today> Twyndyllyngs reschedule: Sunday, Dec 7 Chez Mosc
 Forum index » Clavia Nord Modular » Wish List
DlyStereo module - lesser time range
Page 1 of 1 [8 Posts]
arturmeinild
G2 patch files: 4
PostPosted: Mon Sep 26, 2005 9:28 am    Post subject: DlyStereo module - lesser time range Reply with quote  Mark this post and the followings unread
On the DlyStereo module the smallest time range is 500ms - this use up 36.9% of the patch memory. It would be nice if you could select a lower time range, like 100ms to free this memory if you don't need the long delay time...
The current reason is that I want to use the Stereo Delay as an early reflection module in a reverb patch, and there 100ms would be more than enough - eating up 40% of the memory just for this module seems quite steep.
sheridan
Audio files: 27
PostPosted: Mon Sep 26, 2005 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah that would be nice... but you can build a cheaper stereo delay from the available modules yourself... although good luck with you ER patch! Very Happy
transformer Sheridan
arturmeinild
G2 patch files: 4
PostPosted: Thu Sep 29, 2005 2:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, I was wondering: Is it possible at all to build a feedback delay (not single or tap) with a delay time (range) less than 500ms? If so, can anyone give me a tip? thanx...
G2 patch files: 626
PostPosted: Thu Sep 29, 2005 4:34 am    Post subject: Reply with quote  Mark this post and the followings unread
like this? It duplicates the function of the DelayA, you can omit the filter if you don't need the HF damping it provides. Use 2 input mixers if you want to make a stereo version with cross feedback.
Very small delay ranges make it into a feed back comb filter.
lessthan500.pch2
feedback delay < 500ms range
 Filename:  lessthan500.pch2
 Filesize:  1.03 KB
 Downloaded:  1822 Time(s)
cebec
G2 patch files: 31
PostPosted: Thu Sep 29, 2005 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
this is helpful, ian, but i'm a unsure of how to implement the crossfeedback...
in fact, i was going to make a patch just like this but couldn't figure out how the crossfeedback would work.
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Thu Sep 29, 2005 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Something like this?
(I also added a highpass filter, I always find them useful with delays, especially short timed delays with high feedback)
lessthan500xfb.pch2
G2ian's lessthan500 patch with cross feedback and high pass filters
 Filename:  lessthan500xfb.pch2
 Filesize:  1.38 KB
 Downloaded:  1639 Time(s)
arturmeinild
G2 patch files: 4
PostPosted: Thu Oct 06, 2005 5:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanx for the tips, it's very usable. Smile
3phase
G2 patch files: 141
PostPosted: Fri Mar 17, 2006 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
You should look in the multiplex thread... i and others was experimenting with delays that have lower samplrates...from what i can hear sofar this can be beneficial also for short delays..its just sounds more like the eralies we know..a bit
