Tim Kleinert
G2 patch files: 236
Posted: Sun Mar 05, 2006 1:31 pm Post subject:
Elastic Audio V1.0 Subject description: realtime sample time/pitch manipulation |
Here's my spin on the granular thing. This patch lets you capture 2.7 seconds of audio material. After capturing, you can:
-Continuously manipulate the speed of the playback -from full forwards to freeze to full backwards -without affecting pitch.
-Conversely, change the pitch of the sample up or downward -without affecting speed.
-Freely scrub around in the sample -again, without affecting pitch.
The playback speed is set to zero default. So, after capturing, you won't hear anything right away. I have assigned the (bipolar) pitch stick to the (bipolar) playback speed and the modwheel to the scrubbing position. This way, you can dynamically shuttle back and forth in the sample with the pitch stick and scrub around at leisure with the wheel. Fun.
All controls are also represented on the panel (Page A1). There's also a tuning knob there to tune the sample (regardless of speed).
The last three parameters (grains rate, pitch jitter, readout position jitter) pertain to the granular synth engine of the patch. "Grains rate" controls the speed (and size) of the grains. The jitter parameters, used conservatively, are helpful to "mask" the artefacts caused by the (constant) granulising frequency (especially at high rates). (Without those, the patch sounds identical to old timestretch algorithms on vintage samplers, which is also nice). Cranking up the jitter parameters just warbles the stuff around -fun too.
A cool patch for live jamming. Fits on one DSP. (I squeezed it into the FX section). Enjoy.
best,
tim
 Download (listen) |
| Filename: |
ElasticAudio TK.pch2 |
4.31 KB |
| Downloaded: |
2642 Time(s) |
Posted: Sun Mar 05, 2006 2:35 pm Post subject:
Re: Elastic Audio V1.0 Subject description: realtime sample time/pitch manipulation |
I'll 2nd that, thanks ! _________________ Jan
ian-s
Audio files: 42
G2 patch files: 626
Posted: Sun Mar 05, 2006 3:03 pm Post subject:
| 3rded, daed si luaP! |
Spandex
Posted: Sun Mar 05, 2006 5:23 pm Post subject:
nice one. _________________ --
Lovely Cloakroom.... Lovely Cloaks |
Posted: Sun Mar 05, 2006 7:26 pm Post subject:
| g2ian wrote: | | 3rded, daed si luaP! |
I had to put that through tim's patch inorder to confirm deknow's sneaking PBS suspicion that it's true. |
Afro88
Audio files: 12
G2 patch files: 79
Posted: Sun Mar 05, 2006 7:50 pm Post subject:
| Absolutely awesome patch in both usefulness and sheer G2 wizardry. |
mother misty
Joined: May 13, 2004 Posts: 681 Location: Ghent / Belgium
G2 patch files: 130
Posted: Tue Mar 07, 2006 3:20 am Post subject:
Brilliant patch tim!
I'm having so much fun with this one.
Thanks for sharing. |
Unfed
Joined: May 11, 2004 Posts: 200 Location: Rochester, NY
G2 patch files: 11
