Z5J noise diode equivilent
Page 1 of 1 [4 Posts]
gavw
PostPosted: Thu Nov 02, 2017 3:30 pm    Post subject: Z5J noise diode equivilent Reply with quote  Mark this post and the followings unread
I am building the Penfold synth and I am sourcing the parts for the noise generator, which calls for a Z5J noise diode.
It seems to me this is now obsolete - Does anyone know of a modern replacement?
many thanks
A R C
PostPosted: Thu Nov 02, 2017 6:20 pm    Post subject: Re: Z5J noise diode equivilent Reply with quote  Mark this post and the followings unread
gavw wrote:
Z5J ...Does anyone know of a modern replacement?
I think that was just an axial 5.1V zener diode. So, something like a 1N751? If you are breadboarding you could try a few different 5.1V zeners and audition them to find the... noisiest?
PostPosted: Fri Nov 03, 2017 3:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Or use a general purpose NPN transistor where the Emitter is connected where the Cathode of the diode is projected and the Base of the transistor where the Anode of the diode supposed to be.
my synth
gavw
PostPosted: Fri Nov 03, 2017 3:58 am    Post subject: Reply with quote  Mark this post and the followings unread
That's very helpful - thanks both for your input. Have either of you built the Penfold Synth previously?
