The Garden
Page 34 of 35 [854 Posts]
Goto page: Previous 1, 2, 3, ..., 32, 33, 34, 35 Next
PostPosted: Sat Mar 21, 2026 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
It doesn't appear to be much of a mix (yet) but I am pleasantly surprised by how well these crocuses are performing Razz
Both these and the large Hyacinths were cheap bulbs that I more or less bought on a whim at the end of last year year.
 Filesize:  363.76 KB
 Viewed:  45 Time(s)
 Filesize:  136.02 KB
 Viewed:  36 Time(s)
it smells very pink too
 Filesize:  161.91 KB
 Viewed:  41 Time(s)
 Filesize:  182.14 KB
 Viewed:  39 Time(s)
Audio files: 326
PostPosted: Sat Mar 21, 2026 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
And spring may last a bit longer .. now that it is not very warm outside .. the crocusses & such will love that .. as long as it does not rain Shocked
PostPosted: Sat Mar 21, 2026 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
heh, rain is usually not much of a problem on my balcony, more the lack of it, not much wind either.
I think it also helps that they aren't in a very sunny spot, it's more dappled shade, so they still get enough sun to open up,
but not the direct heat.
Brunnera 'Jack Frost' is growing back nicely as is the Wolfsbane.
I am curious if the latter one will flower this year (it didn't last year).
The Henbane is also growing back, though it seems that the largest plant has now finally given up.
There are 2 other plants that are ready to fill the spot which I think were sown in 2024.
I've also been preparing more seeds in the fridge (cold stratification) and this time I've mixed both the
Hyoscyamus albus aka white Henbane, which is the one currently growing, and Hyoscyamus niger aka black Henbane,
which I what I used to grow and was always much smaller.
 Filesize:  238.32 KB
 Viewed:  35 Time(s)
 Filesize:  261.06 KB
 Viewed:  40 Time(s)
 Filesize:  261.38 KB
 Viewed:  36 Time(s)
 Filesize:  339.82 KB
 Viewed:  35 Time(s)
PostPosted: Sat Mar 21, 2026 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have been busy propagating quite a few plants from seeds and cuttings, with more to be sown later and it has been going pretty well for the most part.
One nice surprise is the Solanum atropurpureum aka Purple Devil aka Malevolence.
I have tried to grow it before without any luck but gave it another try this year with some different seeds. Or actually last year since I've sown the seeds in autumn
and then left them outside in the greenhouse over the winter. Initially nothing germinated and I wasn't really expecting it to work but a couple weeks ago I brought
the seeds back inside and placed them in my TiT incubator. It is after all a tropical plant so likely prefers some heat to germinate.
After having spend some time inside, 1 of the 5 seeds decided to germinate,... and then another,.. and another,..
3/5 is more than I expected (there might even be more to come) and if I can keep at least one of them alive that's already going to be quite a challenge on my balcony.
Not so much a challenge to grow it but to coexist with it in the small space because it is completely covered in long, sharp and pointy, not so friendly looking, thorns.
as you can see here (The leaves are thorny as well Twisted Evil):
fun fact: I convinced Jason over at the Allotment of the Dead to give the Solanum atropurpureum a go as well: https://youtu.be/igZCURLHAZ0?t=593
To give myself some chance of survival I have decided to grow it inside the metal obelisk, in the pot that currently has the flowering crocuses.
So it will be somewhat caged up and in a corner of my balcony where it hopefully doesn't get in my way too much. It's also one of the most sunny spots
so I think it should do well there. Besides the crocuses (which will die off above ground) there's also a Belladonna lutea, aka Deadly nightshade plant
growing in the pot. They are related (both from the Solanaceae family) so I hope they'll get along and I'll leave it up to them to figure out their living arrangements.
I usually use the obelisk as a support for climbing plants and will try to add some of those as well.
There is actually a Thunbergia alata aka Black-eyed Susan vine already in the pot but I doubt it is still alive, we'll see if it decides to return.
Usually I grow Morning glories but they can be very vigorous growers and would probably block out too much of the light for the Malevolence,
while also getting ripped to shreds by it.
Morning Glories: Ipomoea tricolor ‘Milky Way’
What I will try is Tropaeolum peregrinum aka canary creeper which I think will grow less vigorous, or at the very least should be easier to keep under control.
If it grows at all that is, because I've had these seeds for >10 years and they were already close to their expiration date when I bought them.
I don't think I've had much luck with them before but there are only a few seeds left so might as well give it a go.
I also have some equally old seeds of Lathyrus odoratus aka sweet peas which would also be suitable climbers, so I'll give those a go as well.
they look so innocent at this stage
 Filesize:  183.52 KB
 Viewed:  37 Time(s)
 Filesize:  327.79 KB
 Viewed:  40 Time(s)
PostPosted: Sat Mar 21, 2026 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
more old seeds have been sown in the metal 'photobox' planter.
I've tried growing Leontopodium alpinum aka Edelweiss in it before (twice), but it got devoured by a leaf miner.
The Armeria pseudarmeria aka great thrift didn't do so well in it either so it got transplanted to a hanging pot.
Sedum works pretty well in it, at least if grown as an annual.
I was considering trying to grow Dianthus in it this year,
which I also have growing in a pot hanging from the balcony railing and that one has been doing great.
Dianthus 'Lucky Lips'
That reminded me that I still had some old Dianthus seeds left which never worked for me before.
2 varieties, though only very few seeds of one of them: Dianthus superbus and Dianthus carthusianorum.
I also have some older Eschscholzia californica aka California poppy seeds that didn't work for me either and they might like that dry/sunny spot.
I mixed those up and just for fun I also added a couple of the Nigella orientalis 'Transformer' seeds to the mix.
Some seeds have now germinated and I am pretty sure these are California poppy seedlings.
 Filesize:  245.09 KB
 Viewed:  36 Time(s)
 Filesize:  153.4 KB
 Viewed:  38 Time(s)
PostPosted: Sat Mar 21, 2026 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some other plants that I am growing from seeds are Tagetes patula aka French marigolds.
These were some of my favourite and most profusive flowering plants from last year.
Tagetes patula 'Disco Red'
Tagetes patula 'Jolly Jester'
so this year I'll try to grow mooore of them Laughing
not only the same varieties as last year (from fresh seeds that I harvested) but I also got seeds for a mix of flowers in the brown/red/orange/yellow range.
These were all sown on the 2nd of March and have been growing inside under LED grow lights. I did add a couple more seeds in some of the cells when
nothing was germinating in it, which sofar has resulted in the following number of seedlings: 11 mixed, 7 Disco Red, 6 Jolly Jester.
I did sow some more at a later date because the Disco Red and especially Jolly Jester were delayed but in hindsight that wasn't needed
I want to add small Zinnias as well this year, mostly to add some pink to it, but I got a mix of seeds that also has red, orange, yellow and white flowers.
It will be a surprise what will turn up (I am really hoping for some pinks). I started seeds for these on the 2nd of March as well and they did great.
Actually, they did too great Shocked After 2 weeks they were already getting quite large and these are summer loving plants that don't like cold
and thus will probably have to stay inside for at least 6~8 weeks, if not longer. So I did the only sensible thing for a change and got rid of them.
I have plenty more of these Zinnia seeds and I now know that they are not only viable but also germinate really quick and grow fast.
The plan is to wait until June (if I have the patience) and then sow some of them inside (as I did now) but will also try direct sowing outside.
 Filesize:  352.38 KB
 Viewed:  31 Time(s)
±12 hours had passed between taking this photo and the previous one
 Filesize:  361.16 KB
 Viewed:  37 Time(s)
 Filesize:  343.03 KB
 Viewed:  34 Time(s)
RIP.
they grew up TOO fast.
 Filesize:  289.47 KB
 Viewed:  38 Time(s)
 Filesize:  324.9 KB
 Viewed:  39 Time(s)
PostPosted: Sun Mar 22, 2026 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
hmm, I might have a slight problem or maybe I should allow it.
 Filesize:  343.28 KB
 Viewed:  34 Time(s)
 Filesize:  229.3 KB
 Viewed:  32 Time(s)
oh, hi there
 Filesize:  96.43 KB
 Viewed:  38 Time(s)
I had noticed before that the eyes seemed different on the pigeons that were visiting and this appears to be a stock dove instead of a wood pigeon.
edit: actually it's probably an 'ordinary' rock pigeon (not nearly as great as a rock lobster)
 Filesize:  74.28 KB
 Viewed:  37 Time(s)
Audio files: 326
PostPosted: Sun Mar 22, 2026 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
problem? at least it is not a "flying rat" Shocked
And it might reward you with bits of fertilizer, maybe even some new wild plants Idea
Now if only it will not wake you up too early Rolling Eyes
PostPosted: Sun Mar 22, 2026 7:29 am    Post subject: Reply with quote  Mark this post and the followings unread
meanwhile I made two seed snails.
I noticed seed snails appearing online a couple years ago and at first glance they seemed to be one of those trends that spreads on social media
but after a couple of years nobody talks about it again because it turned out to be messy and highly unpractical.
I do think that in general it's much easier to use seed trays or small pots but seeds snails do have a purpose. The thing that sets them apart
is that they can be made tall without taking up much space, which makes them ideal for plants that grow long roots very quickly.
Also the roots themselves don't get tangled up as much as if you were to sow multiple seeds in a single pot.
Maybe I should first explain what a seed snail is for the uninitiated. It's basically a Swiss roll (one of those roll up cakes) but using soil.
They're usually made with cardboard but you can use other materials as well and I recently saw that they are even selling kits for it now.
To make one, you take a strip of whatever material you want to use, put a layer of soil on it (make it fairly moist so it doesn't fall apart)
and then roll it up and tie it together. Once you are done with that you can place it on one end and plant the seeds in the other one.
The two I made are used for the climbing plants I mentioned in the post about the Solanum atropurpureum:
Tropaeolum peregrinum aka canary creeper and Lathyrus odoratus or more commonly known as sweet peas.
I know that at least the sweet peas can develop long roots so this should be ideal for them.
I also just got two hanging pots/buckets to hang from my railing (moooore plant space) and they turned out to be perfect for it.
 Filesize:  282.63 KB
 Viewed:  39 Time(s)
 Filesize:  251.7 KB
 Viewed:  35 Time(s)
PostPosted: Sun Mar 22, 2026 7:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Well it's not that I don't like it,. actually I think it's amazing that it decided my balcony is a suitable space for nesting.
The main problem I've had with pigeons is that they can severely damage my plants. Mostly by trampling on them,
but they might also eat some young shoots or seedlings. This Dove might be better behaved though.
I also need to move things around a bit soon and I wouldn't want to scare it, it's probably already terrified that I spotted it.
I think it can stay in that spot though and to be honest the planter it's using does make a nice nest. It has soil, some rocks,
and sticks and a layer of straw. I put it together and placed it there last year as a habitat for insects.
Audio files: 326
PostPosted: Sun Mar 22, 2026 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah .. so it can stay .. good :)
And maybe some [more] protection .. but then again any bird could enter the balcony and damage things I guess?
PostPosted: Sun Mar 22, 2026 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
I think it's already gone, or maybe moved a bit and I can't see it anymore.
I was planning to do some things in that corner today so maybe I'll spot it again.
Small birds are too light weight to do any real damage to the plants and larger birds generally only stay on the railing.
Maybe the occasional fledgling will make an excursion, I even had a young crow inside last year and a young tit as well.
I have lost quite a few plants in previous years due to severe pigeon damage though. That's also why I often have a lot
of sticks between the plants, they offer some support but are mainly there to prevent them from being snapped.
I captured some incriminating footage Laughing
side note: I've noticed a blue tit showing interest in the nesting box/bird house. It didn't work out for them last year
(I did keep the nest, it's gorgeous) but maybe they'll try again this year.
PostPosted: Sun Mar 22, 2026 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
It's not just me that is enjoying the daffodils, the bees seem to bee attracted to them as well.
I am really happy they are because one of the defining factors in deciding to grow spring bulbs
was that they are a valuable food source for early pollinating insects.
I haven't seen them showing interest in any of the other flowers yet, I'd expect them to be all over the crocuses.
 Filesize:  120.18 KB
 Viewed:  31 Time(s)
 Filesize:  119.21 KB
 Viewed:  35 Time(s)
 Filesize:  112.92 KB
 Viewed:  33 Time(s)
hmm when did those leafs show up, I swear they weren't there yesterday, it's going fast now,..
 Filesize:  532.15 KB
 Viewed:  39 Time(s)
PostPosted: Thu Mar 26, 2026 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
a couple of new plants arrived in the mail today Razz
Different shop than usual this time and I am very pleased with the quality (especially the roots).
Achillea millefolium 'Cerise Queen'
Anchusa azurea 'Loddon Royalist' I wanted something with blue flowers
Gaura lindheimeri 'Whirling Butterflies'
Lychnis arkwrightii 'Vesuvius'
Penstemon digitalis 'Husker Red' It's like a Goth Foxglove
Polypodium vulgare
Salvia nemorosa 'Caradonna'
Veronica repens groundcover for the Buddleja
all links lead to the RHS website
 Filesize:  2.04 MB
 Viewed:  29 Time(s)
PostPosted: Sat Mar 28, 2026 4:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I gave the pot with the Solanum dulcamara* aka bittersweet a bit of an overhaul and added some plants to it.
*This plant was grown from seed in 2017, the same year I started this thread (oh, almost 10 years now).
this is how it looked in 2017 when it was just starting to make its way up
and this is what it looked like in June 2024, probably at its best
I had noticed in the last few years that it seemed to be struggling and towards the end of last year it really wasn't looking very healthy anymore.
I suspected that it might had become root bound after growing in that same pot for all this time, though the Pulmonaria (growing in the same pot)
wasn't doing well either anymore, so it could also be a problem with the soil.
My initial plan was to have a look at it in spring to see what was going on in the pot.
Not something I was looking forward to with the plant + support structure being rather large and my balcony being small,
not to mention having some Ivy tangled up in it which all made it more difficult to remove from its spot.
I didn't wait until spring though and decided to bite the bullet at the end of last year instead of having to dread this daunting task any longer.
It was indeed quite tricky to get it removed from its spot and maneuver it, but eventually I managed to lay it down flat and remove the pot.
Well it wasn't root bound,.. quite the opposite actually as it appeared to have lost a lot of roots.
The bamboo support structure had rotted away in the pot and instead of supporting the plant, the plant was now supporting it.
What I think might have happened is that because it wasn't properly supported anymore, it had been swaying in the strong fall winds,
which had caused some of the large roots to shear off.
I think the plant might actually be dead now (RIP) but it wouldn't completely surprise me if it does grow back from the base.
I also don't know how old these plants can get because they usually aren't grown on purpose but instead treated as an invasive weed.
However, even if it doesn't grow back it's still not completely dead,..
The last couple of years whenever I pruned it back I stuck some of the cuttings in the soil because I had noticed they can root quite easily.
Not all of these cuttings were successful but when I removed the pot I found that 3 of them had rooted.
These 3 cuttings is also were most of last years growth had come from, which somewhat camouflaged that the main plant wasn't doing so well anymore.
So it is still alive, just split in different parts now. And as a last resort I also harvested some seeds last year and they have germinated.
I replaced a large portion of the soil, added a new stronger support structure and replanted the 3 cuttings; one on each side and the largest one in the middle.
The 2 on the sides already started showing new growth a few weeks ago and I initially thought that the middle one hadn't made it through the winter.
Today I noticed some new growth on that one as well Razz
I buried 2 plastic 9cm pots towards the front because I knew I wanted to add more plants later and this way I wouldn't have to dig and possibly damage the roots.
It's also just a lot more convenient. (these pots were also used to temporarily house the violas and hyacinths).
While I had easier access I decided to plant one of the Atropa belladonna plants in it towards the back.
No idea how that will work out but that one has started to produce new growth as well.
Earlier this week I received one of the plants that I really wanted to add which is the Polypodium vulgare aka common polypody.
In dutch it's called Eik varen which translates to Oak fern (which is the name of a different plant) and the fronds do resemble Oak leaves.
It's an evergreen which doesn't get very large, can handle drought and doesn't mind sun, so I think it should do ok in that spot
and hopefully creates a woodland look in combination with the (decaying) wood and bark that I placed around the pot, also the Ivy adds to it.
On the other side I added a Hellebore, or at least I thought it was a Hellebore but when I took it out of the pot it turned out to be 3 Very Happy .
That does increase the odds of at least one of them surviving, and maybe all do. They're probably all yellow but there is a small change they will be pink.
Stay tuned for next year when we may find out,.
I also added a Cymbalaria muralis aka ivy-leaved toadflax which had self-seeded in another pot.
I hope this one will trail down and then establish towards the base of the pot to soften the bottom edge.
oh, and the Pulmonaria was probably struggling because it got too dry.
I re-potted what was left of it and there is a little bit of new growth visible but I am not sure yet if it will pull through.
 Filesize:  379.42 KB
 Viewed:  31 Time(s)
I moved the Digitalis purpurea 'Gloxiniiflora' (Foxglove) into the corner so it can cover the edge of the container and create more space on the other side for some plants I want to add later.
 Filesize:  369.62 KB
 Viewed:  26 Time(s)
PostPosted: Sat Mar 28, 2026 5:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another new plant that has been planted is Veronica repens aka Corsican speedwell.
I divided it into 4 sections and found a free pet which I luckily hadn't cut into pieces Shocked .
3 of those sections were planted in the pot with the Buddleja and hopefully grow into a lush green carpet at the base.
It should also produce small white/blue flowers in late spring.
The remaining section has been repotted into a small pot for later use.
 Filesize:  418.46 KB
 Viewed:  29 Time(s)
 Filesize:  380.76 KB
 Viewed:  33 Time(s)
 Filesize:  432.46 KB
 Viewed:  30 Time(s)
new growth on the Buddleja
 Filesize:  315.59 KB
 Viewed:  25 Time(s)
 Filesize:  344.96 KB
 Viewed:  30 Time(s)
PostPosted: Sat Mar 28, 2026 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
a better look at the Muscari aucheri 'ocean magic' that are also growing in the pot with the Buddleja.
I also re-potted the large blue hyacinth into the pot with the other 3 and removed the violas from it.
 Filesize:  204.05 KB
 Viewed:  26 Time(s)
 Filesize:  163.15 KB
 Viewed:  27 Time(s)
 Filesize:  95.93 KB
 Viewed:  25 Time(s)
it's a bit more purplish than it appears in the photo
 Filesize:  285.5 KB
 Viewed:  31 Time(s)
 Filesize:  230.28 KB
 Viewed:  26 Time(s)
PostPosted: Sat Mar 28, 2026 5:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
nightshades Cool
The White Henbane has a new pot mate in the form of a Datura stramonium.
This one self-seeded at the end of last year and I kept it inside over the winter.
I also removed the top layer of the soil since it had a lot of bird seed in it and mixed in some fertilizer.
Oh, and I added the Henbane seeds (black and white) that I was keeping in my fridge.
The seedlings of the Solanum atropurpureum have adorable tiny spikes Twisted Evil
 Filesize:  343.12 KB
 Viewed:  23 Time(s)
 Filesize:  194.13 KB
 Viewed:  34 Time(s)
who's a cute little purple devil,..
 Filesize:  181 KB
 Viewed:  30 Time(s)
PostPosted: Sat Apr 04, 2026 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
A couple new plants for the yellow hanging planter;
- a bright orangy-red Pelargonium zonale
- Campanula addenda 'White Star'
- Muehlenbeckia*
* this is the trailing plant I got towards the end of last year which was sold as a combo with the silver/white Calocephalus.
That one has actually been growing very well and I temporarily planted it in a separate pot.
I also installed a ring nut so the planter hangs a bit nicer and slightly more secure now.
 Filesize:  292.77 KB
 Viewed:  13 Time(s)
 Filesize:  158.15 KB
 Viewed:  13 Time(s)
PostPosted: Sat Apr 04, 2026 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
The springbulbs are still springing or bulbing. While the Daffodils in the top planter are starting to go over, the ones in the other planters are starting to open up.
Some of the tulips have also started to open up. I am not entirely sure if these are the correct ones (Purple Purissima) but I do really like them.
I really like this combo. I think the Muscari latifolium that are growing in the other planters would fit in very nice as well.
 Filesize:  241.23 KB
 Viewed:  11 Time(s)
 Filesize:  213.38 KB
 Viewed:  11 Time(s)
 Filesize:  144.98 KB
 Viewed:  10 Time(s)
these are a really dark purple
 Filesize:  149.81 KB
 Viewed:  11 Time(s)
 Filesize:  134.5 KB
 Viewed:  12 Time(s)
PostPosted: Sat Apr 04, 2026 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I made a small plant table to place on top of another one, so now the insect hotels can go underneath and some pots on top so they get more light.
I tried to make it look a bit more interesting by having the legs protrude and I want to add drawer knobs on top as ornaments.
Will shuffle things around a bit more and might remove the brown plastic pot (with the orange flowers) which doesn't have anything growing in it at the moment.
 Filesize:  234.89 KB
 Viewed:  13 Time(s)
 Filesize:  366.85 KB
 Viewed:  15 Time(s)
PostPosted: Sat Apr 04, 2026 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also got a couple more plants, mainly some ground covering ones to add to other pots.
A new Erysimum 'Bowles Mauve'. The one I had did great last year but sadly didn't survive the winter.
I did take some cuttings but they're still pretty small so now I have a healthier backup.
I combined it with a Dianthus deltoides 'Brilliant' which should have bright pink flowers in summer.
My initial idea was to also combine it with Acaena microphylla 'Kupferteppich' as a ground cover
but the Dianthus already looks very eager to spread out so I'll save that one for another pot.
I also got an Epimedium youngianum 'Niveum' which I planted in the corner between the ivy and the Foxglove.
Never had much luck with Epimediums before but maybe this is a more suitable spot.
Erysimum 'Bowles Mauve' and Dianthus deltoides 'Brilliant'
The Acaena microphylla 'Kupferteppich' with its small copper colored leaves is visible in the background.
 Filesize:  420.23 KB
 Viewed:  11 Time(s)
if you look closely you can see the small reddish leaves of the Epimedium in the lower left corner.
 Filesize:  308.44 KB
 Viewed:  10 Time(s)
 Filesize:  292.36 KB
 Viewed:  12 Time(s)
PostPosted: Wed Apr 08, 2026 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Made use of the easter bunny albino weekend to remove the little greenhouse, clean a bit and move other things back in place.
It also gave me a better view of the spring bulbs in the 2 large planters which don't appear to flower as profusely as last year.
Some of the tulips are stunted and a very pale pink and I wonder if they might have gotten a bit of cold damage. The temperature
did drop quite a bit shortly before they started to open up and we might have even had some frost during the nights.
The larger ones are coloring up nicely though, a lovely shade of pink with a bit of a purple streak.
Towards the end of last year I got a plant stand which is somewhat modular so you can put it together in different ways.
I used it as 2 taller units during the winter to prop up the pots with the spring bulbs, and now I made it into 3 small units
which, when the spring bulbs have gone over, will be used to prop up 3 large pots with a mix of plants. (more about those later)
 Filesize:  336.8 KB
 Viewed:  1 Time(s)
 Filesize:  330.09 KB
 Viewed:  0 Time(s)
 Filesize:  337.49 KB
 Viewed:  1 Time(s)
 Filesize:  272.91 KB
 Viewed:  1 Time(s)
PostPosted: Wed Apr 08, 2026 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I will have to move things around during the next few weeks when some plants go and others grow larger.
 Filesize:  298.47 KB
 Viewed:  1 Time(s)
Verbena bonariensis cuttings in the front enjoying some actual sunlight.
 Filesize:  363.44 KB
 Viewed:  1 Time(s)
 Filesize:  357.32 KB
 Viewed:  1 Time(s)
 Filesize:  350.79 KB
 Viewed:  1 Time(s)
 Filesize:  337.7 KB
 Viewed:  1 Time(s)
PostPosted: Wed Apr 08, 2026 3:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
The alpine planter looks better at the beginning of this year than it did at the beginning of last year.
Most of the sedums at the front died again but it doesn't look so barren this time.
I did clean it up a bit, added some small sections of sedums from other containers and I might add a couple more sempervivums.
 Filesize:  394.81 KB
 Viewed:  1 Time(s)
 Filesize:  229.48 KB
 Viewed:  1 Time(s)
 Filesize:  313.48 KB
 Viewed:  0 Time(s)
 Filesize:  267.06 KB
 Viewed:  1 Time(s)
