darwen
G2 patch files: 5
Posted: Sun Aug 13, 2006 10:01 am Post subject:
probleme file format |
what does it means when i download a patch and this message appear :
can't load file. file format is not supported.
Is there because i've got an unexpanded G2 ? |
Joined: Apr 03, 2004 Posts: 24672 Location: The Netherlands, Enschede
Posted: Sun Aug 13, 2006 10:36 am Post subject:
No, the file is corrupted, or it is not a G2 patch, or it is a file of a newer version than the OS in your synth is.
You can open the file in a text editor, but only the file header is readable text. It should look like :
| Code: | Version=Nord Modular G2 File Format 1
Type=Patch
Version=23
Info=BUILD 266
In the help/about screen of the G2 editor you can see the version of the editor which is the same version as the OS in your synth. _________________ Jan
darwen
G2 patch files: 5
Posted: Sun Aug 13, 2006 11:07 am Post subject:
| i've got the latest version of the G2 and i load the patch in the G2 section of this site.The last time i can't open a file is on the site of ivity who post some patches on this site. |
Posted: Sun Aug 13, 2006 11:10 am Post subject:
Can you post a link here to a patch you are having trouble with ? _________________ Jan
darwen
G2 patch files: 5
darwen
G2 patch files: 5
Posted: Sun Aug 13, 2006 11:21 am Post subject:
Sorry i post the patch 2 times.  |
Posted: Sun Aug 13, 2006 11:25 am Post subject:
It is not a patch file, the contents of the file are : | Code: |
WARNING: SYSTRAN did not translate the document entirely. The document exceeds the maximum size allowed by the solution.(2048 bytes for plain text) |
No idea where this comes from though, not even if it was caused by electro-music, or by the sender or whoverer ... _________________ Jan
Posted: Sun Aug 13, 2006 11:26 am Post subject:
| darwen wrote: | Sorry i post the patch 2 times.  |
You can try to edit the post
(it has a button above it which says "edit") _________________ Jan
darwen
G2 patch files: 5
Posted: Sun Aug 13, 2006 11:31 am Post subject:
It is an ivity patch that i find on is site.  |
Posted: Sun Aug 13, 2006 11:33 am Post subject:
| darwen wrote: | | It is an ivity patch that i find on is site. :) |
I'm sorry, its not in the patch archive, can you post a link to the page where you found it ? _________________ Jan
darwen
G2 patch files: 5
Posted: Sun Aug 13, 2006 11:45 am Post subject:
You'll have to complain with the webmater of that site I'm affraid, there are more things not working ok there with patches. _________________ Jan
darwen
G2 patch files: 5
Posted: Sun Aug 13, 2006 11:47 am Post subject:
Thanks for your help blue hell  |
