How to Midi trigger a patch
Page 1 of 1 [5 Posts]
Gothboy
PostPosted: Thu Mar 23, 2006 9:24 am    Post subject: How to Midi trigger a patch Reply with quote  Mark this post and the followings unread
O.K.....so I've got this auto-panning patch that right now is using a Clock generator which means that it's constantly making noise when it's up on the screen, say at 120 bpms or whatever. But what if I wanted to use this patch in a MIDI track of one of my songs in Pro Tools where the patch is making noise ONLY when a MIDI note tells it to.......or in other words comes in only during a certain portion of the song? What kind of module do I need to use to make this happen?
I'd also like to know if I can do this with a patch that uses sequencer modules. I know how to sync with bpm.....but can I trigger them from another sequencer so they come in like a little loop a a certain point in the midi track? I know not all of you use PT but this concept goes across the board for any midi/audio program. Here's a screenshot of the patch....is it a matter of adding a keyboard voice to it......and how would I hook it up?
Thanks again to Mosc for hooking me up with Irfanview! Very Happy
 Filesize:  302.8 KB
 Viewed:  302 Time(s)
Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.11.6/El Capitan
Novation SL49, Behringer 2600, Crave, Edge
Mophox4, Nord Lead 2,Modal electronics Argon 8m, Roland System 1, Novation Nova, Nord Micro modular, Korg Radias, Roland d-05, Yamaha A3000 sampler, Novation SL MK2 and Remote Zero controllers, Arturia Beatstep and SparkLE, Korg ER-1, Unosynth
Dymaxion Vehicle Music at www.dymaxionvehicle.com/
X-Electric
PostPosted: Thu Mar 23, 2006 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's one of many possible solutions, if You want a specific note to pass the clock signal to envelope. You could make a D flip-flop if You want to trigger clock signal on/off by this note.
 Filesize:  11.96 KB
 Viewed:  5167 Time(s)
Falk
G2 patch files: 29
PostPosted: Fri Mar 24, 2006 2:26 am    Post subject: You might want to reset the clock generator as well Reply with quote  Mark this post and the followings unread
You might want to reset the clock generator as well from the gate signal of the note detect module.
That way it will start on the beat.
Regards
Falk
Gothboy
PostPosted: Fri Mar 24, 2006 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great! Thanks guys! Another way would be to replace the note detect module with a Keyboard voice module, that way you could select your key anywhere up and down the keyboard range. Brilliant. So I guess it's a case of using the Logic Processor module then. Will this also work with sequencer modules as well?
16 GB Ram
10.11.6/El Capitan
X-Electric
PostPosted: Fri Mar 24, 2006 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's why I said "if You want a specific note" Cool
