Gothboy
Joined: Feb 21, 2006 Posts: 371 Location: Santa Monica, Ca.
Posted: Thu Mar 23, 2006 9:24 am Post subject:
How to Midi trigger a patch |
O.K.....so I've got this auto-panning patch that right now is using a Clock generator which means that it's constantly making noise when it's up on the screen, say at 120 bpms or whatever. But what if I wanted to use this patch in a MIDI track of one of my songs in Pro Tools where the patch is making noise ONLY when a MIDI note tells it to.......or in other words comes in only during a certain portion of the song? What kind of module do I need to use to make this happen?
I'd also like to know if I can do this with a patch that uses sequencer modules. I know how to sync with bpm.....but can I trigger them from another sequencer so they come in like a little loop a a certain point in the midi track? I know not all of you use PT but this concept goes across the board for any midi/audio program. Here's a screenshot of the patch....is it a matter of adding a keyboard voice to it......and how would I hook it up?
Thanks again to Mosc for hooking me up with Irfanview!
Description: |
Filesize: |
302.8 KB |
Viewed: |
302 Time(s) |
_________________ Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.11.6/El Capitan
Novation SL49, Behringer 2600, Crave, Edge
Mophox4, Nord Lead 2,Modal electronics Argon 8m, Roland System 1, Novation Nova, Nord Micro modular, Korg Radias, Roland d-05, Yamaha A3000 sampler, Novation SL MK2 and Remote Zero controllers, Arturia Beatstep and SparkLE, Korg ER-1, Unosynth
Dymaxion Vehicle Music at www.dymaxionvehicle.com/ |
X-Electric
Joined: Jul 11, 2005 Posts: 182 Location: Warsaw, Poland
Falk
G2 patch files: 29
Posted: Fri Mar 24, 2006 2:26 am Post subject:
You might want to reset the clock generator as well |
You might want to reset the clock generator as well from the gate signal of the note detect module.
That way it will start on the beat.
Regards
Falk |
Gothboy
Posted: Fri Mar 24, 2006 12:27 pm Post subject:
Great! Thanks guys! Another way would be to replace the note detect module with a Keyboard voice module, that way you could select your key anywhere up and down the keyboard range. Brilliant. So I guess it's a case of using the Logic Processor module then. Will this also work with sequencer modules as well? _________________ Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.11.6/El Capitan
X-Electric
Posted: Fri Mar 24, 2006 2:16 pm Post subject:
Gothboy wrote: | Another way would be to replace the note detect module with a Keyboard voice module, that way you could select your key anywhere up and down the keyboard range. |
That's why I said "if You want a specific note"  |
