Neutron O/A in blue
Page 1 of 1 [9 Posts]
Audio files: 160
PostPosted: Sat Jul 15, 2017 8:27 am    Post subject: Neutron O/A in blue
Subject description: first build started after a soldering break
Hi Smile
I have a small pile of bare & new to me pcbs forming and decided to tackle the top one first , a Version 1 Neutron orgone accumulator green pcb (thanks Alan).
The home made panel will be the usual 100mm wide by 250mm high with the panel pots , switches , sockets wired back to the board , i found Sduck's cool build a great source of inspiration for helping me with the layout design (Thanks Sduck) , and also the 60 or so pages of the muffs build thread were good to read as well as the pdf docs.
Progress so far ... i have populated the pcb , and now ready to twist some 2/3/4 core wire looms in the drill , i found a piece of 4mm thick ply for when testing and tuning happens , the proper blue panel will have to wait till ive designed some other panels to send 1 order to the printers Smile .
 Filesize:  835.97 KB
 Viewed:  589 Time(s)
 Filesize:  179.97 KB
 Viewed:  572 Time(s)
PostPosted: Mon Jul 17, 2017 10:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't expect amazing fidelity from the PWM Out (almost typed pwn...) -- it sounds rather chiptune-ish, compared to the very excellent Main Out.
Can't wait to hear about the rest Smile
Audio files: 160
PostPosted: Tue Jul 18, 2017 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
im looking forward to hearing this myself Smile , i should have it no-chip tested and wired up through the week .
Audio files: 160
PostPosted: Tue Jul 18, 2017 11:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Panel hardware set up on test panel & L plate for pcb in place also i made a few changes to the panel crosses and checked for space around control knobs.
 Filesize:  951.18 KB
 Viewed:  554 Time(s)
 Filesize:  177.48 KB
 Viewed:  536 Time(s)
Audio files: 160
PostPosted: Mon Jul 24, 2017 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi all Smile
Had a good burst of building over the weekend and got the V1 pcb all wired up and connected to the switches & pots & sockets , done a no-chip power test ... good Smile , popped in the 3v ref chip and checked there was a nice +3v & -3v good again Smile , then went for the op-amps & the teensy board , powered up and no led's , hmmmm, tried turning them around to the opposite of the pcb legend and intrepidly switched on, all good Smile Smile , i done a quick and dirty tune up on the first couple of octaves just for testing purposes and i was feeling myself sliding into a TD tangram / exit album sound zone Very Happy fantastic my fave Smile
then i checked all the pots & switch operations , i have not fully explored the effects sets , i was having great fun just in normal mode, also i was getting some nice 90's warp records type clicks & drone type sounds .
Once the good panel sticker comes in a month or two i will finish off the sound demo testing of the different effect modes.
Loving this module Smile Smile Smile
 Filesize:  1.66 MB
 Viewed:  602 Time(s)
Neutron orgone accumulator test - memories of 1993.mp3
 Filename:  Neutron orgone accumulator test - memories of 1993.mp3
 Filesize:  1.28 MB
 Downloaded:  1032 Time(s)
colorbars
PostPosted: Sat Jul 29, 2017 10:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks great! How are you making your panels?
Audio files: 160
PostPosted: Mon Jul 31, 2017 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi colorbars , panels ... i go to my local engineering firm to get 3mm thick aluminium sign sheet ( aluminium sheet with a protective sticker on the non scratched side) cut to my module sizes (100mm X 250mm) on their big hydraulic guillotine machine , i then print off a drill template on my home pc printer and glue on to the module plate and center punch all the crosses , i then use a press drill in my shed to work up the drill sizes start with 4mm for all crosses and build up to the biggest needed (12mm for my jacks) , i give the front a light rub with P1000 automotive body emery paper and wipe clean ready to apply the proper final vinyl sticker by de-activating the adhesive with warm soapy (washing up liquid) water, that allows me to move the sticker about to line up with the holes and i just scalpel vinyl crosses out before putting on the pots & sockets.
PostPosted: Fri Jul 05, 2019 1:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Dave, does the blue monster long fer more?
Audio files: 160
PostPosted: Sun Apr 26, 2020 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
yay! got round to finishing off this module , it has had the template test paper glued on the front for a few years time to get the proper sticker on the panel Smile .
neutron sound orgone accumulator in a slightly darker blue than usual but all is good Smile .
 Filesize:  1.53 MB
 Viewed:  221 Time(s)
