Expanded modular
Page 1 of 1 [16 Posts]
murat
PostPosted: Tue Oct 10, 2006 1:13 pm    Post subject: Expanded modular
Subject description: version 1.40 Exp
Hello everybody, this is my first day on yhis forum. I am new to modular synthesis. so it is very difficult for me to program patches (yet).
I have bought a modular and i don´t know if it is expanded. it sais in the beginning screen: version 1.40 Exp, but i am not sure or convinced.
Is there a patch that i can test on my modular. Can someone post a patch that will clarify if i have bougt an expanded version?
thnx
Audio files: 297
PostPosted: Tue Oct 10, 2006 1:25 pm    Post subject: Re: Expanded modular
You better believe it, it's expanded Very Happy
But if you don't you can make a new patch and have it in a slot that is the only one to be active. Then just throw in modules (oscillators for instance, doesn't matter too much) in the (upper) voice area until you have a patchload of somewhere from 51 to 100%. Then raise the voice count and see if you get to 4 or to 8 for the max.
And welcome of course.
edit: I moved this topic to the NM section, that seemed more appropriate.
murat
PostPosted: Tue Oct 10, 2006 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
indeed when i deactivate slot bcd i get 8 voices!!
murat
PostPosted: Tue Oct 10, 2006 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
then bought a expanded modular G2 for 1100. This was a nice deal!!!
murat
PostPosted: Tue Oct 10, 2006 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
1100 EURO
Audio files: 297
PostPosted: Tue Oct 10, 2006 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Congratulations Very Happy
Where did you buy it ?
murat
PostPosted: Tue Oct 10, 2006 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
on the internet (netherlands)
murat
marktplaats
mother misty
G2 patch files: 130
PostPosted: Wed Oct 11, 2006 12:10 am    Post subject: Re: Expanded modular
Hi Murat!
Nice to see you here Smile
welcome
murat
PostPosted: Wed Oct 11, 2006 12:21 am    Post subject: very nice
Subject description: very nice community
Thanks
Altough i have a hard time (since yesterday) to understand the editor , modular and trying to program some relevant sound, I am very happy to see that this is a very nice community (forum) that could help me a lot in understanding the modular. I should have bought this thing earlier (f nice sound, I don't need my korg z1 and NR2 anymore). I think that I am going to read and try a lot of things these days.
Some of the patches of the zipped file (8mb) don't work (I do not hear a thing when I play the keys). Is this normal or do I have to change a setting?
mother misty
G2 patch files: 130
PostPosted: Wed Oct 11, 2006 12:39 am    Post subject: Re: very nice
One some of them you have to push “run”
(because they are sequencer patches, you have to start a clock)
some others probably don’t work because of OS updates.
(some modules in v1.4 use a little bit more DSP since the first version of the OS, making old patches go over 100%)
murat
PostPosted: Wed Oct 11, 2006 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
A lot of them are far lower than 100%. Do do not work.
Audio files: 297
PostPosted: Wed Oct 11, 2006 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Could you give some examples ? No need to post the patches, just the creator and the patch name will do (as we have http://electro-music.com/g2patches.php )
murat
PostPosted: Wed Oct 11, 2006 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
PerfSeq32-B1.pch2
monokit
trem to vibrato.pch2
deknow
lifes ok right now.pch2
deknow
vSaxophone.prf2
Chet
ReaktorSaturator.pch2
chet
Audio files: 297
PostPosted: Wed Oct 11, 2006 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, i'll have a go ...
murat wrote:
PerfSeq32-B1.pch2
monokit
This is a MIDI generator, it assumes keyboard playable patches to be present in slots B and C which it will then sequence.
deknow
This patch is muted, see the little mute button to the right of the patch's main volume knob (in the toolbar). Can be tricky to find Twisted Evil
deknow
The bottom sequencer in the left column is used to control volume, it is set to all zero values for some reason -> no sound. The envadr module is set to very short times, not very helpful either. Guess this was a quick thingy to make some point in some article on the forum.
vSaxophone.prf2
Chet
Is a keyboard patch that works here, strange. Some of Chet's patches however need a breath controller or some modifications before they will sound. It's a must nearly to read the posts that acompany Chet's patches in order to see what they are good for.
chet
This patch assumes a signal to be present on the internal audio busses 1 and 2
Hmm, I really wouldn't have thought there could be that many different reasons Very Happy
murat
PostPosted: Thu Oct 12, 2006 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
OK thanks, I am glad that nothing is strange about my modular.
Just stupid newbie concerns.
