Kraakdoos...it doesn't work arggg
Page 1 of 1 [10 Posts]
benfox
PostPosted: Sun Feb 12, 2006 3:56 pm    Post subject: Kraakdoos...it doesn't work arggg Reply with quote  Mark this post and the followings unread
I've try to built the Kraakdoos...it doesn't work arggg
I only have humming sounds or white noises...I use a 709 but it's the 14 pins version is it a problem ? I've check the pinout from the datasheet
pin 1 = pin 3 (in the 14pin version)
pin 8 = pin12 ( in the 14pin version)
I notice that there is differences beetween this shematic :
http://www.logosfoundation.org/kursus/2005.html
and this one
http://www.eam.se/kraakdoos/
I follow the last one because it seems more clear to me.
I use bc558 and bc548 instead of 557 and 547 (is it a problem ?)
Any idea on what's going wrong
benfox
PostPosted: Sun Feb 12, 2006 6:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
is it the right place to post it ?
jksuperstar
G2 patch files: 18
PostPosted: Mon Feb 13, 2006 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
THis is the right place. LEt me dig up those parts & see what I find. I'll back to you tomorrow!
bugbrand
PostPosted: Mon Feb 13, 2006 2:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hiya Ben
I've used 14pin 709s just fine.
I'Ve sometimes had wierd noise problems - especially seemed to happen when I tried using larger touch plates.
I found these 2 mods helped a lot (especially if you try to add the audio output as detailed on my electronics page)::::
1 - add a 10n cap from pin 2 to ground.
2 - add a 1M resistor from the touchplate end of cap C1 (the cap that comes off of pin 1 of the 709)
http://www.bugbrand.co.uk
benfox
PostPosted: Mon Feb 13, 2006 4:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanx a lot guys...
During my experimentations i lost a bc558...hell
What could i put to replace this one (pnp...i guesss)
I use crocodile claw (you understand). It's with a wire soldered to the board at one end and atthe other there is a claw crocodile style 2centimeters long...
Is it a problem Question
Your cracke box ouput is made for a speaker output i guess but i want to plug it into an amplifier...or a mixing board...with the original output it should work isn't it ?
bugbrand
PostPosted: Mon Feb 13, 2006 4:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Yo Ben,
Nah, the standard circuit doesn't work for plugging into an external amp/mixer --- I'd love someone to explain why it doesn't work! My extra circuit works fine to get the sound into the mixer/external amp
For the transistors I've used BC547/BC557s and 2N3904/2N3906 - both work fine and, actually, I've also used a combination of BC547/2N3906 and that worked fine too.. General NPN and PNP configs should work fine I think.
benfox
PostPosted: Mon Feb 13, 2006 5:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok thanx i've add a tiny audio transformer on the output and it works i don't have all the sound i expected even on a speaker.
When you said putting a 1Mega resistor from the pin 1 to ground...i've try it cuts every thing ?!
bugbrand
PostPosted: Mon Feb 13, 2006 5:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Nah, the 1Meg resistor should connect to ground after the cap that connects to pin1 (ie by the touchplate)
benfox
PostPosted: Mon Feb 13, 2006 6:00 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry for that stupid question forget this one....
Ok i did right now the 1meg is at the right place but i loose a lot of ionteresting sounds with this...so i will not put it...
benfox
PostPosted: Tue Feb 14, 2006 5:04 am    Post subject: Reply with quote  Mark this post and the followings unread
It dies yesterday....
Am i too much electric for the stuff ?
