quick question (SOLVED)
Page 1 of 1 [2 Posts]
Estebandito
PostPosted: Fri Feb 19, 2021 4:09 am    Post subject: quick question (SOLVED)
Subject description: regarding the cd4028 BCD to decimal decoder
what happens if you input a binary number over 1001 (9) into the cd4028? So binaries ten to fifteen.
I keep pouring over the datasheet but I must be overlooking the obvious answer. Which would be 'all outputs stay low'. Can someone confirm?
thanks!
https://www.ti.com/lit/ds/symlink/cd4028b.pdf?ts=1613668450121&ref_url=https%253A%252F%252Fwww.google.com%252F
EDIT: page 95 of the cmos cookbook confirms "All outputs remain LOW if an invalid BCD code is applied".
Audio files: 299
PostPosted: Fri Feb 19, 2021 7:41 am    Post subject: Re: quick question (SOLVED)
Table 1 in the data sheet you refer too states 'all outputs stay low' for input vaues > 1001.
