PLA. I find the best way to get a clean print is to run at a very slow print speed. The case and panel did come out very clean, better than I expected. Looks sharp up close too.
welcome party!
Inventor
Audio files: 267
PostPosted: Thu Sep 21, 2017 6:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, very clean! I really like the raised lettering.
I have a 3D printer too, maybe we should compare notes?
Les
