Variations Hub
Page 1 of 1 [5 Posts]
k.e.p.
PostPosted: Thu Nov 02, 2006 10:59 am    Post subject: Variations Hub
Subject description: A Max Patch for synced Variations Management
Attached is a small Patch made in Max which I really like for jamming with different Variations in the four Slots of the G2.
It gives me direct access to all Variations in all Slots, mapped to the Keyboard and it uses the G2's MidiClock, syncing/delaying the Variation Changes to the Beginning of the next Bar. Cool (I wish the G2 had this feature build in...)
Additionally it is possible to make Presets out of Variation Combinations and recall these (using the Numeric Keypad) !!
If you set the G2 to Local Off you can control the Variations synced from the G2 Hardware!!!
Currently it's set to a fixed Grid, syncing to each 4/4 Bar, but maybe I'll add different Measures and Grids. Let me know!!
(You need the Max/Msp Runtime in order to run this!)
Enjoy!
Lars
Variations Hub.zip
Control your Variations synced to Midi Clock, make "Variation Combination Presets"...
 Filename:  Variations Hub.zip
 Filesize:  59.89 KB
 Downloaded:  144 Time(s)
3phase
G2 patch files: 141
PostPosted: Thu Nov 02, 2006 10:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
i ve to try it...
max is somehow a great concept because it alows to run patches without owning the program...
actually i would like to own it..but to big investion for my budgets..
or a to big investion too cure curiosity.
i would have evaluated it the usual ways allready...but it seems that the makers of max have good friends in the hacker comunity Wink.
Its however a software that can be valuable in having..a friend of me started 2-3 years ago to concentrate on the video features and he really started to get jobs getting in just by the knowledge he gained in audio/video patching.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri Nov 03, 2006 12:37 am    Post subject: Reply with quote  Mark this post and the followings unread
i do this internally. an 8-1 switch and a s/h set at the downbeat and you're synced...
in my case, i have perfected my timing of variation button pushing, so the above technique is not utilised Smile
/Dasz
k.e.p.
PostPosted: Fri Nov 03, 2006 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
/Dasz
this is how I started using synced Variation Switching, too. But I didn't like that i have to use an extra Slot for this, as e.g. controlling Variations in a Slot A form inside this Slot is a bit confusing...
Using this Patch I have direct access to all 4 Slots, I even don't have to change the focused Slot.
And I can easily save/recall different Variation combinations, great for trying different Arrangements...
And all I have to do, is to open this Max-App, no modifying of my Patches is necessary.
I'm not sure if I will return to the internal Switch->S/H Way for playing live: I try to avoid the need for a Laptop and I still have my hands free on the downbeat for further tweaking (of course, that's the reason for me to do this, not my bad timing, when switching Variations manually Wink )
monobass
G2 patch files: 12
PostPosted: Fri Nov 03, 2006 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I made a patch that did this once and then decided it sounded better 'humanised' Smile
Steve
