my minisystem design
Page 2 of 2 [30 Posts]
Goto page: Previous 1, 2
zipzap
PostPosted: Fri May 26, 2006 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
sounds rasonable. So if you use one filter, you can do signal-lowpass= highpass, -signal=bandpass, -signal=noch
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri May 26, 2006 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
mosc wrote:
If you subtact the input signal from the output of a band pass, do you get a band reject or notch filter?
Yes.
I think the trick comes from the very good ARP 2600 manual. Which has some other good inverter/phase cancellation tips as well.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri May 26, 2006 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Recombining the LP and pseudo HP gives Rob's Allpass. Very useful for building phasers and creating dispersion in delay feedback.
Sorry for the OT
toppobrillo
PostPosted: Fri May 26, 2006 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey synthesis is always on-topic as far as i'm concerned.. after all, it's not what you got, it's most definitely how you use it!
toppobrillo
PostPosted: Sun May 28, 2006 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
nothing new really, just a shot of the finished joystick module in a temporary pressboard panel.. works perfectly Very Happy , and will make testing of other modules as they're built really easy because the outputs are pretty precise. my pushbutton gate is a wee bit bouncy though.
 Filesize:  56.9 KB
 Viewed:  352 Time(s)
 Filesize:  66.39 KB
 Viewed:  366 Time(s)
