noise in back of pf2??
Page 1 of 1 [5 Posts]
settle
PostPosted: Mon Oct 03, 2005 9:19 pm    Post subject: noise in back of pf2?? Reply with quote  Mark this post and the followings unread
help! ive tried every knob, and was wondering if u all could figure this out for me? im about to work with drumcode performance from mothermisty, and i keep getting this background sequence in the background. even when i turn all the oscillators off....could be somthin in my set up, but ive even cleared all the sequencers and i still get this horrible frikkin testtone sorta thing. ill try and attach an example.
thanx
here
oh, sorry. i think u have to hit the volume buttons to start it. then turn the volume off again and it goes on and on.
killin me.prf2
ahhhhhhh
 Filename:  killin me.prf2
 Filesize:  17.95 KB
 Downloaded:  1262 Time(s)
G2DREAM
PostPosted: Tue Oct 04, 2005 2:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I think it is coming from patch on D slot where you modulate the quantization bits! i am not sure,check it and tell me!
settle
PostPosted: Tue Oct 04, 2005 4:49 am    Post subject: Reply with quote  Mark this post and the followings unread
yeh, i think its a feedback loop of some sort, which adds to the ambience of the patch, but id luv to figure out how to control it. great patch misty. unreal sound.
mother misty
G2 patch files: 130
PostPosted: Tue Oct 04, 2005 11:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi settle,
G2 dream is right, most of the background noise comes from the bitrate modulation.
I've added a s&h module, now the bitrate modulation stops when the masterclock stops.
(I've also deleted the 2 frequency shifters in slot A)
hope this helps...
KILLIN_ME_MF.PRF2
 Filename:  KILLIN_ME_MF.PRF2
 Filesize:  17.69 KB
 Downloaded:  1526 Time(s)
settle
PostPosted: Wed Oct 05, 2005 2:21 am    Post subject: Reply with quote  Mark this post and the followings unread
oh, ok. thanx misty. ill disect slot d. bitrate modulation? ill check it out.
i really appreciate your programming skills.
h
