The Garden
Page 32 of 33 [805 Posts]
Goto page: Previous 1, 2, 3, ..., 30, 31, 32, 33 Next
klangumsetzer
Audio files: 37
PostPosted: Wed Sep 10, 2025 1:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Beautiful, PhOBoS: such variety! Very Happy
I really like Tagetes. My grandmother always had them in her garden.
This year I grew Linnétagetes from seed but they have a hard time competing against the Phacelia and the Borago.
Make a joyful noise!
Eike
PostPosted: Wed Sep 10, 2025 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
ah the Linnétagetes look similar to the "disco red" ones I grew but larger. I used to consider marigolds to be typical bedding plants that
are a quick way to add some color but the flowers themselves didn't do a lot for me. Until I started growing some of the single flower
varieties which I like a lot better. I do love the classic daisy style flowers that you see with a lot of plants in the Asteraceae family.
I can imagine it being hard to compete with the Borago if I look at how large they grew here last year. They completely dominated the
planter they grew in, smothering anything else. Nice plants and the bees loved it but a bit too large for the limited space I have.
PostPosted: Wed Sep 10, 2025 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
while the plants are starting to fizzle out I thought it would be a good time for a bit of DIY and prepare for autumn/winter.
First thing I did was repair the "roof" of the bird feeder. A couple years ago, 2018 to be exact, I glued pine cone scales to it
for a more natural somewhat fairy tale/enchanted forest look. I used hot glue at the time which worked ok but over the years
a lot of the scales had come off. I think mostly due to birds pecking at them looking for insects and the hot glue wasn't the
best quality to begin with.
This time I used wood glue which did take more time but should hold up a lot better. I didn't have much pine cones to work with
and they seemed to be lot tougher so the coverage isn't as dense. I used some small scraps of wood, which I painted, for a nicer
edge at the front.
 Filesize:  202.53 KB
 Viewed:  78 Time(s)
 Filesize:  338.79 KB
 Viewed:  80 Time(s)
PostPosted: Wed Sep 10, 2025 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Something else I added some paint to is the ladybug motel. I wanted to add a bit of color without having it stand out too much
so I mixed greens and blues with hints of pink and purple. I also changed the interior. When I got it last year I put some loosely
packed straw in it, which might have been ok, but since ladybugs seem to enjoy crevices I got the idea of applying a harmonica
fold to some cardboard and placed that in there.
 Filesize:  241.58 KB
 Viewed:  81 Time(s)
 Filesize:  269.06 KB
 Viewed:  69 Time(s)
 Filesize:  244.53 KB
 Viewed:  79 Time(s)
 Filesize:  361.76 KB
 Viewed:  86 Time(s)
PostPosted: Wed Sep 10, 2025 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Made 2 insect hotels from a couple of small fruit crates. I have been meaning to do something with them but didn't know what,
although I did use one of them before to grow some moss. The angled corner supports were protruding and I could have cut
them short but that would make the crates shallow and more likely to topple over. So I extended the sides and made them deeper.
which also makes them sturdier. I got a piece of mesh to cover the fronts and went on a short hike to get some extra materials to
fill them up. (pine cones, twigs, small branches and a couple pieces of bark).
I didn't want to make compartments with different materials but mix everything a bit more naturally together. The first one I put
together still ended up having things more separated and half way through started to turn into a bit of a diorama. For the second
one I first cut up some larger pieces, drill holes in them and then treated it more like a packing puzzle.
 Filesize:  276.33 KB
 Viewed:  72 Time(s)
 Filesize:  317.18 KB
 Viewed:  70 Time(s)
 Filesize:  390.63 KB
 Viewed:  85 Time(s)
 Filesize:  309.93 KB
 Viewed:  72 Time(s)
 Filesize:  337.05 KB
 Viewed:  73 Time(s)
Audio files: 308
PostPosted: Thu Sep 11, 2025 4:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, so the insect hotel is not a bird feeder anymore I see Smile
At mom's place the woodpecker would find, or try to find at least, insects in the block of wood - which made for some interesting 'ghost knocking' for a while.
PostPosted: Mon Sep 15, 2025 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
The flowers on the Goldenrod aren't just yellow but have quite a bit of white on them. I haven't been able to identify it yet,
maybe Solidago 'little lemon' which is a dwarf with yellow/white flowers.
The snapdragons have produced yet another flush of flowers, these just don't give up. They will have to come out once the springbulbs
go in but I'll re-pot them and try to get them through the winter.
 Filesize:  232.39 KB
 Viewed:  82 Time(s)
 Filesize:  261.79 KB
 Viewed:  84 Time(s)
 Filesize:  103.67 KB
 Viewed:  81 Time(s)
 Filesize:  438.81 KB
 Viewed:  92 Time(s)
 Filesize:  369.36 KB
 Viewed:  84 Time(s)
PostPosted: Mon Sep 15, 2025 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Cyclamen has woken up from its slumber.
 Filesize:  252.03 KB
 Viewed:  73 Time(s)
 Filesize:  204.71 KB
 Viewed:  82 Time(s)
PostPosted: Sat Sep 20, 2025 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
grow your own food
wasn't expecting any strawberries this year but there might even be more if the weather doesn't get too bad.
I also planted the ends, or I guess the beginnings, of some spring onions and they seem to be taking well.
 Filesize:  232.19 KB
 Viewed:  80 Time(s)
 Filesize:  160.8 KB
 Viewed:  71 Time(s)
PostPosted: Sun Sep 21, 2025 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finally found a suitable hanging planter for the Carex oshimensis 'Evergold'. Ordered a beige and an orange one since I wasn't
sure what I would like best and also didn't know if the orange would be more of a terracotta orange (it is) or bright orange.
I think it works well in the beige pot and I used the orange one for the Festuca glauca 'Compacta blue' so it has more root space
and it looks a more consistent. I quite like these pots so while they are available I ordered a brown one as well and I think that
should make for a nice trio. I'll probably use it for the Armeria pseudarmeria 'Ballerina Red' which hasn't been very happy in the
current metal photobox planter.
I also got another birdfeeder. I already had an acorn shaped one for peanuts and now I have one for regular birdseed as well.
both planters are the same size, but the orange one is hanging a bit lower and further to the back.
 Filesize:  346.51 KB
 Viewed:  70 Time(s)
I am not sure if putting peanuts in it was the best idea, might clog it up too much but I hope the birds can just peck them out.
 Filesize:  218.6 KB
 Viewed:  75 Time(s)
The wall is starting to fill up nicely. I did reorganize things a little bit so the ivy will have to re-cover some bald spots.
 Filesize:  312.41 KB
 Viewed:  76 Time(s)
PostPosted: Sun Sep 21, 2025 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is already some new growth appearing on a couple of plants. Very Happy
This one did great for most of the year, though it never flowered, but then it started dropping leaves and dying off.
Looks like there is some life left in it so I might end up with 2 different goldenrod plants next year.
 Filesize:  261.86 KB
 Viewed:  65 Time(s)
The Verbena was getting covered in mildew so I cut most of it back and I am glad to see it is starting to regrow from the base.
Note that not all the parts that have been pruned back were done by me.
 Filesize:  290.6 KB
 Viewed:  63 Time(s)
I cut it back after flowering, though there wasn't much to cut back and I wasn't sure if it was going to make it.
Looks hopeful but we'll have to see if it will survive the winter.
 Filesize:  220.83 KB
 Viewed:  63 Time(s)
The Erysimum has also been regrowing quite a bit but I also took some cuttings. It's a short lived perennial and the stems turn woody pretty quickly so you end up with a bare bottom part. It's a readily available plant but cuttings are free.
 Filesize:  272.9 KB
 Viewed:  74 Time(s)
PostPosted: Sun Sep 21, 2025 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Added another Brunnera or 2 actually.
When I picked up the birdfeeder I had a quick look at the plants. I wasn't planning on getting anything new at this time of the year
until I noticed that a lot of the plants that are sold throughout the year (so not the the seasonal ones) now had a 50% discount Shocked .
Got another standard Brunnera macrophylla because the one I already have was looking a bit sad, so now it has a friend.
The other one is a Brunnera macrophylla 'Jack Frost' which I found tucked behind some other plants. I initially didn't really like
the Jack Frost but that was mostly just due to over exposure as it is quite common.
I also got a foxglove, though on closer inspection it might be a lot more than 1 in a single pot, and a fern but I should have paid
a bit more attention to the label of that one because it's one that could get quite large.
 Filesize:  305.55 KB
 Viewed:  74 Time(s)
the larger leaves are from the Aconitum vulparia. It hasn't flowered yet this year and I doubt it will but it appears to be doing alright.
 Filesize:  364.34 KB
 Viewed:  77 Time(s)
 Filesize:  369.35 KB
 Viewed:  84 Time(s)
 Filesize:  259.73 KB
 Viewed:  67 Time(s)
PostPosted: Wed Oct 01, 2025 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
more food,.
Of all the super hot peppers the only one that grew some actual fruits is the Trinidad Moruga Scorpion which has 2 peppers on it.
Don't see any on the other ones but that's often what happens. If they flower it's usually too late in the season, even more so
now that I want to empty out the planter somewhere in the coming weeks to make room for the spring bulbs (which I am expecting
to receive today). I will try to over winter them but I haven't had any success doing that before.
The Fresno peppers on the other hand have been producing a bunch of tasty peppers and are now growing a second batch.
 Filesize:  131.79 KB
 Viewed:  88 Time(s)
 Filesize:  139.11 KB
 Viewed:  68 Time(s)
PostPosted: Wed Oct 01, 2025 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
The 'Carnevale di Venezia' Morning glories have started flowering.
 Filesize:  252.29 KB
 Viewed:  72 Time(s)
 Filesize:  122.97 KB
 Viewed:  68 Time(s)
 Filesize:  148.04 KB
 Viewed:  71 Time(s)
this might be a different variety but it should be a mix of both blue and pink striped ones and it is possible to get some without stripes.
 Filesize:  127.56 KB
 Viewed:  79 Time(s)
PostPosted: Wed Oct 01, 2025 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I have some Hellebores Cool
Didn't buy these but got them from a lovely lady who every year has this stunning display of gorgeous yellow hellebores.
Knowing that they do self seed and because she had quite a lot of them I blatantly ask if could have one. She told me I
could come and dig one out whenever I had time for it and 5 minutes later she was also showing me the rest of the garden.
I had some time the next day so carefully dug around a large leaf trying not to disturb things too much and ended up with
a small clump. Once home I could brake it up and it appears that it contained 6 plants in total. 2 didn't have any leafs and
the others are fairly small. Note that what you see is last years foliage, they are currently still dormant. I don't know yet if
any will take, apparently Hellebores don't like to be transplanted, but I was welcome to dig out another one if it doesn't.
 Filesize:  291.67 KB
 Viewed:  67 Time(s)
PostPosted: Sun Oct 26, 2025 4:59 am    Post subject: Reply with quote  Mark this post and the followings unread
flower
The last photo before I removed it from the planter. I did repot it but it's not a hardy plant so I don't expect it to survive for very long. It's currently still flowering though.
 Filesize:  405.15 KB
 Viewed:  70 Time(s)
These are still flowering. I think next year I will sow them in the container I use for the Phacelia. Starting with the Phacelia in early spring, after they've gone over I'll sow Buckwheat and after that the Calendula.
 Filesize:  110.6 KB
 Viewed:  65 Time(s)
This Buckwheat seems to have some pink flowers. I don't know if it has anything to do with the temperature since they've always come up white but I'll try to save some seeds for next year.
 Filesize:  110.16 KB
 Viewed:  61 Time(s)
I got another strawberry, it was very tiny though. This one has also been repotted and is looking very healthy at the moment.
 Filesize:  135.82 KB
 Viewed:  64 Time(s)
I am not expecting any flowers on the Cyclamen as those should appear before the foliage, but the foliage is what I mainly grow it for anyway and it does look stunning.
 Filesize:  285.52 KB
 Viewed:  60 Time(s)
PostPosted: Sun Oct 26, 2025 5:25 am    Post subject: Reply with quote  Mark this post and the followings unread
bird interlude
A Robin showed up which appears to be a seasonal bird, at least on my balcony.
I did see one a couple of times in Spring but not during the rest of the year.
Of course I am not keeping an eye on my balcony 24/7 and also not very early in the morning
so It might have been visiting more often.
Another bird I saw return today is a Great Spotted Woodpecker which I was able to capture on video.
throughout the day there are a lot of sparrows, blue tits and great tits.
I managed to get a quick shot from my webcam
 Filesize:  277.04 KB
 Viewed:  71 Time(s)
PostPosted: Sun Oct 26, 2025 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
SPRING BULBS
Last year was the first year that I decided to plant spring bulbs. Although not all of them came up it turned out great and I am happy I did.
It provided a lot of color very early on in the year when I usually don't have a lot going on yet and thereby extended the growing season.
It also kept me more active on my balcony later in the year since I had to tidy things up a bit to make space for them.
So at the beginning of June this year I put in an order as soon as it was possible and I received all the bulbs a couple weeks ago.
Some of the bulbs are the same I grew last year since I really liked them, some are more or less replacements and there are a couple
that I didn't grow before.
Narcissus 'Arctic Bells' a small, creamy white, early flowering daffodil with cone shaped flowers, which should have multiple flower stalks per bulb.
I got these instead of snowdrops. I do like snowdrops but I replanted last years bulbs in the pot with the dwarf willow tree (which I am pretty sure
is actually dead now) so hopefully those will come back. The Narcissus are already starting to show some green shoots.
Iris reticulata 'Alida' the same ones I had last year and they were some of the earliest flowering bulbs. I had a look at some other Irises
but I just really like these.
Scilla bifolia 'Rosea' I am not sure if I've seen these before, they remind me a bit of hyacinths but much smaller. Apparently they are
fairly drought tolerant so if they do ok I might replant them in my alpine planter. edit: the dutch name is Sterhyacint
Narcissus 'Jetfire' a small daffodil with backwards pointing petals. I got these instead of the Narcissus minnow that I had last year of
which hardly any flowered. I am pretty sure that was because of a lack of sunlight though.
Tulipa 'Scarlet Baby' Lovely small early flowering bright red tulips. Had these last year and they did great.
Puschkinia scilloides var. libanotica also appears to be a bit hyacinth like but smaller and the flowers are white with a light blue stripe.
edit: apparently in dutch they are called Buishyacint or Saffierhyacint
Anemone nemorosa a white Anemone. I didn't have any luck with the Anemones last year but apparently they like moisture and it's best
to rehydrate them before planting. Last year I had corms which still looked a bit bulb like but this year I received rhyzomes which look like a
bunch of twigs. I planted these in the pot with the dwarf willow tree as well (also likes moisture) and while I was digging around I had a look
at the snowdrop bulbs from last year which are still looking ok.
Narcissus 'Anfield' The same large daffodils I had last year. They were big, bright yellow and kept flowering for quite some time with
multiple flowers per bulb.
Tulipa 'Purple Purissima' I got these as a replacement for the Tulipa 'Sweet Sixteen'. I did like those but because they were fairly small
they got somewhat overshadowed by the large daffodils. The color was also pretty pale. These are larger and a darker pink which should
contrast better with those daffodils.
Muscari latifolium a broad-leaved Grape-Hyacinth to add some extra color between the yellow daffodils and and pink tulips. They are
fairly small though so I am not sure how well it works out but because of the broad leaves they might be able to carve out a bit of space for
themselves.
Allium moly (yellow), Allium cowanii (white), Allium unifolium (pink) I got these as a replacement for the Allium zebdanense.
I was planning on getting those again this year because I really liked them (they might have been my favourite of all the bulbs) but at the time
that I placed my order those were not available yet. So I got these 3 different colored Alliums instead which I planted all in one pot.
fun fact: those 30 bulbs cost exactly as much as 10 of the Allium zebdanense bulbs.
I also kept some of the bulbs from last year but since I am not sure if they will flower again this year I ordered new ones.
As I already mentioned the Snowdrops (Galanthus elwesii) were replanted in the pot with the dwarf willow tree.
The Muscari aucheri 'ocean magic' were left in their small pots, tucked away and ignored for the rest of the year, but when I emptied the pots
out to plant the Narcissus 'Arctic Bells' I found out that they were very much still alive. So I replanted those in the pot with the Buddleja.
There were also small tulips in those small pots but I believe only one of those actually flowered and most of them didn't even show up so
I am pretty certain that the bulbs that were still alive are indeed the Muscari. (time will tell).
I kept the bulbs of the Tulipa 'Scarlet Baby' and also the small Narcissus minnow bulbs and replanted both together in a planter
that's hanging from my railing (the one I use for the Phacelia).
I also kept the bulbs of the large Narcissus 'Anfield' which had multiplied quite a bit and planted them in a large pot. I did have to do it in
2 layers with the largest bulbs in the bottom layer and the smaller ones in the top layer. Those small ones probably won't flower and maybe
non of them will and it will likely get very cramped in there.
I did find some bulbs in another pot when I emptied it out which might actually be the Allium zebdanense but could also be the Hyacinthoides
non-scripta
aka english bluebells. I planted those in a small pot to see if they will do anything.
I think I also still had the Iris reticulata 'Alida' bulbs. At least I recall that I planted some bulbs earlier in the year in the pot that has the
Verbena bonariensis + Solidago + Agastache. I guess we'll have to wait until spring to see what everything is and what has survived.
edit: and even more bulbs have been added. I realized that the large pot that currently has the Thunbergia alata (aka Black-eyed Susan vine) growing in it
is mostly empty until late spring which is when in previous years I have been sowing morning glories in it. The Thunbergia may survive the winter but it's not
really taking up much space. I bought a bag with 15 cheap(er) Crocus bulbs in mixed colors (white/yellow/blue) and planted those in the pot.
I am not really a fan of Crocuses, unless planted in a lawn, but they are a good early food source for pollinating insects. Not sure how well they'll do in there
as it doesn't get a whole lot of sun but it's worth a try. I also planted one of the Atropa bella-donna plants in there which have been growing in small pots
for about 2 years now.
Also got a bag with 5 Hyacinthus bulbs (the large ones) in mixed colors (purple/pink/white), 3 of which have been planted in a pot together with some
large violas (pansies) that add a bit more joy at this time of the year. Those will most likely be long gone by the time the Hyacinths emerge.
I have been somewhat avoiding buying those Hyacinths because they flower fairly late and I need the space for other plants but I'll leave that to future me
to sort out. I am not sure yet where I am going to plant the remaining 2 bulbs, I might add them to the pot with the Buddleja.
the colored borders indicate bulbs that are planted together.
 Filesize:  554.41 KB
 Viewed:  67 Time(s)
These are all the bulbs that are planted in the large railing planter:
Tulipa 'Scarlet Baby', Narcissus 'Jetfire', Iris reticulata 'Alida', Scilla bifolia 'Rosea', Puschkinia scilloides var. libanotica.
 Filesize:  273.73 KB
 Viewed:  56 Time(s)
PostPosted: Mon Nov 17, 2025 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I super charged some peanut butter for wild birds by melting it and adding dried mealworms (crushed), sunflower kernels and some suet.
Decided last minute to also crumble up one of those suet balls with seeds and added that as well. Weirdly enough the smell reminded me a bit of white chocolate.
I hope they like it but I am a bit worried that the magpies and jackdaws discover it (especially the jackdaws) and it'll be gone in a matter of days.
 Filesize:  279.54 KB
 Viewed:  68 Time(s)
 Filesize:  319.28 KB
 Viewed:  67 Time(s)
 Filesize:  275.85 KB
 Viewed:  56 Time(s)
PostPosted: Mon Nov 17, 2025 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool
With all the plants removed from the large planter to make space for the spring bulbs, you can get a better view of the 'alpine gutter' which is slowly filling up.
 Filesize:  422.6 KB
 Viewed:  67 Time(s)
Calendulas are still flowering but I don't expect them to stick around much longer with these low temperatures.
 Filesize:  400.66 KB
 Viewed:  60 Time(s)
The Foxglove I bought on sale 2 months ago seems to be quite happy in its current spot. It has a lot of root space so might grow into an absolute monster.
 Filesize:  385.4 KB
 Viewed:  65 Time(s)
PostPosted: Mon Nov 17, 2025 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got another small greenhouse, similar to the two I already have (one of which is in permanent use without the cover as an indoor storage rack),
but this one is smaller so a bit easier to place. It also has 4 tiers instead of 3, though I did leave one out to be able to add larger plants.
The overall height is practically the same so it does have less space between the levels but that's fine.
I got it just in time since the temperature has dropped significantly. Even though most of the plants on my balcony that are still alive at this point
should be hardy, that hardness gets called into question when they are grown in small pots under less than ideal conditions instead of in the ground.
Having them on a balcony does have the advantage that the overall air temperature is a bit higher than at ground level and they are a bit shelterd
from the elements. Still, I like to give them all the protection I can and it should also prevent them from drying out too much.
I also have some seedlings that I started this autumn: Foxgloves ["Foxy", which should flower the first year and Digitalis lutea], Snapdragons,
Hollyhocks (also a variety that should flower the first year), Primula elatior and a couple of eager Datura seedlings I pulled out of a planter.
I did sow a couple of other seeds as well but they will probably stay dormant until spring.
 Filesize:  259.4 KB
 Viewed:  55 Time(s)
 Filesize:  380.52 KB
 Viewed:  59 Time(s)
PostPosted: Mon Nov 17, 2025 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Something else I got is moss, nice soft, soothing moss. dwarf
Mainly to add as a ground cover to pots with woodland plants like the fern and Brunneras. I have tried growing moss before from small patches
that I gathered myself but never had much success with it. I am not really expecting this to last a long time either, it probably won't survive the
summer but we'll see. At the very least it will probably add a bit of extra protection for the plants during the winter and prevents the soil from
drying out too much
It was advertised as 4 sheets of 30x40cm but they aren't straight cut pieces that all have the same size and I think the total area is probably about
1.5x times as much. It's also a bit of a mix of different mosses and as an added bonus it comes with half a pine forest. One of the pots I've added
moss to is the large one that I recently planted the crocus bulbs in. It's not the same as grass but close enough and it definitely makes the Belladonna
plant look much more natural. I also added it to the Autumn Fern, Brunneras and a Heuchera which is another plant I recently bought on sale when
I got the large violas (you can see some of those on the photos in the previous posts).
I stored the moss that I haven't used yet in 4 plastic containers with a false bottom using hydroton clay pebbles and am currently waiting for a small
rack and a couple of LED light strips to try and keep it alive inside. Maybe I should try making a moss kokedama. I do have a small fern and a couple
of small parlor palms that should be suitable for it. That would also combine nicely with the marimo moss balls.
 Filesize:  394.17 KB
 Viewed:  58 Time(s)
please excuse the somewhat blurry photo. it was overcast and low light levels = long shutter time.
 Filesize:  246.21 KB
 Viewed:  74 Time(s)
This one also got a layer of fresh moss. The ivy started from an unknown seedling that I had found.
I am not actually planning to turn it into a true bonsai plant btw. or am I ?
 Filesize:  318.95 KB
 Viewed:  61 Time(s)
2 of the 4 plastic containers with moss that I haven't used yet. (inside dimensions are ±25x33cm)
 Filesize:  381.94 KB
 Viewed:  66 Time(s)
PostPosted: Tue Jan 20, 2026 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
It's not spring yet, though with the temperatures we had last week it did feel a bit like it,
but nonetheless a lot of the springbulbs are starting to show up above ground.
the two smaller pots in front contain small daffodil bulbs (Narcissus 'Arctic Bells') and the large pot that already has a lot of scraggly green growth is filled with different alliums.
 Filesize:  375.57 KB
 Viewed:  28 Time(s)
this one has the largest variety of bulbs: Iris reticulata 'Alida', Scilla bifolia 'Rosea', Narcissus 'Jetfire',Tulipa 'Scarlet Baby' and Puschkinia scilloides var. libanotica.
 Filesize:  398.25 KB
 Viewed:  21 Time(s)
left side planter with Narcissus 'Anfield', Tulipa 'Purple Purissima' and Muscari latifolium. (yes that's cat food, no I don't have a cat)
 Filesize:  323.37 KB
 Viewed:  24 Time(s)
right side planter with Narcissus 'Anfield', Tulipa 'Purple Purissima' and Muscari latifolium.
 Filesize:  453.46 KB
 Viewed:  25 Time(s)
2 of the left over Hyacinth bulbs, the other 3 are planted in the pot with violas that's partially visible in the first photo (no sign of those yet).
 Filesize:  183.52 KB
 Viewed:  29 Time(s)
PostPosted: Tue Jan 20, 2026 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
more bulbs, these are the ones I kept from last year.
I believe these are Tulipa 'Scarlet Baby' and Narcissus 'Minnow'.
 Filesize:  322.04 KB
 Viewed:  45 Time(s)
Muscari aucheri 'ocean magic' growing in the pot with the Buddleja.
 Filesize:  371.31 KB
 Viewed:  26 Time(s)
All the large daffodils from last year, might get a bit cramped but that's not necessarily a bad thing.
 Filesize:  287.08 KB
 Viewed:  20 Time(s)
Audio files: 308
PostPosted: Tue Jan 20, 2026 5:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe not spring, but i did spot this one one or two weeks ago .. (edit: 8 days ago) shielded from the easterly wind by vegetation .. against a warmish wall of a house .. Muscari botryoides / grape hyacinth / blauw druifje
https://en.wikipedia.org/wiki/Muscari_botryoides
It is waking up early often in that place, there probably will be more soon.
edit: and some more ...
catkins every where .. hazel, alder .. probably willow too, but there are not many here .. or i do not see them often here I mean.
also toverhazelaar ... which is not native here, but is lovely .. erm .. witch hazel .. hamamelus something ...
Muscari botryoides (blauw druifje - jan 13)
 Filesize:  677.08 KB
 Viewed:  30 Time(s)
alder catkins
 Filesize:  2.66 MB
 Viewed:  90 Time(s)
witch hazel
 Filesize:  268.99 KB
 Viewed:  25 Time(s)
