today> Bill Fox solo tonight! Chez Mosc
Thomas Henry XR VCO samples
Page 1 of 1 [14 Posts]
23isgood
PostPosted: Tue Nov 28, 2006 9:06 pm    Post subject: Thomas Henry XR VCO samples
Subject description: XR2206 VCO
Hi everybody. I built three of Thomas Henry’s XR VCO’s a few months ago and its about time I put up some samples for folks to hear.
For the first sample “3 XR-VCO warm” I have the three VCO’s going through a CEM3320 filter with one of those VCO's going through a CEM3320 phase shifter. I am modulating by hand the cutoff and resonance of the phase shifter. On the filter I have an LFO modulating the cutoff. You can hear the VC Skew on one of the VCO's.
For the second sample “3 XR-VCO step sequence” I have the same setup as above except I am not modulating the phase shifter. Instead I mix in the third VCO at around 20 seconds. I am using a Fat Controller for the step sequencer.
I tried posting the links here but they dont work, so you can find them at the top of my website,
http://www.cubanpetemusic.com/
pete
shawn
PostPosted: Wed Nov 29, 2006 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Great samples pete. I was very curious about the CGS gated comparator sometime ago, kudos for demoing that.
23isgood
PostPosted: Wed Nov 29, 2006 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a pic of one of the boards.
XR VCO PCB
 Filesize:  325.49 KB
 Viewed:  17631 Time(s)
23isgood
PostPosted: Wed Nov 29, 2006 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool Shawn. I'm glad you liked the sounds. I'm putting up demos of modules so people can get a better idea of what these modules can do.
There are a few things that need to be adjusted on my VCO's. I noticed that when the VC Skew kicks in, the saw tooth or ramp is louder than the triangle and sine. The square is also louder. I think I need to switch out some resistors.
pete
shawn
PostPosted: Wed Nov 29, 2006 9:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Niiiice. Please do so. The demos last night actually sparked my interest in getting a power supply to start working on some modules. My cnc router is finished so all I have to do is some tweaking and I can finally start making some circuit boards. Yay, no chemicals. Smile
G2 patch files: 626
PostPosted: Wed Nov 29, 2006 1:54 pm    Post subject: Re: Thomas Henry XR VCO samples
I'd like to hear these but I can't get the links on your site to work.
Sad
23isgood
PostPosted: Wed Nov 29, 2006 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok I didn't realise that you can upload mp3's. So here you are.
3 XR-VCO step sequence.mp3
 Filename:  3 XR-VCO step sequence.mp3
 Filesize:  2.38 MB
 Downloaded:  1377 Time(s)
3 XR-VCOwarm.mp3
 Filename:  3 XR-VCOwarm.mp3
 Filesize:  4.43 MB
 Downloaded:  1368 Time(s)
mikeb
PostPosted: Wed Nov 29, 2006 8:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was planning on building one of these really soon and I'm designing my own board for it (I need a few extra things on there, like a power supply, etc.. and don't need a few things.). Could you tell me how much current the circuit is drawing from the + and - 15V supplies?
Thanks.. great samples Smile
23isgood
PostPosted: Thu Nov 30, 2006 12:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure. How do I do that? Measure the current?
mikeb
PostPosted: Thu Nov 30, 2006 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you have a multimeter?
little tutorial here:
http://www.allaboutcircuits.com/vol_6/chpt_2/4.html
Scott Stites
Audio files: 96
PostPosted: Thu Nov 30, 2006 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, I'm at work right now, with laptop speakers and no headphones, but I can tell already I like these samples! Can't wait to go home and hear'em unimpeded by tinny speakers and low volume.
If you used the same resistor values as the original schematic, there's probably nothing wrong with your skew waveform levels. If you haven't checked them out, images of the waveforms are linked on my XR VCO page - you can see the level remains the same throughout the skew. Most likely what you are sensing is the natural difference in the waveforms themselves - a sawtooth and a pulse wave always sound (at least to me) much louder than a sine or a triangle at the same P-P level. The difference is that the sawtooth and pulse waveforms have a lot more harmonic content in them, so they come across perceptually as 'louder'.
Scott
23isgood
PostPosted: Thu Nov 30, 2006 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Scott. Well I think that the square wave output is very loud, but I did look at the skew on my very old Heathkit scope and it looks just like the pics on your site. Well when you listen to the samples again see if you can tell the difference. I did not use the square wave outputs at all. I will put up some samples of those soon.
pete
mikeb
PostPosted: Thu Nov 30, 2006 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
pete
What Scott is saying is that when the waveform skews from sine to ramp, there is just a perceived increase in volume, but not an actual one as you noticed on the scope. hope that helps
23isgood
PostPosted: Thu Nov 30, 2006 3:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh yea I understood. The additional harmonics of the sawtooth are perceived as louder. A sine wave since it is so smooth sounds quieter which is also similar to a triangle wave shape. In these patches i'm using triangle waves with only one of them skewing into sawtooth. Though I did adjust the first two some where between tri and saw for that additional warmth.
I will post some raw wave outputs with no filtering for reference.
