Patch debug
Page 1 of 1 [8 Posts]
arturmeinild
G2 patch files: 4
PostPosted: Sun Oct 23, 2005 1:08 pm    Post subject: Patch debug Reply with quote  Mark this post and the followings unread
Ok I have a problem - I have no idea why the sequencers are not running in this patch. I'm trying to run the seqs with a 48 kHz control signal, but maybe that's too much? Can anyone help??? Thanx in advance...
EDIT: Apparantly 48 kHz was too much - 24 kHz seems to be working - official patch will be up soon... Smile
8cont1wire_conc2.pch2
hi speed seqs doesn't work...
 Filename:  8cont1wire_conc2.pch2
 Filesize:  1.76 KB
 Downloaded:  1450 Time(s)
PostPosted: Sun Oct 23, 2005 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ehm, what do you mean not running, they run alright ovehere.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sun Oct 23, 2005 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
They run ok over here, the 48K clock is working fine. What are you planning to do?
deknow
PostPosted: Sun Oct 23, 2005 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
...i just loaded it in the demo software and both sequencers seem to be running.
deknow
arturmeinild
G2 patch files: 4
Ok 48 kHz don't work with me, maybe it's because I'm using G2 demo and not hardware... Anyway, this patch allows 8 control signals to be sent through one audio wire (one them must be a red audio signal to set the MUX into 96 kHz mode)...
PostPosted: Sun Oct 23, 2005 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Loaded it into the demo, it runs ok over here ....
When you go to the FX section, click on a button in the sequencer and connect the orange output to one of the outputs you should hear a high pitched sound. Patch attached.
bh-8cont1wire_conc2.pch2
Modification on a test patch, not usefull for anything else - see thread for details.
 Filename:  bh-8cont1wire_conc2.pch2
 Filesize:  1.76 KB
 Downloaded:  2559 Time(s)
arturmeinild
G2 patch files: 4
PostPosted: Sun Oct 23, 2005 1:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
The finished patch is now uploaded here.
http://www.electro-music.com/forum/topic-8355.html
Thanx for the help throughout Jan, the patch actually seems to be working now... Smile
deknow
PostPosted: Sun Oct 23, 2005 3:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
i think my laptop is slightly underpowered for the demo software (which might or might not explain the following).
i sometimes find with the demo software that sequencer and logic indicator lights don't work reliably, even when they are doing what they are supposed to. i think when i loaded your original patch, the sequencer in the fx section didn't look like it was running at first. i have learned to always hook an envelope generator, noise oscillator and output module to logic signals so i can "hear" if they are triggering or not.
deknow
