 Forum index » Clavia Nord Modular » G2 Patches - Completed » Synth
Vector Synth
Page 1 of 1 [2 Posts]
ramsy_gss
PostPosted: Fri Oct 21, 2005 6:53 am    Post subject: Vector Synth Reply with quote  Mark this post and the followings unread
I recently played on a friends vector synth and had a neat little idea to make the G2 do the same but using any old sample I cared to throw at it. Simply play four different waveforms into the audio inputs and record a vector performance. Or use the G2 oscillators instead. I've been using an old akai sampler playing all sorts of waves into the G2. My next test will invlove the a bit of FM as well. I'm not sure whether this qualifies as an audio processor or a synth emulator. It's very open to re-interpretation at this stage.
This is my first post up here, critique would be most welcome.
Vector Synth 1.prf2
 Filename:  Vector Synth 1.prf2
 Filesize:  6.17 KB
 Downloaded:  1484 Time(s)
ramsy_gss
PostPosted: Fri Oct 21, 2005 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I forgot to mention that since I only have the Engine some of the functions of the patch may not make sense at first. Morph groups 1 & 2 control X and Y vectors respectively, Group 3 controls the playback speed, and Morph group 4 works as the record function. Since I only had one knob to control both X and Y recording I set full left (-64 units) to enable X record and full right (64 units) to enable Y recording. I hope this makes sense.
