NM G2 and Poly Evolver
Page 1 of 1 [17 Posts]
jonkull
PostPosted: Mon Sep 25, 2006 4:45 pm    Post subject: NM G2 and Poly Evolver Reply with quote  Mark this post and the followings unread
Hello. Probably a stupid topic but...
I'm thinking about selling my Poly Evolver and getting a G2 Engine. I kind of like the open endedness of the G2 and feel like there would be more options for sound design than with the Poly Evolver. I've played a bit with the G2 demo (can't find a real G2 to try out) but since it's monophonic and somewhat crippled I don't know if it makes for a fair comparison. Anyway, I have some (possibly stupid) questions.
The demo is kind of weak/thin sounding...how does it compare to the real thing?
What would be a rough guestimate on the number of voices I'd get out of the G2 on average? Specs say 32 but we all know that never works out on any synth and I know it changes depending on patch complexity.
Can the G2 basically do everything the Poly Evolver can plus more or would I be losing features by selling the Poly Evolver (besides it being analog)?
How is the build quality of the G2 Engine (this is pure speculation I suppose)? I got a good 12 years out of my K2000 before selling it in basically the same condition I bought it in because it was built like a tank. does the nord give the same impression?
Thanks,
Jon
slave to this
G2 patch files: 7
PostPosted: Mon Sep 25, 2006 5:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd keep your poly (especially if you have the keyboard) and just save up and buy an engine when you can. they are both different machines and compliment each other nicely. you'll miss a few of the cool features that the evolver has.
But on a must sell basis, yeah, I think if you get good with modular programming you could mimic it decent enough. Good luck with the choice of waveforms though.
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Mon Sep 25, 2006 5:37 pm    Post subject: Re: NM G2 and Poly Evolver Reply with quote  Mark this post and the followings unread
The only difference in sound between the demo and the real thing is the DAC's. There are people out there that say the DAC's on the G2 sound off. You should really try and track down a G2 and hear for yourself.
As for weak/thin sounds, you can patch massive sounds with the G2, but it takes a bit of work. It's default sound is a little thin (ie, stock 2osc->filter->env synth), but using some tricks around here and some of the filter and distortion building blocks you can get very fat sounds.
Most patches use about 30-50% dsp I've found. So you should expect about 7-8 voices with the average patch.
You'll have a hard time recreating the digital oscs. I guess you could spend time patching something that recreates one of the individual waves if you really missed it, but forget wave sequencing with the original Prophet VS waveforms ala Evolver. The distortion is also unique and I haven't heard anything out of the G2 that is as large. Everything else would be fairly simple to do, but don't expect it to sound like the Evolver. Also don't expect to be able to get all the Evolver features going at once (4 seq's slot with 2 filters, 4 lfos, 3 envs etc.) with polyphony.
It's not heavy, not like a DX7 or anything, but it is solid. Your engine will probably sit hidden away in a rack anyway, because there's nothing to press or use on the panel.
Hope that helps...
jonkull
PostPosted: Mon Sep 25, 2006 5:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd probably think twice if I had the keyboard but I have the Poly Rack. That's something to consider though (having both).
BobTheDog
PostPosted: Tue Sep 26, 2006 5:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I have a PEK and a G2 and I have not heard a single G2 patch that sounds like the evolver, to me they sound very different indeed.
The G2 is a fantastic synth though, I would go for both if you can manage it. I would hate to loose either!
Andy
mother misty
G2 patch files: 130
PostPosted: Tue Sep 26, 2006 7:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Andy
I can't agree more Smile
If I would lose one of them , I'll buy one again tomorrow!
(I even have been thinking of buying a 2nd evolver)
13rian
PostPosted: Tue Sep 26, 2006 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
i second (or third) that emotion! i have a poly rack strapped to a G2 engine and they are a match made in heaven. i might get some major flack for saying this, but i run the evolver thru the nord for processing and blend them at the output. the result is like having one monstrous synth machine.
- b
jonkull
PostPosted: Tue Sep 26, 2006 8:30 am    Post subject: Re: NM G2 and Poly Evolver Reply with quote  Mark this post and the followings unread
OK. That's good. One of the only things I like about the Evolver is the thickness of the sound so if there's a way to make the nord sound thicker than the demo that's a plus.
I figured as much but that's still more than the 4 I have on the Evolver.
You'll have a hard time recreating the digital oscs...(snip)...don't expect to be able to get all the Evolver features going at once (4 seq's slot with 2 filters, 4 lfos, 3 envs etc.) with polyphony.
I don't know that I would want to recreate the Evolver on the Nord. I don't really use my Evolver enough to be bothered. The main reason I bought it was to get a little warmth in my all digital setup (K5000, K2600, FS1R, Z4). It just doesn't really 'fit' like I hoped it would. I've only had it for a week so maybe I'm not giving it the chance I should...
Yeah, that's true...it would be racked and wouldn't really go anywhere. How about the software aspect of it? In your opinion is it a 'real' piece of gear you'd picture yourself playing 5 years from now or will it be a nice big paperweight once software support is discontinued? I guess that's where my hesitation comes in...being tied to a computer makes me feel like I'm buying something that's destined to be obsolete. Normal hardware seems to have more perceived longevity...one of the reasons I don't use softsynths.
So what is it exactly about the Evolver that people like so much?
jonkull
PostPosted: Tue Sep 26, 2006 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
- b
So what is it that everyone loves about the Evolver so much? In my opinion it's a pretty standard fixed path synth with some interesting modulation routings. I don't seem to get the same thrill from it that other people do...though I haven't really had it long enough to really dive in.
13rian
PostPosted: Tue Sep 26, 2006 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Dive in! I personally like the tone. I thoroughly enjoy the programmable nature of the Nord (to the point that it would be worthwhile to keep an obsolete ibook around to program it for many years), but the evolver sound is very unique to my ears. Being able to blend the analog and digital oscillators is one of the best parts for me. The LFO can go from strolling to audio rate (middle c i think?). The sequencers are very cool and lots of people love that about the evolvers, but for me it's more about the pure tone of the box. The hardwired signal flow is pretty well layed out for most of my purposes. The only thing I wish was hardwired differently - the audio input. I would greatly prefer to have one for each voice. But that's just for how I like to use it.
If you can afford to get the G2 without selling the DSI, I highly recomend it. You can always sell off either one afterward if you choose.
- b
jonkull
PostPosted: Tue Sep 26, 2006 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
- b
Just picked up a Micro Modular on Ebay. I figure I can play with that for a while and then decide what to do.
13rian
PostPosted: Tue Sep 26, 2006 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
great idea. i almost mentioned that, but decided not to, only bc you have to use your imagination a bit. the g2 is definitely a few steps up from the micro. but you can get the feel of the functionality at least. have fun and do let us know whatcha think!
- b
jonkull
PostPosted: Tue Sep 26, 2006 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
- b
Yeah...I figured it was one step up from the demo on the computer and I can still keep the Evolver and save myself $700. Now I just need to find my old OS 9 CD.
Jon
13rian
PostPosted: Tue Sep 26, 2006 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
i'd say go ahead and use the 'unsupported' os X editor.
http://www.clavia.se/faq/micro.htm
FAQ#1 read to the bottom there is a link for the beta. It actually always worked pretty well for me.
- b
jonkull
PostPosted: Tue Sep 26, 2006 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. I'll do that.
jonkull
PostPosted: Tue Oct 03, 2006 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well I got my Micro Modular last night. Played with it for a few hours and now I REALLY want a G2. This thing rocks!
Audio files: 297
PostPosted: Tue Oct 03, 2006 5:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some say the NM classics sound better ... maybe that'll comfort you for a while Very Happy
