鼓菇菇 gǔgūgū Mushroom Drum Synth
Ruebezahl
PostPosted: Sun May 22, 2022 7:34 am    Post subject: 鼓菇菇 gǔgūgū Mushroom Drum Synth Reply with quote  Mark this post and the followings unread
This drum synth is housed in a mushroom shaped mosquito light. It can be played by drumming on the mushroom head, or using the internal sequencer, based on a CD4089. The Sequencer can be controlled by 4 switches for the logic inputs of the 4089, or light sensors (housed in the mushrooms head as well) respectively. The sound is a pitch bent square wave oscillator with variable decay.
About the name: The chinese characters meaning is literally Drum Mushroom, but the pronouncation is gǔgūgū, which makes it sound very funny Smile
Here a little video of me playing it, both by hand and automated: video
The available controls are:
- Sensitivity (of the trigger pad)
- Sequencer Speed
- Decay
- Pitch Decay
- High Pitch
- Low Pitch
- Tone (Filter)
Like so often, i had the basic circuit running very quick, but many little details i wanted to add, and decisions i had to made resulted in around half a year that this mushroom finally made sounds. It’s a mosquito trap in mushorom shape, and i housed the circuit in both the head, as well as the body, so there are quite a lot of wires running between the two boards, just through the 4 thin plastic sticks, which made wireing also a little challenging.
This mushroom i found in a thrift store, but i have the plan that this is just the first of many to come, so i already found some others online, Each mushroom drum will have a different color (both body and LED’s) and a different sound. Also they will all have trigger and sync ins, so later on i might trigger them from a master sequencer, or play them by hand like a drum set. So it will be like a big rythmic mycelium.
But so far this little guy is still all by himself, i think already pretty fun Smile
The next mushrooms i am planning on:
-Xor-Drum, for metallic percussion
-twin-t drum
-maybe a simple one, mainly for hihats
-Super Space Drum Clone ( Original by Electro Harmonix)
for the sequencing i guess there are many options, i like patching around with cmos chips, so i think i might build a sequencer with lots of different logic chips.
another one i find quite interesting is a classic Electro Harmonix "Clockworks"
 Filesize:  273.72 KB
 Viewed:  149 Time(s)
 Filesize:  293.08 KB
 Viewed:  148 Time(s)
 Filesize:  463.76 KB
 Viewed:  127 Time(s)
 Filesize:  159.44 KB
 Viewed:  222 Time(s)
