S/H for logic signals?
Page 1 of 1 [3 Posts]
torsig1967
PostPosted: Sun Apr 02, 2006 8:55 pm    Post subject: S/H for logic signals?
Subject description: Trying to make more CPU effective objects for logic signals
I'm trying to reduce processor needed for logic signals in NM G1.
Is there som way to realize these objects with logic gates and other CPU-effective stuff? They only have to work with logic signals, not audio signals.
- Sample/Hold
- Controllable 2 to 1 switch
- Controllable 1 to 2 switch
(With controllable I mean they should change state when controlsignal changes from 0 to 1 and vice versa)
For the moment I'm using the built in audio S/H, X-fade and pan and they-re not at all CPU-effective. Especially not S/H which needs 1%.
Kassen
PostPosted: Mon Apr 03, 2006 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
S&H can be done with a OR gate. Feed the output back on a input. As as you now put a 1 on the other input it'll stay high forever. Put a AND gate inside of the feedback loop and feed the other input of that with a logic inverter. Now putting a 1 on that inverter will break the chain and get the OR to output 0 again.
1 to 2; feed your signal into two seperate AND gates. On the other input of the first you put your controll signal, on the other input of the second a inverted version of it.
For the 2 to 1 you can use the same trick of two AND gates except that there their inputs will be the different signals and you can mix them with a OR.
These tricks are typically a bit cheaper on the cpu but a bit harder on the zero page. Also remember that complex logic chains may suffer from calculation order problems and that could be fixed by using the faster processing of the x-fade and so on.
Kassen
torsig1967
PostPosted: Mon Apr 03, 2006 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, switches work nicely but I cannot see that the S/H works correctly. Or maybe I didn't understand how you mean. I connected it like in the enclosed picture and it will not work as a proper S/H. Logic 1 on the input will produce logic 1 on the output even before the trig signal. And there's a zeroing issue when output is 1 when the trig arrives.
 Filesize:  9.98 KB
 Viewed:  3528 Time(s)
