my first soundlab
Page 1 of 1 [19 Posts]
EraSer
PostPosted: Wed Apr 12, 2006 8:49 am    Post subject:  my first soundlab Reply with quote  Mark this post and the followings unread
Hello everyone. Very Happy
I'm new in this forum...I'm fascinated by this beautiful synth and by this forum!
I'm a guitarist and I would build and play this great electronic machine.I've read about soundlab mini-synth guide and now I have bought nearly all the parts....but I need your help! Very Happy
first of all...
power supply is +/- 9V...i would use the two VCOs....but I've read in the VCOs schematic that IC LF444 & LF442 power is +/-12V....why?...but the power supply is +/-9V!?!?! Confused
I hope I can rely upon your help Wink
bye Smile
ladislaobiro
PostPosted: Wed Apr 12, 2006 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi balance,
welcome to this forum Very Happy
don't worry about the voltage...
you can run your sound lab from +/-9V to +/-15V with no risk of damaging the unit, and probably with no differences in terms of sound...
if you have further questions, post them here...
I'm sure a lot of people will be happy to help you out... Smile
bye...
ladislao
EraSer
PostPosted: Thu Apr 13, 2006 12:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ladislao
thank u......I've seen you beautiful & cool SoundLab...great work!
I've re-adapted schematics to build mini-synth on perfboard (not stripboard)....so could you say me if they are right?....i will post them soon...
p.s.. sorry but I'm not an expert electronic-man Wink but I've just build some simple theremin on perfboard.
bye.
ladislaobiro
PostPosted: Fri Apr 14, 2006 12:35 am    Post subject: Reply with quote  Mark this post and the followings unread
hi balance,
unfortunately my skills in electronics are pretty limited... I doubt I can really be helpful in checking out schematics, modifications, etc...
the only suggestion I can give you is to try to follow as much as possible on your perforboard the parts layout and traces direction of the PCB version...
otherwise, another obvious suggestion would be that you buy an original PCB from Ray..
I did it, and I'm really glad I did it... it's professionally built and really comfortable to use...
it's up to you...
good luck... Surprised)
ladislao
P.S.: btw, I didn't finish my soundlab yet... the pictures you have seen show my WP-20 and my WSG... ;o)
EraSer
PostPosted: Fri Apr 14, 2006 2:27 am    Post subject: Reply with quote  Mark this post and the followings unread
....what is the difference between SL & WP20?
which of them do you recommend to me?
Pehr
PostPosted: Fri Apr 14, 2006 2:33 am    Post subject: Reply with quote  Mark this post and the followings unread
WP-20
Many moons ago Ray Wilson and Ron Romeo created a small company that sold PC boards and kits. We called it "Waveform Processing" The WP-20 Mini-Synth was our premier product. As I look back at it now I see many things I would do differently today but I wanted to leave it as it was 25 years ago. It's a great project and it makes some very cool sounds. I hope you have fun if you decide to build it. This would make a great junior-high or high-school electronics project.
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
ladislaobiro
PostPosted: Fri Apr 14, 2006 4:07 am    Post subject: Reply with quote  Mark this post and the followings unread
there are a lot of differences in features and sound quality...
the soundlab is definitely much and much better than the WP-20...
I built this one first just because I wanted to start building synthesizers from an easier project...
now that I feel more confident with electronics, I started working on my soundlab...
my suggestion is to build both... these are great machines... great analog sources of sounds... you can even make them working together... layers and layers of great electronic sounds...
ladislao
Wild Zebra
PostPosted: Fri Apr 14, 2006 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I still gotta make one. I have a question. I wonder what other kits Ray had? And if he would post some (if he still has them) on his site. I'm sure he and his friend had some other cool circuits.
"your stripes are killer bro"
EraSer
PostPosted: Sat Apr 15, 2006 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Before beginning to build SL i need some help about:
output&input: osc1 CV, osc2 CV,gate input. do you know how can I use them?
Pehr
PostPosted: Sat Apr 15, 2006 2:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, with a sequencer or a keyboard. Very Happy
YouTube channel
flickr photostream
ladislaobiro
PostPosted: Sat Apr 15, 2006 6:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I've sent you a private message (PM)... check it out...
ladislao
EraSer
PostPosted: Wed Apr 19, 2006 6:58 am    Post subject: Reply with quote  Mark this post and the followings unread
First of all thank you for you help
I have a problem. Wink
Here it's hard to find IC(s) LM13700 ,LF444&442 Crying or Very sad .....I've read the IC's sustitutes list.
Which are the best for SL?
Pehr
PostPosted: Wed Apr 19, 2006 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I used LF347 instead of LF444 and LF412 instead of LF442. Works great! Very Happy
There are more substitutes here Cool
YouTube channel
flickr photostream
EraSer
PostPosted: Wed Apr 19, 2006 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Pehr for your suggestions... Wink
Unfortunately here I don' t succeed to find LFxxx...I've found only TL082 & TL084.I hope i can use them to SL Sad
bye
Balance
EraSer
PostPosted: Wed May 10, 2006 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi everybody Very Happy
which potentiometers have you use for SL?Linear or Log?How can I get finer adjustment?
Wink
dnny
PostPosted: Wed May 10, 2006 4:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Wink
i have all linear exept the mixer pots.
take a look at this:
How do I add fine tuners to the oscillators?
HTH
daniel
www.koelse.org
flickr: cable porn group
EraSer
PostPosted: Tue May 16, 2006 4:39 am    Post subject:   Reply with quote  Mark this post and the followings unread
I've tryed to make a vcf perfb layout.
plese tell me if there are errors Embarassed
I've put on perfboard only components (Ic,res&cap) and I've noted near where some components are connected to.
black=jumper
dnny
PostPosted: Wed May 17, 2006 12:19 am    Post subject: Reply with quote  Mark this post and the followings unread
black=jumper
i can't open that link? maybe you need to post it again.
but you should check this out if you are going to stripboard/prefboard your SL.
www.bent-hology.com/sharedfiles/soundlabbackup.pdf
and take a look on these threads also:
soundlab stripboard
Uncle Krunkus' Stripboard Soundlab
HTH
dnny
www.koelse.org
EraSer
PostPosted: Wed May 17, 2006 1:03 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry,this is my vcf perfboard layout Wink
