Picked up a old Tandy joystick what to do?
Page 1 of 1 [7 Posts]
Wild Zebra
PostPosted: Mon Oct 02, 2006 12:13 pm    Post subject: Picked up a old Tandy joystick what to do?
Subject description: CV joystick? maybe APC?
I was going to make a CV joystick for my Sound lab. Don't know how, but thought I'd try or make a Atari Punk Console. I think I'm leaning towards the APC. Maybe CV when I find another. I have a Question though. It has 2 100k pots and the APC uses 470K (500k). If i put a 200k resistor in series on lug one and another on lug two will this be better than just one 400k on one side or the other? I know this will screw the taper up a little but how much does it matter for a little noise box. Or what about just using the 100k's as is? Or what about I just breadboard it and let you all know how it works. Embarassed Now thats a novel approach? Cool
"your stripes are killer bro"
Mikmo
PostPosted: Mon Oct 02, 2006 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
If the APC has timing capacitors you could just make them bigger to compensate for the smaller pot. That would be the easiest way.
Stay Cool
Mikael
http://www.mikmo.dk
DJQUIRK
PostPosted: Mon Oct 02, 2006 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
On my first APC I used 100k pots and adjusted the resistors accordingly and it worked fine. I also tried different caps, namely the electrolytic(cant remember what to though) and it sounded better!! Just play with it until you get what you like or you blow your hands off in a burst fire. At least you will have died serving a higher cause. Twisted Evil
Eternity's beauty is but a delirious void my love
goodrevdoc
PostPosted: Mon Oct 02, 2006 8:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow that's cool zebra. What model? I've been combing the junk stores for months looking for a pot joystick to finally get my APC off breadboard.
-justin
Mikmo
PostPosted: Mon Oct 02, 2006 11:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Logitech Wingman and Wingman Light are pot based, but of course not the Wingman digital.
Only problem is that they are rather large and clumsy and you can't remove the "wanted parts" from the base since its all kind of integrated.
Stay Cool
Mikael
http://www.mikmo.dk
Wild Zebra
PostPosted: Tue Oct 03, 2006 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Not sure what model. It's a very basic tan joysitch with two buttons. I gots paid so I think I'm gonna bread board it tonight. I reckon I'll use resistors and tweak the caps alittle. Probably hook the buttons up a la circuit bend. This is it http://joe.tolumalaska.com/sam/Tandy/Joystick.JPG
It has switches to go between (spring action) back to center, or just loose.
goodrevdoc
PostPosted: Tue Oct 03, 2006 5:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the pic and info, Zebra! That's almost exactly what i was looking for. Now to find one on the cheap...
-jusitn
