strange high pitched "noise" on outputs
Page 1 of 1 [10 Posts]
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Aug 09, 2006 12:53 am    Post subject:  strange high pitched "noise" on outputs
Subject description: 1,1 kilohertz all nite long...
I've just noticed that one of my G2Xs has a weird defect. It outputs a soft constant high pitched frequency on all outputs. I don't know if this has always been so or if it has got worse -I only know that it has started to bother me. It makes this unit unfit for professional recording. That's how loud it is.
The fact is also interesting that this "high pitch noise" is loudest on output 1 and gets somewhat a little less pronounced with 2, 3 and 4.
I've roughly measured the frequency - it's around 1,1k, somewhat more than two octaves above middle C.
What could this be? Anyone else had this? I remember a thread along time ago where there was some discussion about the MIDI chip clock bleeding into the audio (searched for that one, but couldn't find it). Could this be it?
sheridan
Audio files: 27
PostPosted: Wed Aug 09, 2006 4:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Tim,
do you hear the noise even when there are no patches loaded in the slots?
Is the noise constant, ie. a tone, or is it noise?
Finally, is it at 1kHz, or is it high pitched, like hiss?
transformer Sheridan
Audio files: 297
PostPosted: Wed Aug 09, 2006 5:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Makes me think of a ground loop involving USB signals (which is always troublesome (as in too loud for recording) when I use my laptop). Pulling out the USB connectors from both G2s should stop it then.
Kassen
PostPosted: Wed Aug 09, 2006 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
If so ground-lifting the computer may help; that often fixes a lot for laptops, might also work on desktops?
Kassen
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Aug 09, 2006 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your comments.
OK, I should be more specific.
The high pitched tone is always present, regardless of patches being active/inactive/loaded or whatever. It starts within a second or so when powering up the unit and remains constant until power down.
It isn't 'noise' as such, but rather a quite defined pitch at about 1,1k.
The pitch is also not correlated to USB or MIDI activity, as no USB or MIDI connection is present at the moment.
Weird stuff Confused ...
Audio files: 297
PostPosted: Wed Aug 09, 2006 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
tim wrote:
Weird stuff :? ...
Seems so ... does it depend on location, I mean could it be interference from "something else" ?
nbozic
PostPosted: Wed Aug 09, 2006 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Try moving it to another room with as few electronics and cables as possible, and listen to it again.
If the noise is still there it's likely that one of the electronic components in the synth is defective. If there's no noise then you'll have to trace the cause of the interference.
sheridan
Audio files: 27
PostPosted: Wed Aug 09, 2006 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
It doesn't sound at all well... might be time for a service?
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Aug 09, 2006 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't think it depends on location, as I have a second G2X here which performs flawlessly under the very same physical conditions. I've tried it.
I'll do some other experiments, maybe even open it up and have a peek (the warranty is expired anyway). If I find nothing suspicious-well, off to the shop.
Thanks for your replies.
best,
tim
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Wed Aug 09, 2006 6:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tim,
I feel for ya. I had sticky variation buttons on one of my G2 Keybaords (both expanded)
Instruction to taking the g2 apart.
http://www.clavia.se/G2/V1_10/G2expansionboard.pdf
/Dasz
ps.: The panel adjustment procedure is a scary (at times) but functional solution.
