FS Macumbista Benjolin V5 (green, blue, grey)
Page 1 of 1 [3 Posts]
macumbista
PostPosted: Mon Mar 30, 2020 2:47 am    Post subject: FS Macumbista Benjolin V5 (green, blue, grey) Reply with quote  Mark this post and the followings unread
Six Macumbista Benjolin V5 instruments available in green, blue, and grey.
PRICE
The price of the Benjolin V5 is EUR 565 (incl. 19% EU VAT) / EUR 475 (for customers outside the EU), plus express shipping costs from Helsinki Finland. Every Benjolin ships with two banana patch cables and a universal 110/220V AC to 12V DC power supply.
DETAILS
The Benjolin is a standalone synthesizer designed by Rob Hordijk from the Netherlands. It contains two oscillators (one LFO and one VCO), a voltage controlled filter and a circuit called a “Rungler”, which allows chaotic cross-modulation possibilities between the different parts of the circuit. Hordijk refers to the Benjolin as a circuit which has been “bent by design.”
These hand-made Macumbista Benjolins are officially licensed by Hordijk, and have been further customized with a patchbay, which can be used to interface with other modular synthesizers or to setup further control voltage feedback systems within the Benjolin itself, attenuators on the three control voltage input and LEDs displaying the internal state of the Rungler.
The latest Macumbista Benjolin V5 instrument has been redesigned during the spring of 2019 in collaboration with Pete Hartman of Frog Leg Synthesis. The filter input has been improved, and the main output of the instrument buffered for lower noise and ease of use with a wider range of mixers and DI boxes.
The wooden enclosures used to create these handmade analog synthesizers all date from the 1960’s and 1970’s. There are individual variations in the exact color, the size, and the marks which history have left upon them. A number of different colors are available, including a natural finish as well as three different types of “hammered metal” paint finishes in grey, green, blue, and (infrequently) red or purple. Please see the photos at the bottom of this post for examples.
MODIFICATIONS
The Benjolin V5 contains the following modifications from Hordijk’s original Benjolin circuit:
LOOP SWITCH: The LOOP switch locks the otherwise chaotic pattern of the Rungler into a loop. The LEFT position is a loop of 4 steps going forward, the MIDDLE position is the normal chaos of the Rungler, and the RIGHT position is a loop of 4 steps forwards and 4 steps backwards.
EXTERNAL INPUT SWITCH: The external input 6.3mm jack on the back of this Benjolin allows a signal from another source to be sent through the Low Pass Filter of the instrument. Selecting EXT on the FIL INPUT switch sends this signal to the FIL input, where the cutoff and resonance controls of the filter can be used to affect it. When the FIL INPUT switch is in the INT position, the PWM signal, mixed with a small amount of RUN voltage, is sent to the FIL (this is the normal Benjolin signal path).
EXTERNAL RUNGLER CLOCK: A banana jack on the back panel of the instrument provides a switchable clock source for the Rungler of the instrument. The EXT switch position clocks the Rungler from OSCILLATOR 2 of the instrument, the INT switch position clocks it from the external clock input.
PHOTOS
These detailed photos are from a previous batch, please see the photo at the top of this post for exact banana jack colors which may be different.
macumbista.net
macumbista
PostPosted: Thu May 07, 2020 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Only two left! A green and a grey.
macumbista.net
macumbista
PostPosted: Sun May 31, 2020 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
This is the last Benjolin V5 I will be making for quite a while, as I will be starting a PhD program in Sweden very soon and won't have time for any other instrument building. Please email macumbista@gmail.com if you are interested in taking it. EUR 565 (EU) / EUR 475 (nonEU) plus shipping and PayPal 4% if applicable.
macumbista.net
