e1999
Posted: Sat Mar 13, 2021 4:22 am Post subject:
electrolytic capacitor orientation in discrete amplifiers |
Hi there,
If you look at the electrolytic capacitor orientation of the output section of the monotribe
https://usermanual.wiki/Document/monotribesch.191226586/html
-or another example - the mic preamp from Rod Elliott esp found here
https://sound-au.com/project13.htm
-or altec 1592
https://sites.google.com/a/davidmorrin.com/www/home/trouble/transistors/amplifiers/altec-1592a
the capacitor at the input has the cathode towards the incoming signal rather than the other way around as I usually see on other similar circuits.
I was wondering if anyone knows the reason(s) for this?
and also could this be potentially damaging for a device that is connected to it? I'm curious because I have a phone who's audio output jack seems to have been fried and I'm wondering if it might have anything to do with plugging it in to the preamp circuit from ESP.
Thanks very much. |
Joined: Nov 23, 2015 Posts: 1320 Location: Netherlands
Posted: Sat Mar 13, 2021 10:35 am Post subject:
I’d say that the monotribe example is backwards while the other two seems ok to me.
To determine how the orientation of the capacitors should be you have to figure out where the most positive voltage usually is and place them accordingly, where the + of the capacitors points towards the most positive voltage. _________________ my synth |
Posted: Sat Mar 13, 2021 10:39 am Post subject:
As for the esp is concerned, I once was at a talk from an Analog Design engineer and he stated that the best thing that could happen with an opamp when exposed to an esp is to break down immediately because especially opamps that are not esp safe will brake down eventually and usually at the most unconvinient moment... _________________ my synth |
Joined: Apr 03, 2004 Posts: 24672 Location: The Netherlands, Enschede
Posted: Sat Mar 13, 2021 11:04 am Post subject:
| Grumble wrote: | | As for the esp is concerned |
Did you mean ESD .. I think that ESP in the OP was referring to this pre-amp :
Anyway, it seems highly unlikely to me that connecting that pre-amp to a headphones output would blow up that output. _________________ Jan
Posted: Sat Mar 13, 2021 11:47 am Post subject:
your right (of course ) _________________ my synth |
Posted: Sat Mar 13, 2021 11:56 am Post subject:
I did like Extra Sensory Perception tho
(except when that would destroy electronics) _________________ Jan
e1999
Posted: Sun Mar 14, 2021 10:17 am Post subject:
| ok cool thanks for the responses:) |
