few pcb layouts
Page 1 of 1 [6 Posts]
vladosh
Audio files: 51
PostPosted: Wed Feb 19, 2025 12:03 am    Post subject: few pcb layouts Reply with quote  Mark this post and the followings unread
Here are links to Gerber files for few tested and verified working PCB layouts ,if you wanna make your own ,i'll just post the links cause uploading all here again ..
https://synthesizerunderconstruction.blogspot.com/2024/08/siam-siemens-inspired-audio-module.html
Siemens inspired EQ
https://synthesizerunderconstruction.blogspot.com/2024/06/preamp-envelope-follower.html
Envelope Follower/Preamp
https://synthesizerunderconstruction.blogspot.com/2024/01/crossfadepanner-buchla-based.html
CrossfaderPanner based on Buchla - Vactrol Bsed
https://synthesizerunderconstruction.blogspot.com/2024/01/experimental-hardware-neurons-by-grant.html
Experimental Hardware Neurons by Grant Richter
https://synthesizerunderconstruction.blogspot.com/2024/01/non-linear-circuits-primal-hyperchaos.html
NLC Primal Hyperchaos
https://synthesizerunderconstruction.blogspot.com/2024/01/non-linear-circuits-spasm.html
NLC Spasm
https://synthesizerunderconstruction.blogspot.com/2024/01/cgs95-reverb.html
CGS 95 Accoutronics Reverb
https://synthesizerunderconstruction.blogspot.com/2024/01/serge-wavemutlipliers-pt1.html
Serge VCA/Overdrive as part of Serge Wavemultiplier
https://synthesizerunderconstruction.blogspot.com/2024/01/papareils-fxloop.html
Paparail FXLoop - VC Aux
https://synthesizerunderconstruction.blogspot.com/2024/01/hagiwos-additive-vcos.html
Hagiwo's Additive VCO Dual
https://synthesizerunderconstruction.blogspot.com/2024/01/smoother-serge-ssg-and-hagiwo-bezier.html
Serge Smooth from SSG plus Hagiwo's Bezier Curve
https://synthesizerunderconstruction.blogspot.com/2024/01/buchla-194.html
Buchla 194 BPF
https://synthesizerunderconstruction.blogspot.com/2024/01/old-crows-yamaha-bpf.html
Yamaha GX BPF
Ayab
PostPosted: Tue Apr 01, 2025 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you so much Vladosh. An excellent variety of interesting modules.
I am excited to do some building! Very Happy
I will very much enjoy building some of them. I usually do my own etching but I may give the gerbers a try and order some of the double sided boards.
Razz Smile Very Happy
PostPosted: Tue Apr 01, 2025 5:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
A lot to look at there. Thank you for posting!
vladosh
Audio files: 51
PostPosted: Wed Apr 02, 2025 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
you're welcome ,these posted here are tested and built ,there are more at the blog but i had not built them ,they are all double checked or more https://synthesizerunderconstruction.blogspot.com
Ayab
PostPosted: Wed Apr 02, 2025 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you again for your generosity making your hard work available Very Happy
Ayab
PostPosted: Wed Apr 02, 2025 12:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is alot to go through which is exciting!
I am having a good look. Inspiring.
