rodcencko
Posted: Mon Aug 01, 2005 2:44 am Post subject:
Composition Grammar |
I follow with interest the topic about "How to get inspiration", but rather than inspiration I've some trouble to find a compositional "grammar" to use with my ideas. I've tried to look around on the net and I ask already in another forum without any concrete answer. It seems that especially in the field of the experimental music none has tried to give a kind of rules for putting ideas in an structured context. When I asked the same question in another forum the the typical answer were: Let the music flow or Don't give to your creativity a cage etc.etc.
I hope I was clear enough when I say Grammar I mean a set of rules to use for give a finish structure to a music composition
Suggestion are welcome |
Posted: Mon Aug 01, 2005 3:21 am Post subject:
Re: Composition Grammar |
hey rodcencko!
This is very interesting. I have been thinking about these things myself a lot. I guess you are right about that grammar missing, in the sense you are using the term.. and also a proper "modern" terminology to describe both the process and the methods. I guess we have to invent something then..
| rodcencko wrote: | | When I asked the same question in another forum the the typical answer were: Let the music flow or Don't give to your creativity a cage etc.etc. |
yeah.. right.. very helpful advice indeed.
I am a bit busy right now, but I will get back to this topic ASAP. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
deknow
Posted: Mon Aug 01, 2005 4:44 am Post subject:
this is interesting, and something i have given some thought to over the years.
there is an illusion (i think) that there are "rules" for other forms of music (specifically in the classical tradition)...this is no more than an illusion. what matters about music is what it sounds like. there are times when methods and/or process are also importnat, but if the music doesn't convey something auraly, then those things are irrelivent (imho). for instance, one can compose with a tonal or serial approach....but if the music sucks, who cares.
certainly, harmonically and structurally speaking, physics is probably the best language to describe what is going on. the "rules" that are learned by every music theory student are simply an analysis of what bach did by ear....and he did this because of how it sounded, not because he had an arbitrary set of rules to follow, but because of how differant pitches and overtones interact, and how they are percieved by the listener. in the case of these "standard rules", it was rameau who (many years after bach's death) analyised his style, and was able to codify it into a set of rules that achieve a similar effect...but anyone who has done projects for a class based on these rules knows that this process is _not_ the same kind of creative process of composition (in almost all cases), but more like following a set of rules. of course these can be applied brilliantly, just as the rules of how to move chess pieces can be simply following rules, or they can be used to do brillaint and elegant things.
i have a free improv band that has been playing together for several years (and most of that time, we rehersed once a week). this experience has lead us to develop our own vocabulary. we can talk about what we do, but in general, it is easier to keep that discussion in the musical domain (we express them through playing, not by talking about them).
i think the only answer to your question is that there is no grammar (outside what record collectors use...which, like rameau's analysis of bach looses much of the creative "meat" in the discussion) for most forms of modern music. much of the academic "notation" for modern music seems to me to be bridge between the time when music could only be recorded by notating it for others to play, and the modern time where music is recorded directly by the composer (and there are certainly other approaches, especially when dealing with groups...but this is again notating for others to play). the only solution is to actually record something (anything), and then, as your own "audience", evaluate what you like, what you don't like, and devise ways to get closer to your goal. as you get closer and gain more experience, you will be able to ask specific questinos....some more tangible than others ("how do i make the bass meatier...more "menacing", or "i really like the quality of the drum sounds in such and such a track...how do i get these drums to sound more like that). in the jazz tradition (before people went to expensive university to learn "jazz theory"), transcribing (writing out) solo's of other's recorded works that accomplish something that the "student" wanted to learn has always been to learn...i think "making a house track" or "recording a drum and bass sequence", or even (as sheridan has done) "sythesizing real sounds" is probably the most valuable thing you can do. looking for a vocabulary that someone else has devised only insures that you will work within their limitiations.
deknow |
Kassen
Posted: Mon Aug 01, 2005 5:31 am Post subject:
Deknow, I think rodcencko actually *wants* a grammar, something along the lines of the demand that a Fugue introduces the theme in a certain way or the need for a kick on every count with a relatively high pitched countraccent in the lead or bass of house and the "pitch everything up a semitone somewhere at 2/3 of the track" of 80's pop or the rules of twelvetone music, except for electronic experimental music.
I can well see the demand for this; we are so insanely free that it make smaking choices hard. Inherently, for experimental music, such a gramar would be personal; however where to look for such a grammar? I have to think about this but it's certainly a excelent question. _________________ Kassen |
deknow
Posted: Mon Aug 01, 2005 5:54 am Post subject:
well, i think record collectors do this...but i also don't think it's particulary useful if one is working with "experemental" music, as collectors can only really describe what has already been done, and only describe the result, not the process. if one works only within the framwork of what other's have described/defined, it doesn't seem very experemental to me.
as you said, it must be a personal lexicon....and that is only developed (i think) by doing actual experementation.
deknow |
egw
Joined: Feb 01, 2003 Posts: 1569 Location: Asheville NC
G2 patch files: 8
Posted: Mon Aug 01, 2005 5:57 am Post subject:
| Structure or "grammar" shouldn't restrict the creative flow unless it's too heavy handed. It may even help inspirationally by providing a context or starting point. In most types of music some amount of structure, or conventions, are given. But in experimental music, I think the structure itself is part of the creative process. So feel free to devise your own. |
Posted: Mon Aug 01, 2005 6:58 am Post subject:
| egw wrote: | | Structure or "grammar" shouldn't restrict the creative flow unless it's too heavy handed. |
I tend to agree and isn´t also structure.. or rather perceived structure one of the many possibly ways to identify music? That said, structure does of course not always mean "repetition of elements"
| egw wrote: | | It may even help inspirationally by providing a context or starting point. In most types of music some amount of structure, or conventions, are given. But in experimental music, I think the structure itself is part of the creative process. So feel free to devise your own. |
Good points. I am also seeing that free experimental music often also refers to conventions.
Devising a "this piece only" set of objects/components/rules is a good suggestion. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Mon Aug 01, 2005 7:08 am Post subject:
I don´t think our new friend is thinking grammar=conventions as in "I love those dull genres and I am too lazy to figure out something smart I can call my own." It is more the other way around I guess.
Speaking of conventions, there are at least two sides to this. Ultimately we have to use some conventions in order to get the music accepted as music. I don´t think that is an act of evil. It is all about making the listeners accept the premises and then make them listen. It is of course quite true that it is not a valid claim that all music should be loved by everyone. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Mon Aug 01, 2005 7:16 am Post subject:
| deknow wrote: | looking for a vocabulary that someone else has devised only insures that you will work within their limitiations.
deknow |
It doesn´t always work that way. These issues are far more complex than that. One example is how Franz Liszt clearly both became part of the new avantgarde and how he also managed to create his own voice. His transcriptions and variations of pieces by Paganini shows this well. That stuff is still damned hot. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
rodcencko
Posted: Mon Aug 01, 2005 7:29 am Post subject:
"I think the structure itself is part of the creative process. So feel free to devise your own"
That's what I heard so many times.
But, must the experimental composition be a kind of "Nobody's land" where everyone find his own way or maybe it should have at list one or more defined macro-structures where I can put my compositional elements? |
paul e.
Joined: Sep 22, 2003 Posts: 1567 Location: toronto, canada
Kassen
Posted: Mon Aug 01, 2005 8:48 am Post subject:
| elektro80 wrote: |
Yes, very much so. There are many sounds that are quite typical for certain types of experimental music. With some experience you can often date and place experimental music after hearing half a minute of it, much like you can with house or techno. "experimental" often has a sound, much like blues and rock have a sound.
I can well imagine rodcencko's frustration and in fact in my own experience the people that claim not to be held back by rules are quite often the people that work within a quite strickt formula yet are unconcious of this themsleves.
I often use rules to structure pices; for a while I was quite facinated with canons and wrote pieces where one monphonic line had a delay on it of exactly a quarter note and I made chords by making the melody layer with itself, sometimes with feedback, sometimes without. I would however considder this gramar on the level of the musical phrase or theme, not on a compositional level (though admittedly the line blurs). Currently I'm working with pitchsifters to play counterpoints on one line by putting effects over it, using a delay with gated feedback. This makes writing quite hard and a very concious process.
Modular synthesis is very well suited for such ideas. As I wrote previously; one way of dealing with this is by emulating principles. FOr example, say we are writing a love song and so are choosing the form of a duet. We could make two patches in modular synths that in some way represent the persona of the people we are writing about. We could then make sure they each take some form of input from the other patch, thus reacting to eachother and compose the piece on a higher level representing changing situations and leave the patches to determine their relationship to eachother within these situations in a self-organising manner.
I think a lot can be done with the design of intelligen, semi autonomous instruments, particularly in pieces about the relationships between people and changing situations. In conventional forms of composition the score and the instruments are fairly static; we have the option of thinking about what elements of the notes and the instruments represent what and actually making the relationships between the things they are inspirered on a active part of the signal flow. Even if this doesn't always result in good music it's a interesting psychological experiment. _________________ Kassen |
Posted: Mon Aug 01, 2005 8:50 am Post subject:
Yup, the "Variation Techniques for Composers and Improvisors" by Larry Solomon is an excellent helper.
It does however not directly answer the initial question.
Personally I don´t see the "feel free to devise your own" advice as problematic, but I do see that it also can be seen as a diversion. We are still left with the "How do I do that?" question. Related to this is of course the problem every composer faces: "Right.. so I did just that.. but then when there are no rules.. how can I know if this piece of music is any good?" _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Kassen
Posted: Mon Aug 01, 2005 8:57 am Post subject:
| rodcencko wrote: |
I think it's a inherent part of experimental music to *try* to find your own way in this "noman's land", however there is no reason at all not to borrow methods of navigation, even if you don't adhere to a ready made map. You could for example devise some alternate tuning of your own and implement that on some outlandish instrument of your own design, then set the musical form of some type of folkmusic loose on this.
I don't think there is any great need or use for everybody following the same macro structure but I do think that it's usefull to have a set of rules to govern individual pieces. Did you for example considder scoring for a old, short, silent movie? archive.org will have plenty of readily available targets for such experiments. _________________ Kassen |
opg
Joined: Mar 29, 2004 Posts: 954 Location: Berkeley, CA, US
Posted: Mon Aug 01, 2005 10:25 am Post subject:
When I got more into experimental music (which wasn't as deep into it as most of the members here compose), my first question is, "What do I want to hear that I haven't heard before or enough of?" I'll then begin fiddling with sthose sounds I want to hear.
But then I get to the actual structure of the song. I usually end up following a more traditional pop song format, the whole "A - A - B - A" garbage, because most of my songs focus on rhythm. But what about those more ambient, abstract songs? After I have decided what I want to hear, I then ask myself, "Well, what would be BORING? What would I NOT want to hear my sounds do?" I usually follow these rules:
1. At the beginning of the song, you should give the listener a sense of space and/or sound quality. That is, if you don't start the song with loud drums with reverb or a crazy-panning synth drone, your opening sound should have an ear-catching CHARACTER to it. I like to start off with a messy analog synth rhythm/arp that's got a lot of tape saturation, bit reduction, etc. If this rule isn't followed, it's difficult to catch your listener's attention or not have your sobg sound like General MIDI/musak. (But keep in mind, rules and structure are meant to be broken).
2. Be careful how long you focus on a certain loop/instrument/sound. Even if you have some really organic bubbling synth that's constantly changing in terms of panning, HP/LP filtering, phasing, volume, etc., it could very well be interpreted by the listener as THE SAME SOUND, and therefor repetitious. Of course, it can hurt you in just the opposite way. If you make too many changes too fast, the listener won't have time to enjoy those sounds that you want to have heard (this is usually a problem for me personally).
3. Just like stand-up comedy, things should usually be re-introduced throughout the song - not a strict structure like "A - A - B - A," but at appropriate distances away from when you first heard them. By "them," I mean either a sound or melody. With electronic music, there is so much that could be your "hook" that the choices of what should be re-introduced can be maddening.
This is probably not the best way to go about answering the question, but I worry about structure all the time, especially when I have to figure out how to transition from one section to the next. Right now, I think most of my songs are over-structured and don't flow very well.
I think after deciding what "type" of music the song you're working on is (meaning: has a beat through most of the song, very organic and ambient, crazy glitch, etc), you will be able to apply these rules. And then later know when to break them. |
Kassen
Posted: Mon Aug 01, 2005 10:37 am Post subject:
Great post, OPG. I think that one of the main things that remains the same everywhere is that good music has a ballance between elements that are expected by the listener and elements that break this expectation. THis holds true for everything from sound design to conventional meloldy.
It would follow that to have this "expected" element we need some rules that the listener can detect in some way and that provide the structure. _________________ Kassen |
paul e.
Posted: Mon Aug 01, 2005 11:30 am Post subject:
don;t know if this is totally on point to the discussion..
but is is interesting to observe that traditional blues has the same basic structure each and every time, yet the variations and permutations of this form are quite vast ..
most blues musician draw on internal experience and feeling ..
so perhaps 'structure' is less important and 'inspiration/emotion' is the real driving force behind composition
the 'rules' of music are simple and self-evident..not even 'rules' but more like natural laws..
maybe it's not only intellectual, but more importantly, emotional forces that guide the composition _________________ Spiral Recordings |
opg
Posted: Mon Aug 01, 2005 1:14 pm Post subject:
Just don't forget that there are so many subgenres of electronic music. One in particular, minimalism - how does this fit in our discussion? This is not a subgenre I'm interested in because it violates Rule #2
| Kassen wrote: | | It would follow that to have this "expected" element we need some rules that the listener can detect in some way and that provide the structure. |
I think, with the exception of minimalist electronic music, paul e. brings up a good point about "inspiration/emotion." Minimalist music doesn't build to anything, whereas most other electronic music (whether percussionless and ambient, or glitch) has this building-up, variations, and combinations in its songs. I'm one who easily gets tired of a song that I've been working on for a while or feels like they're in a "structure rut." I've tried ending songs that don't elude back to anything in the rest of the song, and all it does is create a bad ending. I prefer the "stripping away of parts" as an ending, whether it is a simple repeat of a section from the beginning of the song or a combination of the beginning and some variations.
But again, the amount of things possible in electronic music is vast. The "expected element" could be something as different as adding a pan and filter setting on a sequence, not a variation of the sequence itself. It just has to be introduced and used enough during the early portions of the song so the listener knows that it's an "expected element."
I guess you could look at it like film editing - CONTINUITY. The listener has to recognize a continuity in your song early on, just like the editing in a film. You must make the audience think (either consciously or unconsciously) "Okay, so this is how they are arranging segments."
It reminds me of the movie "The Limey" my film professor showed us when I was in college as an example of a personalized, human memory-like style of filmmaking. Short shots were scattered throughout the film, skipping back and forward in time, mimicking the main character's thoughts and memories. The film wasn't an extreme version of this, but it was done in a way that the audience was able to follow and expect it. |
dmosc
Posted: Mon Aug 01, 2005 1:34 pm Post subject:
this is a very excellent thread.
I think rodcencko is hitting on a major point here. How open ended should things be? If you have your instruments be "experimental", as well as your rythems, your tempos, your harmony, your structure, etc... you can be overwhelmed with the composition and it can come out lifeless and unfocused.
I love when Amy Newburg expressed in her talk at EM05 that sometimes the technology's capabilities/limits were central themes in a given composition. I think many composers try to do too much, be too "original", and fail not out of lack of inspiration or creativity, but lack of focus.
I had the pleasure of studying with Dr. Payne at Bucknell University for 4 years. He is a renound handbell composer and I had the unique experience of observing him both as a composer and as a conductor. It amazed me that some of his favorite and most popular works were not his most detailed. Before my last year, he wrote a very simply structured piece in basically ABA form which he claimed he wrote 90% of in the course of 15 minutes on an airplane. The piece wasn't technically easy by any means but after some work on the group's part, it quickly showed itself as a wonderful piece. I think the trend in his work of pieces that I liked were when the compositions themselves were not too auspicious and accepted the limitations of the handbells, even embracing the restrictions of the players. After all, in handbells, it's very limiting. Each player only has 2 hands and takes a certain time to put a bell down and pick a bell up. You can learn some amazing techniques but you're not going to create every possible sound you could imagine like a synth. My point is, that the limiting capabilities, rigid structure, and traditional voicings of the bells was a compositional tool, not a thing to be struggled against.
There is great wisdom in seeking a structure before beginning a composition. Imposing limits on your work's scope and allowing more specialized roles for experimentation can have great results. I feel sometimes the community here is too quick to burn the bar lines, notes, rythems, tonality, instrumentation, and anything else you would recognize as "played out". I'm not saying experimentation is not a wonderful and needed thing in this day and age, but you often see more looking through a window than stading outside. |
Kassen
Posted: Mon Aug 01, 2005 2:16 pm Post subject:
| opg wrote: |
I think, with the exception of minimalist electronic music, paul e. brings up a good point about "inspiration/emotion." |
Yes, indeed. I find that many of the pieces I considder especially touching are actually build within a very firm genre-framework. Blues, Folk and Techno all have very ridgid rules but perhaps because of those they allow for a lot of freedom in the areas not covered by those rules.
Do do have a bit of a problem with Paul's "self-evident" and "natural" rules of music. I personally don't think there are rules that are that universal. Admittedly there are some wide-spread phenomena such as some sort of structural/rithmical repitition and the octave but for example drone-based music doesn't need to have either to be quite musical and expressive. _________________ Kassen |
Kassen
Posted: Mon Aug 01, 2005 2:30 pm Post subject:
| dmosc wrote: | | There is great wisdom in seeking a structure before beginning a composition. Imposing limits on your work's scope and allowing more specialized roles for experimentation can have great results. I feel sometimes the community here is too quick to burn the bar lines, notes, rythems, tonality, instrumentation, and anything else you would recognize as "played out". I'm not saying experimentation is not a wonderful and needed thing in this day and age, but you often see more looking through a window than stading outside. |
Yes, I'm very much in agreement. As I see this discussion we are dealing with rules. It apears to me that there are three types of those; those chosen intentionally, those implied by a style and those taken for granted subconciously. (of cource those last two tend to overlap but I think they are different).
What we haven't yet touched upon are the limitations and rules implied by our tools, the sequencer, the modular system, etc; they all imply and often enforce some direction and set of limitations. To get back to the word "grammar"; we need a grammar to express ourselves towards our tools, wether that's matching the right kind of cable to the box, manipulating icons on a schreen or typing definitions straight into a programing language, it's all grammar.
In literature and especially poetry we are allowed to break gramatical rules if this helps us express ourselves and of cource the gramar of our tools can often be broken, for example through cerquit-bending, but in all of those cases it is nesicary to begin with deciding what exactly it is that we want to express. After that we can decide on the proper "language" (and thus grammar) and how ridgidly we'll adhere to the gramar.
I think this is very hard, especailly since so many forms and methods are open to us.
I'm not using the words "rules" in any negative sense here BTW; rules may seem like a limiting concept but it's also rules that make our software dependable (well....) and it's rules that allow you to decode this text (and me to write it). _________________ Kassen |
opg
Posted: Mon Aug 01, 2005 2:41 pm Post subject:
| dmosc wrote: | | I feel sometimes the community here is too quick to burn the bar lines, notes, rythems, tonality, instrumentation, and anything else you would recognize as "played out" |
This is very interesting. I feel the same way about electronic music's seemingly endless musical possibilities. I believe that today, anything you can possibly think of in music can be done. Ironically, it seems that electronic music does NOT have endless possibilities, in a way. We are able to control every aspect of any kind of sound. And THAT feels "played out." I guess why I'm drawn to limitations, like the microsound Gameboy music for example.
And are there really that many aspects to a sound? Think of those aspects in terms of settings and effects on those tools, software, modular systems. Take a sound - a basic waveform, a clip from a movie, whatever - and ask yourself, "How can I mangle this beyond recognition?" You have filters, arpeggiators, granulizers that can reorder pieces to the sound, phasing, all kinds of delay, pitch shifting - AND knobs that can control all of this in real time. And all of these adjustments have SUB-adjustments - delay with a gradual LP filter, oscillating chorus spread, etc.
Sure, there are so many combinations that it seems endless, but you have to think of the music as the final output. The listener is not going to know you got that buzzing sound from a pitched-down loop of an Apple 2e beep! It's because there are only a few aspects of a sound that the human ear recognizes. THAT is the greatest limitation of them all. |
Posted: Mon Aug 01, 2005 4:39 pm Post subject:
| dmosc wrote: | | I feel sometimes the community here is too quick to burn the bar lines, notes, rythems, tonality, instrumentation, and anything else you would recognize as "played out". I'm not saying experimentation is not a wonderful and needed thing in this day and age, but you often see more looking through a window than stading outside. |
I don´t disagree with you re the burning of "traditional" components. That said it does seems like the term experimental music is being used in various and often conflicting ways.
A trend not especially evident here, but indeed very evident at some other boards ouit there is that musicians will use the term experimental (music) in order to say stuff like:
"Hey, I can make electronic music too but I am not quite sure what I am doing.. so like.. I can call it experimental.. everyone else seems to do that anyway"
"All my friends make experimental music so .. uh.. well. I won´t do anything wild.. so I will stick with that too"
etc etc.
Some use the term similar to how some are using the indie pop term.. and making even less sense. Others are using it because they cannot quite come up with a better word for and it sounds cooler than say.."Hey, I am Brad and this is my music.".
Whatever.. and some are indeed seriously making experimental music.
One vital point here is that I am very convinced that it is possible to make personal music that is fairly unique.. and at times very hard to classify.. but still not in any way close to being experimental in the way I understand the term. Listen to the stuff made by Chris Orczy. His music might be improvised, intuitive and seemingly structurally simple and hard to classify. To me it sounds like full and pretty tense compositions.. very mature stuff. but not in any way does it sound to me like experimental music. He clearly knows what he is doing. He understands his own music making processes.
I am not about to say that experimental music is stupid or bad. Far from it. What I do think is that experimental music is a term that does not say much about the very music ( well.. sometimes it REALLY does.. but we have mentioned that earlier in the thread.. so.. ).
Where are all the jazz dudes? In modern jazz there is still room for theory and frameworks. I have often heard "experimental electronic music" that music wise.. is damned close to modern jazz. The only major thing that makes it non-jazz is the claim that it is "experimental electronic music". However, if the same piece of music HAD been tagged with the jazz label.. then it wouldn´t in any way been even close to experimental. It would simply have been mainstream modern jazz.
Perhaps the electronic music community is overplaying the term "experimental"? Perhaps we are really in need of a new vocabulary? _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
