passive attenuator for monitoring
Page 1 of 1 [3 Posts]
cebec
G2 patch files: 31
PostPosted: Tue Oct 10, 2006 9:08 am    Post subject: passive attenuator for monitoring Reply with quote  Mark this post and the followings unread
Can I get some recommendations for a passive attenuator to complement a computer audio interface w/ balanced outs and a pair of bi-amplified monitors?
It doesn't need to be fancy...
PostPosted: Tue Oct 10, 2006 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have been using an SM Pro Audio M-Patch passive attenuator and am extremely pleased with the unit.
It is a half-rack unit that comes with rack ears. It uses combo XLR/TRS connections so you can use either kind of cable.
I found a link to a vendor that sells the unit that has good info about it:
http://www.frontendaudio.com/SM_Pro_Audio_M_Patch_Monitor_Control_Station_p/3348.htm
Incidentally, I am using mine for the same purpose as you -- to control the level on a pair of Mackie Active monitors.
cebec
G2 patch files: 31
PostPosted: Tue Oct 10, 2006 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, that looks good.
Only other one I've found so far is the Rolls SLC19 -- it's a fairly simple and inexpensive Stereo Level Control
http://www.rolls.com/new/slc19.html
